how to clear error P0A80
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gerald10, Jun 10, 2026.
  1. Gerald10
    Gerald10 Junior Member
    38
    I replaced the hybrid battery in my 2011 Toyota Prius. Is it correct that I need to drive a few miles for the permanent P0A80 error code to clear?
    Thanks,
    Gerald
  2. JC91006
    16,931
    8,640
    This can be really tricky if you didn't replace it with a brand new battery. That permanent code is a pain to clear on a gen 3 car, unless it's a new battery. Then you just drive it a bit and it clears on it's own
  3. Gerald10
    38
    got a new battery installed.
  4. Tombukt2
    Tombukt2 Senior Member
    13,798
    2,501
    Durham NC
    All you care is that that code now stays history not current or active that's it
    ScottHz likes this.
  5. JC91006
    16,931
    8,640
    if it's a new battery, you just drive it a little bit. Should be cleared in a couple days. I would give it an entire weeks worth of driving before you go back and complain.
  6. Brian1954
    Brian1954 Senior Member
    2,650
    1,058
    South Central PA, USA
    You need to complete the Confirmation Driving Pattern to clear the permanent P0A80 code. Take a look at post #53 in this thread, https://priuschat.com/index.php?posts/3595679
    ScottHz likes this.
  7. JC91006
    16,931
    8,640
    deleted
    #7 JC91006, Jun 10, 2026
  8. Gerald10
    38
    i now got error c2124 error code after battery replacement. why is that? any idea?
  9. Brian1954
    2,650
    1,058
    From Google AI:
    "Code C2124 on a 2011 Toyota Prius indicates a Tire Pressure Monitoring System (TPMS) malfunction. Specifically, it means the car's receiver has lost connection with Transmitter ID 4 (the fourth tire pressure sensor). This almost always happens when the internal battery inside the sensor dies after 5–10 years of use, causing it to stop broadcasting."
    The C2124 code is not related in any way with the hybrid battery replacement. It is a separate issue.
    #9 Brian1954, Jun 10, 2026
    ScottHz likes this.
  10. Gerald10
    38
    i just replaced all 4 tpms sensor last year.
    ScottHz likes this.
  11. Brian1954
    2,650
    1,058
    Does the tire pressure warning lights come on when you are driving the car?
    #11 Brian1954, Jun 10, 2026
  12. ChapmanF
    18,946
    Driving the confirmation pattern is usually a way to hurry along the forgetting of the permanent code that would happen anyway in due course of normal driving.
    The trouble code is detected by a self test that the car will run under certain circumstances during a drive. So the driving you do has to hit those circumstances, so the self test will run, and the test result has to be ok, and when you're not doing the confirmation pattern, just driving around normally, the test has come out ok consistently over a certain number of drives.
    When you do the confirmation pattern, you deliberately drive in the necessary way so the self test can run, and the car knows you're doing this on purpose and only needs to see the test turn out ok one time to forget the permanent code.
    ScottHz likes this.
  13. douglasjre
    douglasjre Senior Member
    2,245
    751
    Null, NL
