How to Change Your Transmission Fluid
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Triparadox, Aug 4, 2019.
  1. Mendel Leisk
    42,323
    Not necessarily. Honda for one, recommends a single drain and fill with their traditional automatics. They know only 50% drains, but that's ok. I suppose they adjust the interval accordingly.
    The only time they suggest a full "flush" is in case of fluid contamination, say engine oil inadvertently poured in. And even then the process is simple, albeit more time consuming and costly. The flush is just a series of drain-and-fills, with a good drive in between, three if I recall correctly.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Spoken from experience:whistle:?
    Or do you know someone who has;).
  3. Mendel Leisk
    42,323
    Yeah, I'd poured in about 8 oz of motor oil before I woke up. DIY'd the multiple drain and fills, chagrined...
  4. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    At one of the Bay Area meetups, one member had bought type IV atf for his Gen2 :cool:.
    After the second bottle was being added, I walked by and said “wait, what”:eek:.
    That prompted a similar activity;).
    Sorted it before bad things happened (y).
    jerrymildred and Mendel Leisk like this.
  5. Mendel Leisk
    42,323
    At least he was using some sort of transmission fluid. My offence was a felony... :oops:
  6. CR94
    CR94 Senior Member
    2,826
    1,241
    Northwestern S.C.
    So many ways to overcomplicate a simple drain-n-fill!
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Thanks. I have that document around here somewhere. I just couldn't seem to find it when I wanted it.
  8. Triparadox
    Triparadox Active Member
    201
    108
    I just made a call to one of the very few mechanics that will do it. He said he can do it for $230. That's beyond my expectation. I'm thinking of doing it myself. Can any of you recommend which stuff I need to get?
  9. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    SFO likes this.
  10. Mendel Leisk
    42,323
    They likely have NO clue what's involved. Either that or they're robbers.
    jerrymildred, CR94 and Raytheeagle like this.
  11. Triparadox
    201
    108
    What do you guys often do in the meet ups?
    Do I need that pack of 6 Toyota ATF WS that cost $52 from Amazon? That all? How about the recommended pumps and hoses??
  12. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    We’ve got the tools;).
    All you need are 4 quarts of ATF-WS :).
    And this meetup will be in an actual shop if we get the timing right(y).
    SFO, Robert Holt and jerrymildred like this.
  13. frodoz737
    frodoz737 Top Wrench
    4,798
    2,560
    33
    "Service Advisers" love padding their commission.
  14. CR94
    CR94 Senior Member
    2,826
    1,241
    Northwestern S.C.
    Even if you do it alone, you don't need any fancy tools or a pump if you have simple stuff like small funnel, hose, and hex key.
    jerrymildred and Raytheeagle like this.
  15. schmuber
    schmuber Member
    115
    85
    Georgia
    Good guess about a six pack! Got the fluid wrong though… :whistle:
  16. jerrymildred
    11,517
    14,167
    Tampa, FL
    Other than the big plastic shield you have to remove to access the plugs, it's way easier than changing the engine oil.
    CR94 likes this.
  17. Mendel Leisk
    42,323
    I take the full shield off for oil changes too. Takes 10 minutes tops, once you're used to it. If you never do it, then the plastic fasteners may be seized up with grit.
    There are some access openings in the shield, in vicinity of transaxle drain/fill bolts, but not taking the shield off I suspect you'd get some splashing. Not sure, never tried it.
    jerrymildred likes this.
  18. Triparadox
    201
    108
    Wait.. Wrong fluid? When I googled transmission fluid for prius that's all I got
  19. CR94
    CR94 Senior Member
    2,826
    1,241
    Northwestern S.C.
    That was a joke, methinks..
    Four quarts should be ample.
  20. schmuber
    schmuber Member
    115
    85
    Georgia
    Summertime. Bunch of guys messing with cars. Six pack…
