How to clean engine bay area?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Rainking, Feb 7, 2013.
  1. Rainking
    Rainking Member
    164
    New York
    NY uses lots of salt on their roads and noticed the engine bay is all yucky. I want to clean it but something tells me I can't spray engine degreaser and blast it with water. So how should I clean it. The salt is everywhere from the synergy drive and to the side walls.
    JMD likes this.
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Follow
  3. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    blast it with a power washer. it'll be fine.
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I would be VERY careful with that power washer. You can flood the spark plugs since they are set into deep holes and any number of wire connectors can be overwhelmed by a powerful spray. I would try to keep the spray on the lower side of the engine away from any wires.
    PriusCamper likes this.
  5. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    Yes, I agree with xpcman... There's way more electrical components in a Prius to risk a powerwash up top.... You could definitely power wash the underside of the car regularly and go after the spots where it enter the engine bay. But up top just use a mild non-toxic all purpose cleaner and some rags and some random tools to get into the nooks and crannies.
    Also always pop the hood and wipe everything down after you wash the car, that's a good way to keep it clean....
    Unfortunately salt is the worst thing ever for a car so the more you can keep the whole vehicle clean of all that the better.
  6. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I have been using Simple Green on my engines for 25 years. Spray it on, wait a couple of minutes, rinse it off. More as needed. Works great for me. I used to damage stuff using the car wash to clean engines. Not a problem with Simple Green and water.
    Dan
    Rainking likes this.
  7. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    Throw away the power washers. I like the suggestion of using Simple Green and then using a low pressure garden hose to rinse it off.
    Matthew813, Rainking and WD0AFQ like this.
  8. Rainking
    Rainking Member
    164
    New York
    Thanks! I will try the simple green and rising it with the garden hose.
  9. champion510
    champion510 Junior Member
    23
    I have done that before to my lexus sc300 and let me tell you.. it is not cheap to get them replaced and wait for water to flush out..
  10. Paul79UF
    Paul79UF Junior Member
    27
    Orange County, CA
    I also like using Simple Green to de-grease an engine bay.
    Just keep the garden hose sprayer on a gentle setting such as "shower".
    Let the engine dry out before starting the car again.
