How to disable LOCK at shift or speed?
Discussion in 'Gen 3 Prius Main Forum' started by PriusG3IV, Sep 3, 2010.
  1. PriusG3IV
    PriusG3IV New Member
    37
    Kentucky
    So - I've looked at the existing threads and see that there are essentially two methods each for locking/unlocking the doors in conjuction with 1)when the shift lever is moved and 2) when the vehicle passes a preset speed (18mph?).
    My question is how to disable the locks from functioning whether I shift the gear fob or reach a predetermined speed. I do NOT want the door locks to move at all once I get in a start the car.
    Have any of you had any success with this - and if so, can you please advise "how"?
    Thanks.
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    Get it programmed at the dealer?
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I had my dealer do it prior to delivery, along with disabling the seat belt chime, and switching the reverse chime to a single chime.
    The owner's manual had a chapter near the back with pages of setting your dealer can customize for you.
    Enjoy your new ride.
  4. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    I have mine set to lock on engaging gear. I consider it a safty function for both my wife and myself to prevent unwanted entry. But as mentioned the dealer can set it for you.
