How to determine if the water pump needs replacement?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NoviceMechanic, May 14, 2020.
  1. NoviceMechanic
    NoviceMechanic New Member
    UK
    Active
    I have a 2010 PRIUS T SPIRIT VVT-I CVT 3rd Generation. A few months ago I had a problem with cabin heating followed by indication of engine warming. When I got the car serviced at an authorized Toyota service centre they told me that there was a coolant leakage and they fixed it by loose pipe fitting. However, they also told me that the water pump needs replacement to resolve the engine heating issue.
    I didn't get the water pump replaced though. The coolant leakage has now stopped, however, I still get the engine heating symbol sporadically when I take a car for long drive.
    How can I determine if the water pump indeed needs changing as it is quite expensive to replace it?
  2. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    How many miles are on your car? Can you hear your pump running (from outside your car) when you turn on your heater-like a buzzing sound?
    If you can DIY, the job is easy, and the pump is around $235 from a dealer. The pump simply bolts onto the side of the engine. At ten years, if you plan to keep the car, a new pump is cheap insurance. Many owners have had pump failures.
  3. Peter123
    Peter123 Active Member
    132
    128
    The original equipment manufacturer is Aisin. Their part number is WPT190. There is a separate water pump for the power inverter, Aisin WQT001, and it is cheaper. You should be able to find something for £150 to £200. I do not know what a dealer charges for it in the UK.
  4. Mendel Leisk
    42,053
    I'd second this. I think runtime is what brings them to failure. What's the concensus, somewhere between 125~150K miles it should be replaced?
    Maybe a lot more in UK, just judging from past postings here. The Aisin pump below might be best bet for buyers outside the States:
    Genuine Toyota 161A0-39015 (161A039015) PUMP ASSY, ENGINE WATER - Amayama
    (View the photos with the Aisin pump, the box lists compatible vehicles/engines.)
    Or even in the States? Worth noting:
    1. Throw in a few extras (say wiper blades, air filters) and the shipping cost often doesn't budge, or just a small amount extra.
    2. Try to keep purchase from one country (either UAE or Japan) will ensure only one shipping charge.
    3. In my experience with small purchases, around $100 CDN max, there was no sales tax or duty.
    BruceInOKC and pjksr02 like this.
  5. NoviceMechanic
    UK
    Active
    I think I will take your advice and replace the pump anyways. Thank you.
  6. Mendel Leisk
    42,053
    @NoviceMechanic, just to clarify, since part of your response got encapsulated in the quote: your car has 91K miles, and you hear a whizzing sound when turning the car on.
  7. NoviceMechanic
    UK
    Active
    Yes, that is right.
  8. Mendel Leisk
    42,053
  9. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Is there a way to read the trouble codes:whistle:?
    Since the engine water pump is magnetically driven, troubleshooting it is tough:cool:.
    But I've done the replacement job 3 times and each time found the impeller to be restricted and in one case, rubbing against the internal housing:eek:.
    @The Critic had his water pump fail early on in his Gen3's life (around 130k IIRC), so it happens ;).
    Hope that helps(y).
    BruceInOKC likes this.
  10. Paul E. Highway
    Paul E. Highway Active Member
    209
    129
    Hawaii
    I replaced my 2010’s water pump at 156,888 miles as cheap insurance.
    pjksr02 and Raytheeagle like this.
