How To Cool Down Your Car Without A/C
Discussion in 'Gen 3 Prius Main Forum' started by Maine Pilot, Jul 20, 2011.
  1. barcelona11
    barcelona11 New Member
    71
    Central NC, USA
    There is IR paint/coating for metal roofing in classic barn red and other darkish colors. It doesn't have to be white/light. I have put roofing samples out in the sun, and the temperature difference between the IR coatings and regular coatings is remarkable.
    An excerpt from
    http://www.coolmetalroofing.org/elements/uploads/casestudies/TMI_CaseStudy_25.pdf
    In general, dark colors absorb most of the visible light striking the surface while lighter colors reflect most of that solar energy. This would suggest that color is an indication of how much solar visible energy will be reflected. The amount of infrared energy that is reflected is often a function of the color as well, but recently new pigment technology has been introduced to change that assumption. New IR reflective pigments in paint systems allow for darker colors to actually reflect more total solar energy. [end of quote]
    The above study also contains a graph showing how much of the solar spectrum is in the infrared.
    For the record, since I couldn't get a light green 2011, I wanted Blizzard Pearl, but all the ones coming in at the dealership had leather and other high-end options we didn't want.
  2. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    Back in the 90's a buddy of mine had an IROC, nice car but no A/C. He would get in the hot car and drive off without opening the windows. After boiling for about 5 minutes, he would open the windows, and I swear, it FELT like A/C.
    In this example, the extra effort will make you feel comfortable once you sit down and drive away. I would just stick with A/C
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Please correct me if I am misunderstanding, but the IR paints claim to fame seems to be high emissivity. The reflectance results mirror what is expected based on their color.
  4. Maine Pilot
    Maine Pilot Senior Member
    166
    504
    Saco, Maine
    True; however, in the meantime you're breathing in that superheated air which adds to your discomfort.
  5. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Most things have an emissivity around 0.95 (on a scale of 0 - 1). Not much higher to go.
    Link is broken.
    While it might be possible to create a dark IR paint that reflects more Solar energy than an IR absorbing light color, I find it hard to believe that you can make one that reflects more than a IR reflecting light color.
  6. barcelona11
    71
    Central NC, USA
    Sorry, I didn't test the link after I posted. I replaced it, but it still acts broken. After clicking it, click "Case Studies" then "Cool Metal Roofing - An Emerging Hot Topic" to get to the study.
    I, too, doubt that a dark color with IR (infrared reflecting) pigment is cooler than a light color, but it is more cool than the same darker color without the IR pigment. In other words, there's a way to improve the heat-absorption situation with darker colors. Wouldn't it be great to have a Barcelona Red car that was cool to the touch (that is, ambient temperature) after sitting in the sun?
  7. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    If you want to cool down your car without A/C do this:
    Move to the northwest along the Pacific Ocean.....
    A/C is not needed.....
    The land of 9 months of winter and 3 months of spring...
    alfon
  8. babybird
    babybird Member
    117
    44
    Colorado
  9. drash
    drash Senior Member
    2,600
    1,339
    Upstate NY
    XLE AWD-e
    Actually long ago I put in white seat covers and draped a white towel over the dash. I wanted white because I thought it would look cool. Temperature inside went down by 10 F. But since I worked in warehouse they didn't stay white long.
  10. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    I guess that would do ok for an exchange of air. Recently I've been opening the door, putting foot on brake without getting in car, turning on power and then just stepping aside for a very short while (15 seconds) as AC gets going. Only on the hottest of hot days, though.
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Even on 100 degree days I find the combination of the sun shield, tinted windows and a short period of time where the "windows are completely down works fine for cooling the interior.
    If you can cool the interior to ambient temperature before starting the AC then you'll reduce the initial mpg hit imposed by the AC compressor. I noticed a 10mpg drop when the AC is, working hard upon activation and the interior is much hotter thank your desired AC setting. I then tested the system when the interior temp wash closer to the desired setting and the hit was only 1 mpg.
  12. fed123
    fed123 Member
    120
    New Jersey
    2024 Prius Prime
    Whatever the science of it, if I open and and close the door that many times on a hot day, I've worked up my body heat so much as to cancel the effect of this scheme.
