How to enable reverse beeping
Discussion in 'Gen 5 Prius Main Forum' started by james1999, Jun 12, 2026.
  1. james1999
    james1999 New Member
    Massachusetts
    2026 Prius
    XLE AWD-e
    I purchased the 2026 Toyota Prius XLE AWd. The reverse beeping sound was not enabled. Gemini stated the dealer does not need the reenable the feature. I was unable to find the menu to turn the feature on. Can anyone help with directions?
  2. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Once you find out...
    please post the instructions here
    to save us the trouble.
    Thanks.
  3. Hammersmith
    Hammersmith Senior Member
    2,482
    2,542
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm only 97% certain, but I believe the reverse beeping is one of the options that you either need a dealership or one of the scan tools to do. Like Carista or Carly. I don't think it's accessible through any of the normal menus.
    edit: Yep, it's a dealer option(it's listed that way in the customization section of the owner's manual). Some of the third party scanners can do it, but confirm it with the maker of the scanner first before buying any.
  4. Dany Dan
    Dany Dan Member
    58
    38
    Québec, Canada
    2024 Prius Prime
    SE
    To activate the reversing warning, you must go to the dealership or obtain a bidirectional OBD2 scanner which allows customization (coding).
    Most OBD2 scanners do not allow it, even if it is bidirectional.
    The Carista software does not allow this adjustment either.
    The least expensive scanner is the Launch Creader Elite for Toyota which allows all customization adjustments.
    BiomedO1 likes this.
  5. Hammersmith
    2,482
    2,542
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I believe the old Dr Prius app could do it on the 3rd gen. Don't know if it still does it or if it works on a gen5. (I haven't used the app since I got my new Prius.)
    I believe the app is free(either that or I bought it a loooong time ago). It's a little finicky with which OBD2 adapters it works with, but you can still get the bluetooth Panlong adapter on Amazon for under $15. I keep that one in the car in case I need to read a trouble code out on the road. (I have a muuuuch more expensive Mongoose that I use with my laptop for serious work.)
    edit: The android-only Panlong is $13. The android/iOS one is $26.
    #5 Hammersmith, Jun 12, 2026
  6. Mendel Leisk
    42,330
    Crude, but would momentary detachment of the 12 volt battery return it to defaults? Maybe nix other stuff though.
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,077
    6,937
    Texas Hill Country
    Newer cars have non volatile memory for settings.
  8. BiomedO1
    BiomedO1 Senior Member
    4,576
    2,404
    Left Coast
    Just a note and clarification - the reverse beep is an internal cabin alarm ONLY - NOT an external commercial large truck reverse alarm.
    FWIW: I was able to adjust my gen4 reverse alarm with the free version of Dr Prius.
