How to Change Your Transmission Fluid
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Triparadox, Aug 4, 2019.
  1. Mendel Leisk
    42,373
    Tell me you're just rattling my cage, lol.
  2. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    I had to chime in that at my last ATF change, I rounded out the hex drain plug. Maybe I over-torqued it last time, but the plug was also quite corroded. With cold weather coming, I didn't have time to order a new plug and drill out the old one.
    Fortunately, I have an oil extractor, which is a tool that I've used many times around the garage. I simply sucked as much ATF out through the fill hole as possible, close to 3.5 quarts. Then, I refilled to overflowing.
    Here's an extractor similar to mine, if anyone is interested (LiquiVac Oil Extractor):
    LiquiVac Oil Extractor — 2 Gallon, Model# 2000 | Northern Tool + Equipment
  3. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Drain plugs only need to be snug.
    The only way you'll get ALL the oil out is to dismantle it. 3.5 quarts is good. :)
    Just put 3.5 back in. How you get it out, doesn't matter, really.
    And you don't have to climb under the car. Can you reach the filler plug from the top????
  4. Mendel Leisk
    42,373
    You can run a hose down to it, but you really need to access from below.
    29 ft/lb is the torque spec, a little more than snug.
    jerrymildred likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I almost said that a minute ago, but was just going from memory when I changed it in my PiP. Technically, I think there is an open channel big enough, but you would need an inhuman number of elbows to reach it from above. :D
  6. Mendel Leisk
    42,373
    When I drop the hose down, even with a pit lamp shining up from below, it can take multiple tries to get the hose through and in the vicinity, lol.
  7. jerrymildred
    11,517
    14,171
    Tampa, FL
    First time I did it? Bulls eye!! From then on, at least two tries. LOL!!
    Bbonez and Mendel Leisk like this.
