How to Change Your Transmission Fluid
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Triparadox, Aug 4, 2019.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I guess I'm kind of similar. Usually, when I take in the used oil is when I buy the new oil, washer, & filter so it's on hand when I'm ready.
  2. Triparadox
    Triparadox Active Member
    201
    108
    Cool.. I'm afraid that I might miss the meet up... good to hear that
    RMB and Raytheeagle like this.
  3. bjb120
    bjb120 New Member
    Saint Louis
    I accidentally did the tranny change on floor ramps. Do you think it is ok? I capped as soon as it started flowing out.
  4. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Having not done this and only reading about it in here, my guess would be the car must be level when doing this procedure.
  5. jerrymildred
    11,517
    14,167
    Tampa, FL
    The drain & fill plugs are closer to the back than the front. So, with the front higher, it might actually drain a little better. However, when you fill it, it won't get quite as full. Instructions say to fill it so the level is between 0-10 mm below the filler plug opening. If you fill it to the brim and plug it immediately, the level is probably slightly lower than 10 mm below the opening depending on how high the ramps and how much the ground slopes. Probably tolerable, but not ideal.
  6. Mendel Leisk
    42,343
    Have you got any left over fluid? Raise it again, this time level, and see if you can get a bit more in?
    CR94 and jerrymildred like this.
  7. Mendel Leisk
    42,343
    Toyota has a document that says to only use fluid from a newly opened bottle (This REALLY should be printed on the bottle, btw). I'm onboard with that, but I think if it's a matter of days it's ok.
  8. abdullah arslan
    189
    79
    I just changed it by myself just only paying $40 for fluids. Unscrewed bolts by using alan wrench (10mm) with a metal pipe to leverage. And it worked great. For the filling, use a 3-4ft hose but be careful that is should be thick enough. And even though it is not so high, car ramps provide adequate clearance for the job. By the way, my 2010 prius is on 242k now. I asked the previous owner, it had the last drain about 60k. So the fluid was like raw petroleum :)
    jerrymildred and Mendel Leisk like this.
  9. Triparadox
    201
    108
    I already have the fluids. The only thing that keeps me from doing it if I have to take off the splash panel. It's already hard for me to reinstall the front splash panel, let alone the whole thing off. Also I don't know how many clips that are going to be broken since I bet they're all old.
  10. abdullah arslan
    189
    79
    If you have extra clips like this one
    , you will have no worries. I installed new clips for the whole panel. Some of them were not in good shape and some other were broken by me :)
  11. jerrymildred
    11,517
    14,167
    Tampa, FL
    If you want to get the official ones that will for sure fit, they cost a little more, but here's all that you need for a gen 3.
  12. Mendel Leisk
    42,343
    If you're thinking you need to take off the front most black under panel, in order to remove the engine under panel (the front panel does lap over the engine panel), that's not the case: you can just slip the leading edge of the engine under panel out from under that front most panel. There's four shared bolts you remove to free the connection.
    If you take the engine under panel off regularly, get practical tools for helping to pry the plastic fasteners off, and always wash the plastic fasteners free off grit, you'll find it's very easy, about 5 minutes for removal or reinstall.
    My main plastic fastener removal tool is a paint can opener, one of these:
    jerrymildred likes this.
  13. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    I bought 2 bags like that for $10 on ebay.
    Haven't used any yet, but certain I will...
  14. Mendel Leisk
    42,343
    Just did:
    (11) - 90467-07201 (regular)
    (2) - 90467-09227 (bigger)
    through Amayama.
    All
    in, $25.07 CDN.
    That's enough to replace every one, but right now I'll just do the 2 bigger ones, and a few of the regulars. They're all present and accounted for, but with the bigger ones the pins keep falling right out, and some of the regular are missing a jaw.
    That's after 9 years, taking the cover off probably around 24 times.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    There are deals that sells the clips and the removal tool as a package/kit. I busted clips with the paint lid removal tool before so I decided to get the fastener removal in a kit and never looked back. We always use it at our meet ups.
    Raytheeagle and Mendel Leisk like this.
  16. Mendel Leisk
    42,343
    Can you post link or pic of that tool?
  17. jerrymildred
    11,517
    14,167
    Tampa, FL
    Please! (y)
  18. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    This?
    I have 3 or 4 of them, but I don't use them. The angle is bit too steep for most fasteners I needed to remove. I could not get the flat tips to insert easily between the fastener's center rivet part and the plastic collar part to pup out the rivet part off. I've had better success removing those clips with regular plastic panel removal tools like those.
    #98 Salamander_King, Nov 22, 2019
  19. ASRDogman
    8,063
    4,086
  20. Mendel Leisk
    42,343
    Those slip under the fastener collar, but not really practical for lifting the head. I have a tool like that, use it occasional, if the fastener won't pop out, even after the head is raised. Rarely happens though, usually when fastener is on it's last legs, maybe a bit grit jammed.
