How to circulate air with only fans?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Francos, Mar 29, 2013.
  1. Francos
    Francos Member
    118
    I just want to circualate air. Everytime, I increase the speed of the fans, automatic temperature control kicked in. Any one know the proper way to bypass Temp control (no heat or AC)?
    52,804
    if everything is off, you should be able to press the fan speed button without anything else happening. someone else was complaining about this the other day. if auto comes on, one push should shut it off.
  3. El Dobro
    El Dobro A Member
    7,102
    3,282
    With the system off, there is no fan running. I just crack a window open.
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    . Same problem here, but I see that in the beginning of the AC section in the thick book, everything seems to be dependent on the initial settings. I confess that I have not digested that section as it seemed to be beyond me. Tomorrow I will endeavor to comprehend it and then if you do the same we can compare notes. How's that sound?
  5. Andyprius1
    2,327
    859
    Cool CA
    . That's giving up El Dobro
  6. Andyprius1
    2,327
    859
    Cool CA
    again that is bypassing the system, there must be a settable temp to preclude all this off/on, and button pushing. If I don't find it tomorrow I have a appt. with Toyota at 0700 on Monday at dawn, six guns in hand.
  7. Andyprius1
    2,327
    859
    Cool CA
    Good Night.
  8. El Dobro
    El Dobro A Member
    7,102
    3,282
    Keeps the windows from fogging up.
  9. Andyprius1
    2,327
    859
    Cool CA
    That's another interesting point, I have never had a car where the windshield fogs up on the outside. Pg. 368. Owners manual.
  10. El Dobro
    El Dobro A Member
    7,102
    3,282
    It's more like frosting up rather than fogging up on the outside, when the windshield is cold.
  11. El Dobro
    El Dobro A Member
    7,102
    3,282
    Not giving up, more like lessening the chances of the ICE turning on.
  12. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Set the temp to LO, press the AC button to turn the AC off, then adjust the fan and mode.
    Make sure you do not press the filter button (next to the Mode button) by accident.
  13. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Or you could take one sixgun with a couple of speedloaders. Easier than holding six guns. :p
    Ken Blake likes this.
  14. Francos
    Francos Member
    118
    I think I got it. I turned the temp control to low, was able to increase fan speed to get cold air outside. The temp out is about 54, inside is around 60. AC was not on.
  15. bisco
    52,804
    brilliant!(y)
