how to disable the DCM/Telematics unit in the car
Discussion in 'Gen 5 Prius Technical Discussion' started by RandyPete, Mar 31, 2024.
  1. soft_r
    soft_r Active Member
    191
    160
    Beverly Hills
    2024 Prius
    You guys are still so weird for trying to dissuade people from disabling theirs. What does it matter to you? Seriously. Why do you care to try to talk anyone out of it? It doesn't hurt the car. It increases security and privacy by disabling it (and no one cares about your likely retort that we're all being tracked by our phones, we know, but with a simple pull of a fuse we can not be tracked by our car company and not lose a single feature that isn't already easily handled by the phone).
    Oh and who the hell would use the traffic information when we all have carplay and android auto and waze? Weird behavior. Weird reason to even keep the DCM powered up. Having the in-car microphone working is a more compelling reason than toyota traffic info. Only some weird NPC type person would be like "hey honey, let's not use waze, google maps, or apple maps, let's check the toyota traffic information system ".
    Also please read through the thread, I've posted many links to articles regarding issues with DCMs through car manufacturers. It's not an urban legend. Subaru even went as far as making a dongle to bridge connections to restore mic and speaker functionality in theirs after they had to do a recall for issues when 3G shut down. The DCM is a massive liability in all regards. It's a security liability, it's a privacy liability, and it's a reliability liability. And you add these liabilities for what? Toyota traffic info and an SOS button? lol gtfo
    Trollbait likes this.
  2. Gokhan
    Gokhan Senior Member
    6,616
    2,627
    Paramount CA
    LOL I am not trying to persuade you to do or not do anything. Do or not do whatever you want. I am telling you that I am not disabling my DCM for the reasons I explained.
    Lantaral likes this.
  3. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Pull which fuse ?
  4. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    Priipriii suggests trying # 16. If you do, let us know if it works.
  5. Salfed
    Salfed New Member
    2022 Prius Prime
    Greetings, my friend. I see you're on the right path. I chose to unsolder the esim from the module. The data grab definitely occurs even without antennas/battery connected to the module, saw it with my eyes. Microphone and speaker works in my case. I also get traffic data even though I'm not sure where it gets that. But removing the sim disabled the sos button and toyota app connectivity.
  6. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    How did you do that ?
  7. Salfed
    Salfed New Member
    2022 Prius Prime
    So basically what I did is disassembled the transceiver/telematics block, so that you only have the
    microboard circuit part of it. Then opened up the Kyocera Corporation's modem and removed the chip for eSim receival by Verizon. You have a different Prius. If you'd shown the telematics block to me, I would try give a look.
    RandyPete likes this.
  8. Blackat
    Blackat Active Member
    483
    353
    Colorado
    2023 Prius
    Limited AWD-e
    Seems like a lot of work to go thru
  9. Salfed
    Salfed New Member
    2022 Prius Prime
    Is it? The hardest part is to move the screen out of the way. If you don’t have the soldering station you can delegate the process to someone else for like 20 bucks
  10. Dale Coba
    Dale Coba New Member
    2024 Prius Prime
    SE
    While removing the DCM SIM should stop data transmission, it would still permit the logging of the data to the DCM's onboard memory, which can later be downloaded. While removing the SIM retains the cabin microphone and speaker function, it's both non-reversible and insufficient for my purposes.
    Pulling the 5A fuse indicated in the attached diagram and waiting for the DCM internal battery to discharge *appears* to disable the DCM. All DCM features are disabled, including the SOS button. Everything I use continues to work as advertised, with the sole exception of the interior cabin microphone. You know when the DCM internal battery has discharged, because the cabin mic stops working.
    However, because I never activated any of the data functions, installed the Toyota app, or agreed to any of the Toyota data terms, I have no way of determining if, with this fuse pulled, all functions of the DCM are truly disabled or that all transmissions have stopped. On the other hand, the car is not displaying any error messages. Yes, I know the TPMS modules also transmit, but I'm not concerned about tracking, only vehicle data.
    The only way to be sure the DCM is fully nonfunctional, and no part of it is still being powered by another circuit, would be to fully unplug all DCM connectors. If the DCM is fully unplugged, it's well reported that, in addition to the cabin mic needing power, there are a couple speaker wires which need to be jumpered with two short lengths of #22 solid core wire.
    1) Is anyone willing and able to send me the disassembly instructions to non-destructively get to and unplug or remove the DCM on the Gen5 Prius?
    2) Rumor has it from other Toyota owner forums that the mic only needs a 5v supply to function without the DCM. Has any Gen5 Prius owner succeeded in restoring the cabin mic after disabling the DCM? If so how? Does anyone have the cabin wiring diagrams for the Gen5 Prius or Prius Prime?
  11. Bill Norton
    Bill Norton Senior Member
    2,220
    746
    MONW, Ks.
    2019 Prius
    L Eco
    You flatter yourself thinking anyone in Japan, (or wherever it is that this 'tracking data' is sent to), is "Following you"...:sneaky:
    Who exactly cares what grocery store or gas station you go to? How is it possibly a "Massive Liability"?
    I'll tell you who cares what grocery store or gas station you got to. Google. But you seem fine with that and "Don't care".
    I guess it's harmless to have this level of paranoia directed at your stupid car. It could be worse...:whistle: Carry on!!(y)
    vvillovv and Gokhan like this.
  12. Gokhan
    6,616
    2,627
    Paramount CA
    Not to mention that you are unkindly mutilating the car for the next owner (this is exactly why I don’t buy used cars anymore) and telematics will be a legal requirement soon as the cars will have speed-limit-exceed warnings.
    Bill Norton likes this.
  13. bionicbadger
    bionicbadger Junior Member
    Alberta
    That will be for new cars only after a specific date and won't affect used/old cars
  14. cool_prius
    cool_prius Member
    106
    38
    United States
    2025 Prius
    Reading through this thread is tiring. Interesting and informative, but tiring. Can we please stay on topic and not continue this "Who do you need to hide from?" type of argument that never gets anywhere? Might as well be a Linux vs Windows, Console vs PC, or Android vs iPhone debate. Every choice is valid because everybody is dealing with their own set of circumstances.
    For instance, my interest in privacy isn't isolated, it stems from my interest in tech and modularity. I like turning things off that I don't use. I like tinkering and modding. I also just like knowing how stuff works and what does what.
    Anyway, it seems reaching the DCM module requires taking apart the dashboard. How much taking apart are we talking here?
  15. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    It ain't just goo gool - barney and all it's ai brothers in the compute spaces have agents to crawl it and share it with their other agents.
    Maybe some might remember one or two of the backoffice nicks from the 90s or one of the declassified big boy programs that's not up and running these days
    List of government mass surveillance projects - Wikipedia
    Yeah, who cares ? besides it's still snowin out.
  16. cool_prius
    cool_prius Member
    106
    38
    United States
    2025 Prius
    Found this from the service manual. Steps to remove DCM module. Seems like a chore with a lot of opportunity to end up with a rattling dashboard if not done right. I think I'll pass and just remove the fuse. I wouldn't be giving up the microphone because I don't use voice controls ever.
    upload_2025-3-6_11-38-3.png upload_2025-3-6_11-42-17.png upload_2025-3-6_11-44-0.png
    #56 cool_prius, Mar 6, 2025
    soft_r likes this.
  17. Hammersmith
    Hammersmith Senior Member
    2,370
    2,420
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If you want to have fun, there's another box a little below the DCM that's mounted to the floor. Just unbolt it and flip it upside down while it's still plugged in and the battery's still connected. I guarantee you'll have an exciting day(and probably need a change of pants afterwards).
    If you watch Mat Armstrong, he tried it in a Range Rover he was working on a month or two ago. lol
    vvillovv likes this.
  18. vvillovv
    4,336
    1,517
    NY
    Who said - if it doesn't suck it blows - don't ask me where the punctuation mark(s) belong ....
    what a day ?
  19. kenmce
    1,552
    525
    NY
    Yaw sensor?
  20. Hammersmith
    2,370
    2,420
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yep. lol
    Mat even mentioned a yaw sensor was probably inside the box earlier in his video. And he still unbolted it and moved it around while everything was plugged in. :rolleyes:
    Scared the heck out of everyone(especially his cameraman who had his head in the door at the time), and their ears were ringing for awhile afterward. The only positive was that he hadn't reinstalled the trim yet so the curtain airbags were easy to replace. Still, it was a few hundred pounds he hadn't planned on spending.
