How to charge @office; no outlet :-(
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fouaddba, Nov 29, 2012.
  1. John H
    John H Senior Member
    2,208
    558
    get a co-worker with a Hummer and an inverter to charge up your PiP in the parking lot.
    Send me a photos please. :)
    lensovet likes this.
  2. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    If Honda's 2000 W generator specs are to be believed, you can generate 3 kWh using 0.55 gallons of fuel. That full charge might get you 10 - 15 miles, or 18 - 27 MPG. Not good.
  3. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    We should consider the environment more, man, global warming is so appalling, that is the reason for plug-in models. I suggest buying a nuclear plant and install it in office, this is the way to go.
    WE0H likes this.
  4. PiPLosAngeles
    1,551
    724
    A 1.5 kW PV array shouldn't cost too much, all things considered. As long as you're parked for three hours during peak irradiance (10 am - 2 pm) you should get a full charge.
  5. John H
    2,208
    558
    Or get one of these setups and pay some landscapers to charge up the PiP . Job Creation!
    Buy Now Pedal Power Bicycle Generator Alternative Green Human Power
    Energy
  6. Mendel Leisk
    42,383
    What sort of panel is that, how big? I seriously doubt it's possible to charge a PIP with any sort of portable solar panel.
  7. PiPLosAngeles
    1,551
    724
    It's about 6 large panels like you'd install on a roof. The panels and inverter will cost a few thousand dollars at a minimum.
  8. PiPLosAngeles
    1,551
    724
    Gets me to thinking about putting up a little 2-panel system just so I can net 0 kWh charging the PiP.
  9. bisco
    52,915
    i'm spending .50/day so approx. $150./yr on electricity. how much would a net 0 array system cost?
  10. PiPLosAngeles
    1,551
    724
    Probably close to $3000. It's not worth it from a financial perspective.
  11. This is the direction to go, get your fellow workers and Supervision excited about the car. Mgt will probably gladly go along with installing a outlet, a chargepoint. You do the research for them.
  12. bisco
    52,915
    that's only a 20 year breakeven, what if i diy it? or is that already?
  13. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Yep, generator, lawn mowers, leaf blowers, etc. are horrible polluters compared to currently sold fossil fuel burning cars, esp. a PZEV rated car like the Prius and PiP.
  14. 3PriusMike
    3,101
    2,421
    Silicon Valley
    They may have expired, but there were federal tax rebates for installing a charger.
    Mike
  15. lensovet
    2,615
    496
    Burlington, NJ
    Those ended in December 2011 and haven't been renewed since. Thank the party that's not in the White House…
  16. PriusPlugIn
    PriusPlugIn New Member
    Ditto on the plug install. Don't use a generator.. What's the point of the plug in? Besides, someone would definately steal that 1200.00 Honda generator
  17. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Easily 3 grand just for the panels. Figure another couple of grand for a set of batteries, charge controller, and inverter.
  18. lensovet
    2,615
    496
    Burlington, NJ
    yeah, i mean, consider that a single charge costs less than $1 (if it costs more, you're better off just filling with gas anyway). Even at $1, you're looking at thousands of charges before payback. At 250 working days/year, even at $3k cost for panels, you're looking at a 12-year payback period…!
    Andyprius # 1 likes this.
  19. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Realistically the OP is out of luck with his charging problem.
    But
    How about a second EV battery that could be removed and taken into the office and recharged?
    But wouldn't that allow him to just drive home with the extra range anyway?
    Well yes but this way he could mooch power from his workplace.
    Bisco lives in the land of gloom ie Boston winter. Would need way more panels and stuff than those of you in the land of sunshine. and there is a concurrent solar thread so I'll leave it at that.
    To provide just the electricity for two charge stations at a new construction fast food pad site is est $3,000. 225 ft. minimum one way dedicated circuits trenched in in their own conduit plus disconnects, breakers ect. Amperage and voltage drop require the use much larger gauge cooper ie $$$. If we ever get one built I'll write it up.
  20. bisco
    52,915
    lugging around a battery would be an interesting site.:)
