How to install (precrimped?) cotter pin?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SB6, Nov 30, 2019.
  1. SB6
    SB6 Member
    324
    71
    I installed a new ACDELCO lower control arm and ball joint, and they came with a new cotter pin. However, the pin looks precrimped, not like the straight/noncrimped pins in the installation videos I've seen.
    I found a Wikipedia page titled R-clip, however, the picture seems a bit different than mine. What's the proper way to install these?
  2. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The pin will be inserted thru the stud and the bends on the clip will sit within one of the notches on the castle nut.
    iPhone ? Pro
    Raytheeagle and SB6 like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I can't imagine what you mean by "precrimped." If the arm is held on with a castle nut, it should have a regular straight cotter pin that goes through the opposing slots in the castle nut and the open end gets bent.
    If it's a spring clip, that would not be the right kind for a castle nut.
    Ed Beaty likes this.
  4. SB6
    SB6 Member
    324
    71
    Here's a picture showing the pin in question. I think these are called R-pins
  5. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Why didn't you take a picture of it and post it here?
    jerrymildred likes this.
  6. jerrymildred
    11,517
    14,167
    Tampa, FL
    +1! @ASRDogman
    I have never seen anything like what's in the link you provided, @SB6. This is an R-clip/R-pin/hitch-pin/spring cotter-pin/ad nauseum.
  7. ASRDogman
    8,067
    4,089
    A "Jesus" clip! :)
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    It's just a custom, re-usable spring type and installs just like any other style cotter pin. Straight portion goes through the hole. Shaped portion locks into the outer edges of the nut...……..
    If you're not comfortable with it, just use a normal, classic style pin.
  9. spiralhelix
    spiralhelix Active Member
    255
    220
    Illinois
    When I installed that shaped pin, I inserted it with the bends towards the end of the bolt, then when all the way in I rotated it so the bend at the end went in the empty space of the parapet. I used a small pick to help give me the clearance.
    -Spiral
  10. SB6
    SB6 Member
    324
    71
    I posted a link to a picture in both of my previous posts in this thread
    I ended up installing it by inserting the straight end through the stud with the bent end above the stud. Then rotated it so the bent end went into an open slot of the parapet. Then I sort of hammered the bent end in to tighten the pin. Idk if that was the correct way to go about it, but it seems to have worked lol.
    Do I need to bend the straight end? I just saw that my current tie rod also has one of these pins, and the straight edge isn't bent
  11. The Critic
    3,193
    2,333
    CA
    Honda used that style of cotter pin on their vehicles during the 2000's.
    Raytheeagle likes this.
  12. ASRDogman
    8,067
    4,089
    I "think" the hook part hooks around the bolt so I think so it doesn't need to be bent.
  13. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    Yes, nothing needs to bend permanently there. I recently dealt with those on my 2011 Honda Odyssey. The straight part goes through the hole, and you can grab the outer, not-straight part and pull it so it fits around the bolt and snaps back in place. It bends elastically and comes back to its beginning shape.
