How to disconnect battery 2017 prius
Discussion in 'Newbie Forum' started by bill rowe, Jan 17, 2017.
  1. bisco
    52,902
    sounds painful.
  2. Prodigyplace
    12,720
    11,852
    Central Virginia
    @Mendel Leisk should know. He was the one that "crossed the streams" on his battery.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Is there power available in this garage ?
    If so, connecting a battery tender type smart charger would be a MUCH better option.......for several reasons.
    Then......as mentioned, it is not "necessary" to disconnect the battery at all but it would be good to make sure it is fully charged.
    The cold will NOT do it any damage as long as the charge stays high enough.
  4. bill rowe
    bill rowe Junior Member
    ottawa, canada
    Technology
    I have power but not a smart charger. I will just activate my regular charger for 1/2 hour a week. i'm sure it will be fine.
  5. Mendel Leisk
    42,377
    Procuring a 3~4 amp smart charger would be: smart. Will charge it right, can be left in indefinitely.
    RCO likes this.
  6. Sam Spade
    2,036
    1,024
    2017 Prius c
    Most tender type smart chargers are rated at 2 amps or a bit less.
    If you are going to go to that much trouble, leave it connected for 3-4 hours just to be sure.
    RCO likes this.
  7. bisco
    52,902
    do we have official charging rates on the new gen 4 12 volt?
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    You mean something on the battery label?
  9. bisco
    52,902
    no, toyota will having charging specs. maybe owners or device manual.
  10. Mendel Leisk
    42,377
    Looks to be a little more than 3rd gen. It is a physically bigger battery:
    (page 732, at least in my pdf)
    I've got a couple of older CTEK's, the 3300 and 4.3, they're 3.3 and 4.3 amps respectively, IIRC. Looking at their current North American page I see a spread of 3.8, 5.0 and 7.0. All of these can be left on indefinitely. They go through a charge session, then trickle charge.
    www.ctek.com
    #50 Mendel Leisk, Jan 23, 2017
    RCO, Prodigyplace and bisco like this.
  11. Prodigyplace
    12,720
    11,852
    Central Virginia
    RCO likes this.
  12. Prodigyplace
    12,720
    11,852
    Central Virginia
    :LOL: You beat me to it. :D
    Mendel Leisk and bisco like this.
  13. Sam Spade
    2,036
    1,024
    2017 Prius c
    You can't always believe what you read........regardless of where it comes from.
    "11.0 to 12.4" indicating "half charged" is just ridiculous.
  14. bisco
    52,902
    i disagree. but there is more to battery health than voltage.
    that being said, when mine gets to 12.4, i'll be replacing it. 7 or 8 years is a more than reasonable 12v life.
    #54 bisco, Jan 23, 2017
    RCO likes this.
  15. Prodigyplace
    12,720
    11,852
    Central Virginia
    Apparently, so does Toyota.
    RCO likes this.
  16. Mendel Leisk
    42,377
    I do not know, if you're reading 11.0 for example, I would think you're deep doodoo. This graph:
    From this site:
    The 12volt Side of Life (Part 1)
    is an old standby.
    RCO likes this.
  17. Sam Spade
    2,036
    1,024
    2017 Prius c
    You disagree with what, exactly ?? And why ???
    See attached chart.
    (Well guess not. It won't let me attach an XLS file)
  18. bisco
    52,902
    sorry, please see my edit. i don't know if these generic charts apply to the toyota battery. for instance, a new fully charged gen 3 battery is 13+ volts.
  19. Mendel Leisk
    42,377
    It will allow .xlsx, if you can do a save-as. Older versions of excel won't do that though. Are you windows, 7.0 or later? Try snipping tool, just start typing it in start menu field, it'll find it. You can take screen shot of your spreadsheet, and it's automatically in clipboard, <ctrl> V will paste it, in the advanced prius chat editor. Just position cursor where you want it.
    Like this:
    RCO likes this.
  20. Prodigyplace
    12,720
    11,852
    Central Virginia
    Also, some things work on initial posting, but not when editing a post. I cannot edit to add an image, for instance.
    #60 Prodigyplace, Jan 23, 2017
