How to display "miles remaining"
Discussion in 'Gen 2 Prius Main Forum' started by monsieurpooh, Apr 15, 2012.
  1. monsieurpooh
    monsieurpooh Junior Member
    ca
    In the second generation prius, how do I get it to display the miles remaining based on the current fuel and mpg, or is that only on 3rd gen?
    Thanks in advance
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Yes, Gen 3 and newer. (and they all disagree with it)
    Skibob, danboy and monsieurpooh like this.
  3. dianeinreno
    dianeinreno Member
    104
    17
    Denver,CO
    To my knowledge you cannot display a "miles remaining" figure on the trip computer in Gen II
    WilDavis and monsieurpooh like this.
  4. Tideland Prius
    16,681
    There isn't a DTE readout in the 2nd Gen Prius.
  5. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Uggg, that's a bummer. Was sure there had to be one. I hope there's a low fuel light that comes on before the last dot on the gas guage oes away?
  6. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    The last bar starts flashing (supposedly with a dozen or two miles, maybe?)
    SDB54 likes this.
  7. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Check the owners manual and you will see the low fuel light. Most Prius owners don’t wait that long though. The gas gauge is more of a suggestion than a solid indicator.
    SDB54 likes this.
  8. dolj
    dolj Senior Member
    8,652
    4,401
    Wellington, New Zealand
    On the Gen 2, the low fuel warning is signalled by an audible beep, the message "Low Fuel" on the MFD (appears briefly) and the last pip on the fuel gauge starts flashing. I reset trip B to zero when I hear the beep and use that as a DTE of sorts. You can go whatever your current MPG is x 1.2 (so, if 44 MPG, you can go 52.8 more miles).
    The low fuel message will appear on the MDF briefly at start up until you refuel.
    A big caveat to US owners, because of the flexible fuel bladder, YMMV. Because of the fuel bladder, they usually never get to experience the low fuel warning. Instead they opt to fill when the gauge is down to the 3rd or 2nd pip.
    #8 dolj, Sep 5, 2019
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Do not run out of fuel especially in a 2005 your wallet will really regret it. That could be one very expensive day.
    Skibob likes this.
  10. Mendel Leisk
    42,355
    Why not just fill up when there's at least a couple of dots still showing on the gas gauge? Why play Russian Roulette with a little bit of gas sloshing around in the bottom of the tank, LOL?
    SDB54 and Skibob like this.
  11. fuzzy1
    10,713
    While I don't actually have a Gen2, I thought its gauge was the same as a Gen3: that last dot never goes away, even after you are out of fuel. But that dot does blink (continuously) and beep (once) as a low fuel warning.
    Beware that a certain small fraction of U.S. Gen2 owners, with that problematic fuel bladder, have had their cars run out of fuel before that blinking and beep warning was reached.
