How to get Entune working
Discussion in 'Gen 3 Prius Audio and Electronics' started by runnyeggs, Aug 4, 2017.
  1. runnyeggs
    runnyeggs Junior Member
    NV
    It's been 2 weeks and I still cant get entune to work. I am using Entune and not Entune 3.0. It seems the software in my car is updated to the correct version. I have a iphone 4s. Bluetooth works fine streaming from my music as well as making calls. I just cannot get Entune to connect. It looks like all you need is bluetooth to be paired for it to work but I must be missing something here.
  2. Codemonkey812
    Codemonkey812 Junior Member
    22
    Kent, Ohio
    The standard Entune setup with an iPhone requires you to use the USB cable. There is an advanced setup that allows you to use DUN via Bluetooth but it depends on your level of tech and what cell phone provider you have. If you have T-Mobile I can send you the steps.
  3. obanster
    obanster New Member
    Bay Area
    Codemonkey812 - Can you send me the steps to update? Im on an iphone 7 Plus, T-Mobile and have a 2012 Prius 5 with Tech Package. (7in. Screen). Thanks! You Rock!
  4. Codemonkey812
    22
    Kent, Ohio
    Sorry for the delay. Here is the how I have my radio/Entune setup, these sets will only work if you have T-Mobile as your cell phone provider.
    1. Turn on the mobile/personal hotspot on your phone.
    2. Go into Setup on your radio.
    3. Select Bluetooth
    4. Select Paired Device List
    5. Select your phone (assuming your phone is paired with your radio)
    7. Select DUN/PAN Connections. IMG_0452.JPG
    10. Go back to the prior menu, and select Entune Account
    11. Enter your Entune account information.
    12. Go back to the prior menu, and check the "Enable DUN/PAN Connections"
    That should be it. You need to make sure your mobile personal hotspot is enabled before you try to connect to any Entune apps (I just leave mine running all the time so I do not forget).
Loading...
