How to Diagnose the Car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Transtec24, Jun 18, 2017.
  1. Transtec24
    Transtec24 New Member
    southern Il
    I recently bought an 06 Prius with a bad engine. It sat for a month before I could work on it. When it was time to work on it I had to push it in. The ready light wouldnt come on. I changed the engine without removing the invertor or unhooking any thing on that side, I did however remove the safety plug from the Hybrid cell. I finished the engine swap & it wouldnt ready up so it would just go it neutral. I pushed the button on & off several times & it came on finally.I dont know how to diagnose this car
  2. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    Did you ensure you reinstalled the safety interlock switch correctly? (See diagram below.). For some reason a lot of people seem to miss locking the plug in step 3. It will also take two start/stop cycles to get the car into ready to drive state.
    In regard to diagnostics, you need to have a scan tool (and know how to interpret the DTC info) in order to ensure you don't end up doing the "replace and hope" technique repair.
    m.wynn likes this.
  3. dolj
    dolj Senior Member
    7,628
    3,849
    Well, that is all I got, and to be honest I did not really understand your post, so made some assumptions. You said you didn't know how to diagnose the car, but then you say you have a scan tool and fully know how to use it.
    #3 dolj, Jun 19, 2017
    m.wynn likes this.
  4. JC91006
    16,475
    8,393
    Sounds like you should test the 12v battery and make sure it's not dead.
  5. SusanS
    SusanS Junior Member
    I didn't know there was a switch. I will check on that.
  6. SusanS
    I did install brand new batteries in both fobs. The newer (but previously working) fob was still working but I installed a new battery anyway. The older (original, but working fob) was completely dead and so I had to replace that battery. But that was what made me wonder if the older/original fob had lost its ability to have the smart function because I had let that battery drain down too low. So the bottom line is they both have new batteries. Thanks for that idea.
  7. bisco
    49,376
    what is going on with this thread?:confused:
    jerrymildred likes this.
  8. Transtec24
    southern Il
    Sorry lol I figured out it was my fault because I wasnt pushing the brake pedal down before I pushed the button so the"READY" light wouldnt come on & it would go in neutral instead of Reverse or Drive !!! This is my 1st experience with a hybrid. I just dont know all about it yet but I will
  9. Transtec24
    southern Il
  10. SusanS
    I saw the switch. Is it supposed to be in or out to make the smart key work?
  11. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    This may be the strangest thread I've ever seen. Did a bunch of posts get deleted?
    m.wynn likes this.
  12. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    error----error===error!
    Looks like two topics are "shorted" together. ;)
    jerrymildred and m.wynn like this.
