How To Install the VAIS AIC-100i iPod Adapter
Discussion in 'Knowledge Base Articles Discussion' started by hybrideyes, Nov 5, 2005.
  1. hybrideyes
    hybrideyes New Member
    123
    My earlier post was lost during a PriusChat crash, so I'll come back later and try to remember what else I said here before. At any rate, below is my installation guide for the VAIS AIC-100i iPod adapter.
    [File replaced on 12-23-06 because it seems to have disappeared before. Download count was 1,274.]
  2. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    Thanks again, hybrideyes, for putting this together, and posting it. It is invaluable to anyone who purchased one of these units.
    I installed the VAIS AIC-100i thanks to this guide, folks. That means that if you have a trained monkey in the household, he or she can do it as well!
  3. tideland_raj
    tideland_raj New Member
    108
    Sunnyvale, CA
    One of the best installation manuals ever. Nicely summarizes all the tips and tricks that you and the community have collected in a beautiful and funny pdf :)
  4. jimofdg
    jimofdg New Member
    533
    DG, IL, US
    It worked perfectly for me. Ordered in the 2nd group buy from Eugene on Nov. 9 and installed on the 18th. The box fits in the slot where I had been keeping the manuals for the Prius.
    If your iPod is white (very likely), you may notice black lint on it from the lining of the glove compartment. I vacuumed it before installing, but some powder remains. I mention it in case you want to really wipe out that compartment while you have it detached.
    Also, I did this installation after Toyota did their ECM reprogramming (SSC 50P)and the Nav DVD update. The 50P letter came the same day as the AIC-100i, so great timing there.
    Hi to all. I've been busy with lots more to do at work, and little time to read PriusChat. Hope the new calendar goes well. (I haven't read the recent posts yet.)
  5. sariantekara
    sariantekara New Member
    hello all *slams head into desk in frustration*ok now that i have the spas out of my sytem ive searched every where i can to find info about using the avic 100i in a 2001 prius and so far it seems as if us classic prius drivers are out of luck any clue ??
  6. DanMan32
    DanMan32 Senior Member
    3,799
    23
    Tampa Bay, FL
    Since the changer port is available on the classic, there is a good chance it will work on a classic, but no guarantees.
  7. Color Theory
    Color Theory New Member
    17
    Has anyone tried this on a 2006?
  8. duffetta
    duffetta New Member
    Boston, MA
    Can you explain the significance of this comment? Is there some issue with the installation of the 100i before the ECM reprogramming? I was about do to the installation myself in the next week or so, but I haven't had the SSC 50P work done as yet.
    Thanks,
    Mark
    P.S. Although I haven't done the installation yet, the quality of this installation manual has convinced me to do it myself instead of paying someone a bunch of money. Thank you!
  9. jimofdg
    jimofdg New Member
    533
    DG, IL, US
    No, I just didn't want the Toyota person doing my ECM reprogramming to look around at my modification, harmless though it was.
    I was a little concerned that I wouldn't put things back together right after installing the AIC-100i. There was no problem. I never had to use anything but my hands on the air vent, on or off. Prius looks like new.
    And of course I didn't want a Toyota tech to accidentally damage the iPod interface while working on what they were supposed to be doing. Again, needless worrying.
  10. duffetta
    duffetta New Member
    Boston, MA
    I did the installation into my '04 this afternoon. Went great. The instructions as provided by hybrideyes worked perfectly. Thank you hybrideyes!
    My unit from Vais is the SoundLinQ Model SLI. While I haven't see the Vais installation manual for the AIC-100i, it appears that there is a difference between the two units. My SLI has 2 switches that program the serial device communication speed between the unit and the iPod. 3G iPods use a slower speed than newer iPods. There are instructions Vais manual for changing the speed on the unit (which I am happy to provide to hybrideyes if he wants to update the manual).
    Can't wait to go back to work in January so that I can drive to and from work and not have to listen to that dribble on the Boston airwaves!
    Now, off to work on my playlists . . .
    Thanks,
    Mark
  11. shawn7
    shawn7 New Member
    55
    Beaufort South Carolina
    This will NOT work on the ipod Shuffle.. Right?
    Thanks,
    Shawn
  12. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    That is correct. The shuffle does not work with the VAIS unit.
  13. Cox
    Cox New Member
    38
    The link to the install pdf does not work - help!!
    Please...
  14. aaf709
    3,841
    <div class='quotetop'>QUOTE(Cox @ Nov 21 2006, 03:52 PM) [snapback]352780[/snapback]</div>
    Try http://priuschat.com/index.php?act=Attach&...ost&id=5354 I used it to install my DICE, it's a great installation instruction.
    EDIT: 2,800 post! (I know, big woop)
  15. Cox
    Cox New Member
    38
    Perfect! Thanks!!
  16. hybrideyes
    123
    <div class='quotetop'>QUOTE(Cox @ Nov 21 2006, 07:52 PM) [snapback]352780[/snapback]</div>
    This board has always been squirrely. I replaced the file at the top of this post, so it should work again now.
  17. jcohen919190
    jcohen919190 New Member
    Oakland, CA
    <div class='quotetop'>QUOTE(hybrideyes @ Nov 5 2005, 05:41 PM) [snapback]151275[/snapback]</div>
    Any way to get the video iPod to output its video there as well? Does VAIS make such a device? Thanks.
  18. Lutzbone
    Lutzbone I play the trombone
    17
    Grand Rapids, Michigan
    Hybrideyes, just wanted to say that your guide ROCKS! Just used it to install my DICE iPod adapter (purchased from the PriusChat shop) in my 2004 Prius with Nav. Took me about 20 minutes. YOU ARE THE MAN. (or woman, as the case may be) B)
    Lutzbone
  19. willc73
    willc73 New Member
    None of the links seem to work for me.
  20. Chris Nikirk
    Chris Nikirk New Member
    Phoenix, AZ
    Count me in on the group that used your guide to install. Worked right out of the box . . . I've got text display and all the steering wheel controls work, plus I can still use every iPod control from the iPod. Even better than I expected!
Loading...
