How to clean clogged EGR cooler?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by anonymous, Jul 22, 2018.
Tags:
  1. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I zoomed in on it. Dawn Professional Power Dissolver. I’d never heard of it before today.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Raytheeagle and Mendel Leisk like this.
  3. Mendel Leisk
    42,280
    Judging from the above PDF, PH is 13, about the same as oven cleaner. Oxi-Clean is 11, worked for me. But yeah if it's tough, higher miles you could give it a try. Be really careful with it though: gloves, eye protection, wear old clothes, rubber apron and so on.
  4. ASRDogman
    ASRDogman Senior Member
    8,048
    4,081
    Okay, thanks. But I'm super happy with the ease of oven cleaner. :)
    But the pressure washing is calling to me.......
    Raytheeagle likes this.
  5. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    I find this really interesting:
    "mostly powdered carbons easily blown by compressed air"
    I wonder what causes the difference.
    Merkey and Mendel Leisk like this.
  6. CR94
    CR94 Senior Member
    2,820
    1,238
    Northwestern S.C.
    Is it acquiring its exhaust gas post-converter, like the 4th-generation Prius does (as I understand)?
  7. Mendel Leisk
    42,280
    ^Very good point; that could well be the difference. Some 4th gen'r (preferably with at least 50K miles) should get off their duff, check and post a pic of the EGR pipe, the piece between valve and intake manifold.
    mikey_t, CR94 and SFO like this.
  8. Mendel Leisk
    42,280
    Considering the revised 4th gen EGR intake location (downstream of the Cat, as opposed to 3rd gen's in the exhaust manifold), and the more-or-less doubling of the EGR cross-sectional area, it's readily apparent the Toyota engineers had alarm bells ringing. EGR revision is even noted in a white paper on the 4th gen Prius (which I can't find at the moment).
    Meanwhile, for 3rd gen owners, they don't want to know. They pay lip-service, but too-little-too-late.
    Chuck Pearson, Merkey and CR94 like this.
  9. anonymous
    anonymous Member
    177
    104
    US
    Here is what the cooler looked like 32.5k miles after last cleaning
    Actual flow was worse than it appears; barely let any light through and was almost clogged again.
    Cleaned again, initially with brake cleaner then rest with pressure washer. Did a good job but didn't clear all passages, so it probably won't last as long (although now with new valve stem seals maybe it won't dirty up so quickly)
  10. ASRDogman
    8,048
    4,081
    So you believe the oil leaking is through the valve guide seals?
    I replace a lot of mid 80's Mercedes valve guide seals. Some type of defect.
    Made lot's of money from those jobs! Easy and fast! :)
    I think it's more the seals than the rings. I haven't seen any photos or video of the rings clogged up.
    I'm not saying that they are not doing that, I just have not seen any.
    It would seem there would be more cylinder failures if the rings clogged, it would seize.
  11. Mendel Leisk
    42,280
    Holy smoke! That's quite well along. I'm gonna make a note of that, appreciate the datum. Did you have an oil catch can?
    Send an Xmas greeting card to Toyota, with that "before" snapshot on the front.
    mikey_t and SFO like this.
  12. Bbonez
    Bbonez Member
    40
    44
    I'm going to pull my cooler and clean it out soon, I like the idea of using a pressure washer as i have access to one with a diesel burner to heat the water. I was planning on using hot water and some of this degreaser:
    Is there anything we need to be careful with when hitting the cooler with a high pressure hot water/degreaser combo?
  13. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Why do I have the urge to pull the EGR valve on mine that has 18k since cleaning just to take a look? Seeing this makes me very curious to see how mine is doing.
  14. Mendel Leisk
    42,280
    And it's so much easier the second time 'round...
    mikey_t and Raytheeagle like this.
  15. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Particularly if the lower nut under the cooler has been left off;).
    I did our 2010’s circuit cleanse twice and the second time at a 50k miles interval:).
    Thought that was appropriate for future changes(y).
  16. Mendel Leisk
    42,280
    With @anonymous' pic it looks like the rightmost portion was 100% clogged, maybe since last time? That mighta accelerating the clogging of the rest??
    Hey, I'm with @cnc97...
  17. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Channeled flow leads to issues as there is less area to distribute the load:cool:.
    But a frequent cleanse is required (y).
  18. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I’m thinking pull the EGR valve, undo the exhaust tube, and hose it down with brake cleaner. Then let it air dry. If Sunday is nice here like they say, I’m going that route.
  19. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    So you're gonna try to clean it while still mounted? It would be great to not have to pull the coolant hoses. I would still do the wire on the drill thing, I would think that would give you the most bang for your buck. Is it possible to move the exhaust pipe out of the way once it's disconnected?
  20. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    My engine has only 18k or so since last cleaning. If I find anything pulling the valve, I’ll decide how to proceed.
    Raytheeagle and mikey_t like this.
