How to charge @office; no outlet :-(
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fouaddba, Nov 29, 2012.
  1. lensovet
    2,615
    496
    Burlington, NJ
    Remember Jim? He seemed very happy with his setup.
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    portable Solar power station. from Costco. about $250. will need to run all day but should get half a charge or so...
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  4. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
  5. bisco
    52,914
    jim335? did he haul the battery into his office every day to charge it?
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  7. lensovet
    2,615
    496
    Burlington, NJ
    lol no, but it would be doable – the assembly is something like 60-70 lbs. don't forget that it has its own charger anyway, so this would actually work out pretty well…
  8. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    j 1772 evse needs a least 6 amps. No data on minimum amps the pip needs to start charging. Pilot signal would have to track the array current also.
  9. bisco
    52,914
    i know i'm a skeptic, but i have to question the authenticity of jim's thread. partly due to the shaky history of pis and partly to jim's picture of the battery in the back with the cables tucked under the carpet.
  10. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Any of these solar powered options will require the use of a battery, charge controller, and inverter. A solar panel's output is not steady enough to just directly power an inverter of the size needed to charge the PiP. The reason that grid-tie solar installations don't need a battery is because the grid itself functions as the battery.
    lensovet likes this.
  11. Savantster
    Savantster Junior Member
    40
    Colorado Springs, CO
    Or, they make those extra battery packs (perm mounted, I believe) that you could add to your plug in. It just adds more battery/range, so you'd just be charging more at home.. but should increase your range enough for your commute. Although, those are something like $1,500 and up.. It's probably a lot cheaper just to use the ICE for the last few miles or your trip.
  12. Raj Rajan
    Raj Rajan Eco Dashboard: Green-E
    Eagan, MN
    I have had my 2012 PiP for two weeks, with no place to plug it in (I am on temp relo and in an apartment). I have averaged 51 MPG for my first 150 miles in pure HV mode. Finally found a chargepoint public charging station today. Charged for an hour at 220V and got 10.6 miles EV range. It was wonderful to drive back in that mode! I will just have to wait until we move into a home with a garage and outlets!
  13. bisco
    52,914
    hope it's soon!
  14. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    100-foot 12/3 extension cords are only $49 on Amazon. Run one out the window to the car.
  15. Joeypip
    Joeypip New Member
    Boston
    I really hate to say it because you just bought "A" car, pip or otherwise. If your round trip is 23 miles, you would have been better off with a Volt.
  16. PiPLosAngeles
    1,551
    724
    That depends on how often he drives longer distances. My commute is 21 miles each way, but I frequently make 50 - 100 mile trips so I needed the 50+ MPG of the Prius.
  17. bisco
    52,914
    with a larger interior.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    and seating for five:D
  19. bisco
    52,914
    exactly. range is only one of many factors for deciding between volt and pip.
  20. MandyTee
    MandyTee 2012 Prius Three ~ Classic Silver Metallic
    49
    16
    Greater ChicagoLand, IL
    I can't help but wonder why you did not consider this before purchasing the PIP? It didn't occur to think about where you'll plug in while you're at work?
    I'd speak directly with my employer about it; maybe they'll give you a hand and offer some solutions, or perhaps split the cost of installing an outlet with you?
