How to find "passcode" on iphone 12?
Discussion in 'Gen 3 Prius Technical Discussion' started by Seymour1, Sep 7, 2025.
  1. Seymour1
    Seymour1 Member
    272
    36
    I am unable to find the "passcode" on my iphone. The setup instruction in the manual tells me to enter the passcode into my cell phone. My bluetooth is turned on on the iphone. I am unable to find out how to turn on the "passcode" of 1212.
    If I dial the number on my cell phone, it will connect O.K. to my car. I want my "contacts" to be entered into my NAV/phone memory.
  2. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    The number you use to unlock your phone, that is the passcode.
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Another one for the archive
  4. ETC(SS)
    7,555
  5. ChapmanF
    19,020
    I suspect there was some context left out of the original post, and the poster is trying to pair the phone via Bluetooth to the car.
    Bluetooth pairing often involves an authentication step where one of the devices will generate a few-digit code and display it, and you're supposed to enter that code on the other device, to confirm those are the devices you wanted to pair.
    Maybe the OP should give more detail on the steps being followed. What's on the car display at what step, and what's on the iPhone display at what step.
  6. Seymour1
    Seymour1 Member
    272
    36
    The Prius manual tells me to enter "1212" into my phone. My problem is that I cannot find the place to enter "1212". I have gone into settings and searched. In "passwords" menu, I see a "passkey" set to "0". It was never set. I will enter a code and see what happens. My phone uses face recognition to open. I cannot see how to enter a passkey on my phone. I am 82 and stay confused. I will go to Verizon for help.
  7. ASRDogman
    8,066
    4,086
    Okay, when you "pair" it, the radio will ask you to enter a passcode, or key.
    They it does whatever it does to communicate with the phone, then a display should open
    so you can put the passcode/key that you entered on the phone....
    I am 98, and try to stay away from confusion. :rolleyes::barefoot:(y):whistle:
  8. Mendel Leisk
    42,345
    C'mon, who can remember all these terms.
    The Password Game
