How to improve fuel efficiency?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Lisa C, Aug 31, 2019.
  1. Mendel Leisk
    42,271
    Wait a sec, are you saying the dash display of mpg regularly underestimates? I think I'm just confused; it's practically part of the Toyota Mission Statement...
    fuzzy1 and Prodigyplace like this.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    EVERY vehicle I've ever owned that had an onboard fuel mileage display has always been around 6% on the high side.
    Maybe 10 of them.
  3. Prodigyplace
    12,710
    11,848
    Central Virginia
    I measured mine once at 10% high
  4. fuzzy1
    10,687
    Yes, those numbers are estimates, which don't well match most people's real world driving.
    But because those numbers are the measured output of a very well defined test set, you can also legitimately call them "ratings". Even the EPA itself does:
    It has a better city rating (or estimate, or score) than highway rating. But as I've described before, that is an artifact of the artificial test scale that derates (discounts with a somewhat arbitrary fudge factor) the highway test results more than the city results. Real world results still vary, and a fair number of drivers won't see that city inversion.
    #24 fuzzy1, Sep 2, 2019
  5. Mendel Leisk
    42,271
    Our previous 06 Civic Hybrid was the first car for us to have mpg display. It was either spot-on, or very slightly on the pessimistic side. As an example, if the display said 5.0 liters per 100 km, my calc would be 5.0 or sometimes 4.9 (lower number better).
  6. Mendel Leisk
    42,271
    Yeah my calc's dance around, highighted one a bit of an anomaly:
    Average is 7.0~7.5%
  7. Gas Mizer
    Gas Mizer Member
    153
    50
    Redding, California
    2018 Prius
    I'm not sure how you can calculate mpg more accurately than the computer unless you know PRECISELY the level you're filling your tank to.
  8. Mendel Leisk
    42,271
    Well, the car's computer does calculate quite accurately I think, and then, before displaying it, adds a fudge factor, likely around 7.5% for third gen.
    It's quite easy to get accurate calculated fuel economy. First off, always fill the same way. I would suggest to fill till it shuts off, and stop. This does a couple of things: it's relatively uniform, and prevents the various bad things that can happen from filling to the neck.
    Then consider: if you calculate one tank, sure there could be a little discrepancy, due to when the pump shut off. If it shut off a little early, your mpg goes up, and the converse if it shut off a little later.
    Say it shut off a little early. Next tank, it'll take a little more gas to fill, and it will balance out.
    So with even just two fillups, the fill error more-or-less cancels out.
    A long of string of calculated fill ups. It's pretty much DEADLY. And if you keep a running total, all the miles and all the gas, it's bullet-proof.
    Prodigyplace likes this.
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    Long term, just normal filling can give you a very accurate number.
    The onboard computer is really not that sophisticated either.
    That is, it doesn't have a very accurate way to precisely measure the fuel used.
  10. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Don't blame TOYOTA only - they're all the same. KIA was about 7% optimistic, both FORDS about 5 or 6%, PRIUS about 5%.
    It's never going to be accurate anyway. It's reading from a plethora of sensors which are really there for other purposes, and providing you an approximate calculation. PLUS - it displays it in about 9 different formats!!
    The Owner's Manual clearly says (about DTE) "... is computed based on your average fuel consumption. As a result, the actual distance that can be driven may differ from that displayed." SUBARU says almost the same. FORD says "... approximate distance the vehicle will travel on the fuel remaining in the tank. Changes in driving pattern may cause the value to vary"
    Data Daedalus likes this.
  11. fuzzy1
    10,687
    My current Subaru, a '14 Forester, is also nearly spot on after adjusting for the built-in odometer error.
    Unadjusted, it appears to read a couple percent high. But the odometer itself (not the speedometer) is biased 1.8% low, apparently a reaction to that class-action warranty fraud case alleging defective (over-reading) odometers. Several manufacturers were hit with similar suits.
    Applying that adjustment factor leaves a residual MPG error well under 1%, closer than I've cared to calibrate.
  12. Lisa C
    Lisa C New Member
    North Carolina
    Prodigy place, I was using ECO mode.
  13. Tideland Prius
    16,671
    Our Gen 2 was spot on. Our Gen 3 was optimistic by 5-10%.
    The EPA needs to start testing with E10 fuel. They’re still using E0 and that’s what the manufacturers submit. E10 knocks off 2-5% so at least if they test with E10, their numbers will be closer.
    That said, the Gen 4 is regularly beating the EPA numbers in the summer so even if it’s overestimating it, it’s still better than the city mileage. Driving out to the suburbs can net 3.9L/100km (60mpg) (with the best at 3.6L/100km (65mpg). Stop and go, it’s closer to 4.2L/100km (56mpg).
    The Prime is a whole ‘nother beast. It can run high 60s all summer (I got 3.4L/100 or 69 mpg running in HV mode across the Cascades... round trip)
  14. Prodigyplace
    12,710
    11,848
    Central Virginia
    Most of us ignore DTE. There is a reason @jerrymildred calls it the guess-o-meter. We have been referring to the dashboard economy readings. For you it would be l/100km.
    #34 Prodigyplace, Sep 3, 2019
    jerrymildred and alanclarkeau like this.
  15. alanclarkeau
    7,045
    7,593
    I haven't found that. Other cars I've owned (I've got records of every fill since 1975) used 3-6% more with E10. PRIUS is the only car I've owned which has negligible - ie impossible to categorically calculate. When I first got her, I filled her with 91 for 3 fills, then 98/95, then E10 - and almost no difference, not enough to swear that one was better - maybe about 1% better with 98.
    I put it down to several factors, the most likely being that it drives 30-40% in EV mode which doesn't care if it's got E10 or 99 in the tank.
  16. Jon Watkins
    Jon Watkins Active Member
    131
    115
    Bluffton SC
    2024 Prius
    My dash display mpg is always off by appx 6 - 8%. That’s why I use fuelly to track my actual mileage.
  17. Gas Mizer
    Gas Mizer Member
    153
    50
    Redding, California
    2018 Prius
    Wait. You're telling me the computer that allocates fuel in millisecond pulses with a constant gallon/minute fuel pump is less accurate than going to pumps that shut off with pressure, which could vary with temperature and use? I find that hard to believe.
  18. Mendel Leisk
    42,271
    @Gas Mizer, regarding your skepticism of the accuracy of calculated:
    I get the impression you picture multiple tank calc's like a novice potter, working with clay on a spinning wheel. The clay is prone to get off-center, develop a wobble, and fly completely off.
    Think of it more like a pendulum, that someone's perhaps given a little nudge. Over time it settles down, it's inherently stable.
    If you fill by the stop-at-first-shut-off method, record your gas pumped, note the odometer reading, you'll be very close, and any "zig" on an individual tank is more-or-less cancelled out by a "zag" on the next.
    Accumulated calculations, for multiple tanks, are virtually 100% accurate.
    The only fly in the ointment: someone borrows the car, puts $10 in, stuff like that, lol. Even that you can bounce back from, as long as they kept the receipt, know how much was pumped in. You can lump it in with the next tank.
    A good tactic: use the Odometer to calculate the distance travelled, not the trip meter. Or use the trip meter too, but just for feedback, and as a cross-check.
    #38 Mendel Leisk, Sep 3, 2019
  19. fuzzy1
    10,687
    Retail fuel pump meter accuracy is regulated by most states' consumer protection laws. Car MPG display accuracies are not regulated by any law, so most of the manufacturers have not chosen to make them accurate, even if they could. The result is many MPG displays being wrong by much more than is legally allowed for fuel pump meters, and car manufacturers not wanting to be taking on the competitive disadvantage of displays being accurate instead of biased high.
    Meter shutoff-point is not regulated, but we can work around that by keeping a running fuel log of many consecutive tanks, or even the full life of the vehicle. The error ratio term shrinks as total fuel purchased and total miles driven get ever larger over many tanks.
    #39 fuzzy1, Sep 3, 2019
  20. sam spade 2
    7,035
    2,804
    2017 Prius c
    That does not, however, somehow make it not true.
    AND.....the shutoff point for the pump has no bearing on the accuracy of the readout of how much was delivered.
