How to make The Prius Plug-in (Prime) actually worth it
Discussion in 'Gen 5 Prius Main Forum' started by Driver1, Jun 4, 2026.
  1. Driver1
    Driver1 New Member
    Georgia
    2026 Prius Plug-in
    XSE Premium
    Engine thrash at low speed is ridiculous and this is how to actually solve it.
    A Firmware-Only NVH Calibration for the 5th Gen Prius Prime
    The Core Concept
    The 5th-generation Prius Prime carries a 13.6 kWh plug-in battery and a 2.0L Atkinson engine that is among the most thermally efficient gasoline engines in production. Today the car uses that hardware only to chase fuel economy. Stealth Comfort Mode re-calibrates the existing architecture to chase something the vehicle has never offered: luxury-class silence.
    By using the plug-in battery as an active macro-buffer, the power management ECU decouples engine speed from the driver's foot. Instead of the familiar hybrid drone that rises and falls with acceleration, the engine slips in as a low, steady, unchanging hum while the battery absorbs every transient load spike. The result is the instant torque and quiet cabin of a premium EV, backed by the zero-anxiety range of a gas tank. Below about half pedal it behaves as a refined, EV-like cruiser; above it, the full hybrid system wakes for performance. Two personalities on one button.
    This is a refinement feature first, not an economy play, and it is worth being clear about that. The mode is opt-in, so the certified EPA label, measured in the car's standard configuration, does not change. Preliminary modeling across multiple city and highway mixes indicates fuel economy stays neutral to modestly better, from no measurable loss up to a few percent, because a steady, loaded engine avoids the frantic short-cycling of standard hybrid logic. That is upside to confirm on a dynamometer, not the reason to build it. The mode integrates behind the existing **[Auto EV/HV]** button, requiring zero hardware changes, zero user retraining, and zero modifications to the manufacturing line.
    [ Driver Pedal Input ] ---> [ Power Management ECU ]
    v v
    [ 13.6 kWh Battery Buffer ] [ M20A-FXS Engine ]
    Instantly deploys 60+ kW Held to a steady, quiet,
    to absorb transient spikes highly efficient rpm floor
    v
    [ eCVT Transaxle / MG2 ]
    v
    [ Linear, Silent Acceleration ]
    The Three Engineering Payoffs
    A naive series-hybrid calibration would introduce real NVH, thermal, and kinematic penalties. This strategy clears all three with precise, production-grade software safeguards, each with precedent in shipping vehicles:
    **Speed-Linked RPM Floor.** To avoid transaxle power-recirculation losses and inverter back-EMF stress at highway speed, the engine is not pinned to one speed. It holds a serene 1,600 rpm up to 45 mph, then scales smoothly to about 2,100 rpm by 70 mph. That keeps the motor-generators inside their efficient electrical range, while wind and tire noise fully mask the slight rise in engine pitch.
    **Anti-Shudder Boom Mitigation.** To eliminate the 53.3 Hz second-order structural boom inherent to a four-cylinder under load, the firmware caps engine load near 45% inside the resonance zone, softening the firing pulse at its source. A Schmitt-trigger hysteresis band stops boundary chatter, and MG2 backfills the exact torque deficit through the planetary set, so the pedal stays perfectly linear and the cabin stays smooth.
    **Predictive Thermal Window.** To hold SULEV30 through the cold-start FTP-75 cycle, the ECU runs a predictive model. When navigation data or driver pedal patterns indicate the engine will soon be needed, it runs a decoupled, ultra-low-load catalyst warm-up at about 1,200 rpm beforehand, so the catalyst is fully lit before it ever faces a high-load generator demand. No cold-cat hydrocarbon slug, no torque hole.
    Why do it?
    Most manufacturers calibrate plug-in hybrids with the nervous, short-cycling logic of a standard hybrid, because it is the safe, known baseline for emissions and economy testing. This calibration uses the Prime's plug-in pack and its electrical throughput to treat the engine as a stabilized, deliberate power plant rather than a frantic mechanical assistant.
    It bridges the gap between spreadsheet efficiency and an emotional, premium user experience, with no penalty to the rating sheet and no new parts. It is an EV feel that runs on infrastructure available at every street corner on earth, delivered entirely through smarter code. And it is newly possible. No earlier Prius had the battery capacity or the discharge power to buffer the engine this way; the 13.6 kWh pack is the first that can. The hardware just caught up to the idea.
    It also reframes what the big battery is for. Sold as a fuel-saver, the plug-in pack is underwhelming. A full 44-mile charge displaces only about seven-eighths of a gallon, roughly three dollars of gas, for a little over a dollar in net savings once you pay for the electricity, and it ties the car up for about four hours on 240V or most of a day on a standard outlet. Nobody comes out ahead babysitting a charge cable for a dollar a day. The pack's real worth is what it does for the driving experience, and Stealth Comfort cashes that in on every drive, plugged in or not, because the mode is roughly fuel-neutral with no wall charging at all. That turns the battery from a marginal savings device that has to be managed into a refinement asset that pays off every time the car is driven, which is a far stronger reason to want a Prime than the few dollars a plug saves.
    And it expands the car's appeal without disturbing its current one. Because the mode is opt-in, the buyer whose whole reason for owning a Prime is maximizing EV miles drives exactly as before, nothing taken away. What the car gains is a customer it does not fully capture today: the driver who runs past the 44-mile range, takes road trips, cannot always charge, and likes the powertrain but not the drone. For that person the pitch flips from "look how little gas you will use" to "look how much better it feels," and it converts a shrug into a sale at zero hardware cost.
    Technical Appendix: Powertrain Calibration Specification
    The Idea
    What it is
    The idea is to lean on the big battery and the electric motors so the gas engine almost never has to raise its voice. You get most of what people brag about in a Tesla, the instant torque and the quiet cabin, except you are doing it on petrol with a gas tank backing you up, so you never think about range or hunt for a charger.
    What it feels like to drive
    You pull away in silence on electric, like any EV. As you settle into traffic the engine slips in underneath you, but you do not get the familiar Prius drone that climbs and falls with your foot. You get a low, steady hum that holds one pitch, the way a well-insulated luxury car sounds. Roll on the throttle to merge and the surge is instant, the engine note staying flat, because the battery is covering the spike, not the engine. On the highway the hum lifts a little, but by then wind and tire noise own the cabin and you do not notice it. The only time it ever truly raises its voice is when you ask for everything, past about half pedal, and then it sounds like a car that means it. Lift off and it sinks right back into the quiet.
    What makes that work is a deliberate inversion of stock hybrid behavior. In a normal Prius a moderate press produces an immediate jump in rpm, so the engine sounds busy before the car actually feels fast. Stealth reverses the relationship: light throttle stays quiet, medium throttle stays quiet, and only heavy throttle brings the engine into the party. That is exactly how premium turbocharged cars are tuned, the cabin stays calm until you make it clear you want to go. The side effect is that the car feels more powerful, not less, because the engine arriving late reads as a surge rather than constant background strain.
    Toyota could frame it as two personalities on one button. Below about half pedal it is Stealth, EV-like refinement, the battery absorbing the transients so the engine never chases your foot. Above half pedal it becomes Prime Boost, the full hybrid system awake, rpm climbing fast with maximum battery assist. It will never be identical to a Tesla, because there are still engine starts and stops, but for commuting, traffic, suburban roads, and moderate highway driving it gets surprisingly close to the EV sensation while keeping the gas tank.
    The button you already have
    Nothing new to learn. The Prime already has the two buttons this needs.
    **[Auto EV/HV]** is the automatic mode, the one most people leave the car in, where you let the car decide. This is where Stealth Comfort lives. The new logic becomes the brain behind this button, so the driver gets the quiet cruiser by default without reading a word of the manual.
    * **[HV/EV]** is the manual override, and it does not change at all. Force HV to lock and preserve your charge for later. Force EV to draw the pack down to minimum on the last leg home, so you arrive nearly empty and can take a full 44 mile charge overnight on cheap power.
    [ Battery SOC ]
    |-- [HV/EV] forced EV ----> drain pack to minimum (arrive empty, take full 44 mi charge)
    |-- [HV/EV] forced HV ----> lock and preserve current SOC for later
    +-- [Auto EV/HV] ---------> STEALTH COMFORT
    |-- low/mid speed, light pedal --> series-priority quiet cruise
    +-- high speed / hard pedal --> seamless parallel blend
    By putting the logic behind a button drivers already expect to mean "let the car optimize itself," you hand them a luxury EV experience by default and add zero user confusion.
    Why It Works
    Low rpm is not the enemy, light load is
    Everybody assumes low rpm means low efficiency. It does not. What matters is load fraction, how hard the engine is working relative to what it could do at that speed. A lightly loaded engine bleeds most of its fuel to friction and pumping no matter the rpm. Load it up and even low rpm lands on its best efficiency island. The M20A-FXS has a wide island thanks to its 14:1 compression and electric variable valve timing, which is why this works as well as it does.
    So the trick is not to baby the engine. It is to run it low and loaded, using it as a generator that carries the car and tops the battery at the same time. In a roughly 1,600 rpm window it sits near 60% load and lands around 39% thermal efficiency. Peak for this engine is about 41%, so you are giving up almost nothing.
    The question worth checking was whether buying this refinement costs fuel. The model was run repeatedly to find out: a 300-mile day with no wall charging at all, the battery just buffering, across several city and highway mixes, plus an rpm sweep. The result comes back in a narrow band every time, from no measurable loss to about 4% better than stock, because the steadier engine policy avoids short-cycling and hunting. So the NVH strategy does not appear to cost economy, and may modestly help. Treat that as upside to confirm rather than the headline, because it is modeled rather than dyno-measured. The certified label does not move regardless, since the mode is opt-in.
    The 13.6 kWh macro-buffer
    This is where the Prime beats the cars that already run series-hybrid. Nissan e-Power and Honda i-MMD carry tiny buffers, around 1.5 to 2 kWh. When the driver suddenly asks for a big slug of power, the engine has to jump up right now, because the little battery cannot bridge the gap. That is why those cars still surge their engine note under hard throttle.
    The Prime carries 13.6 kWh and a pack that can dump well over 60 kW on demand. The engine can sit at a leisurely 1,600 rpm putting out a steady, efficient 20 kW. When you press in for traffic, the battery instantly covers the difference and you feel clean electric torque while the engine never changes its tone.
    Driver demand: 45 kW
    |-- Engine locked at 1600 rpm -- steady 20 kW --+
    | v
    +-- 13.6 kWh battery buffer -- instant 25 kW --> MG2 --> 45 kW to wheels (quiet)
    Instead of the engine mimicking your foot step for step, it simply experiences a shift in electrical load while its physical rpm stays a serene hum.
    This is also why the idea is new rather than a missed opportunity nobody noticed. It was not possible on earlier Prius generations, and not because nobody tried. Their packs simply did not have the capacity or the discharge power to act as a macro-buffer, so the engine had to track the driver's foot because nothing else could cover the transients. The 13.6 kWh pack is the first one with enough throughput to let the engine sit still. The hardware finally caught up to the concept.
    The engine already cycles, this just governs how
    It is worth being precise about the baseline. Stock HV does not hold the engine steady. It flips it on and off in indeterminate windows as demand rises and falls, closer to a light switch than a dimmer. That cycling exists for good reasons, efficiency, emissions, and catalyst management, but it is also the source of the switch-like character a driver notices. So Stealth Comfort is not fighting a stable baseline, and it does not pretend the engine is a static generator in all conditions.
    What it changes is the on/off policy. A minimum dwell time once the engine starts, revised hysteresis so it does not chatter between states, and the 13.6 kWh buffer absorbing short demand swings so the engine does not need to flip as often. Engine shutoff is still permitted, but only in clearly safe windows where catalyst temperature and road load are both favorable. The unresolved question was never whether the engine is allowed to cycle, it already does. It is whether you can constrain that cycling without breaking emissions or thermal margins, and the dwell-and-hysteresis policy is exactly that constraint. What the driver feels is a steadier hum in place of a switch.
    The quiet window
    The 2.0 Atkinson has two rough spots, not one. Past about 1,700 rpm it drones, the airborne noise everyone knows. Down around 1,400 to 1,500 rpm under heavy load it booms, a structural shake through the mounts that feels lugged. The target sits between them, roughly 1,550 to 1,650 rpm, with a slow sub-audible dither across the band so it never parks long enough to build a standing acoustic wave.
    The Engineering
    Transaxle kinematics, power recirculation, and the speed-linked rpm floor
    The one hard physical limit lives inside the eCVT. On the 5th gen transaxle the engine sits on the planet carrier, MG1 on the sun gear, MG2 and the output on the ring, with a planetary ratio around 2.6. Their speeds are locked by the geometry. With ratio k near 2.6, the planetary relation reduces to MG1 speed = 3.6 x engine speed - 2.6 x ring speed. Ring speed rises with road speed, so pinning the engine low while the car speeds up forces MG1 to spin backward harder and harder.
    | Vehicle speed | Ring / MG2 | Engine if pinned | MG1 / sun | Status |
    | 35 mph | ~2,500 rpm | 1,600 rpm | -740 rpm | clean series zone |
    | 55 mph | ~4,000 rpm | 1,600 rpm | -4,640 rpm | edge of efficient EMF range |
    | 65 mph | ~4,700 rpm | 1,600 rpm | -6,460 rpm | recirculation losses climbing |
    | 75 mph | ~5,450 rpm | 1,600 rpm | -8,410 rpm | unacceptable, must blend |
    The structural redline on MG1 is well north of 17,000 rpm, so rotor structural failure is not the issue. Instead, two operating limits intervene first:
    1. Spinning the permanent magnet rotor backward rapidly generates heavy back-EMF whose current loads the inverter thermally.
    2. The device enters a mechanical-electrical-mechanical power loop called **power recirculation**. MG1 generates electrical power that MG2 must immediately consume to balance the planet carrier against pavement torque. The conversion penalty for this recirculating energy climbs steeply as the speed split widens.
    A hard 65 mph cliff is the wrong fix. The correct calibration uses a **speed-linked rpm floor**. Hold ~1,600 rpm up to 45 mph, then let the engine target rise gently along a minimum-loss curve to ~1,900 rpm at 60 mph and ~2,100 rpm by 70 mph. Raising the engine to 2,100 rpm at 70 mph cuts MG1's reverse rotation speed by roughly 1,800 rpm, keeping it cleanly inside its efficient electrical range and mitigating power recirculation. The driver does not notice the extra revs because road and wind noise dominate the cabin at those speeds. Above this practical ceiling, the system drops into a normal parallel blend.
    Transient power delivery
    Because the engine is locked to MG1 and MG2 through the planetary set, holding it steady turns the electrical side of the transaxle into a dynamic scale. Here is how the device handles a real transient, pacing traffic on a rolling hill, with the engine pinned and generating a steady 20 kW.
    | Driver input | Road | MG1 behavior (sun) | Battery action | Outcome |
    | Cruising, ~15 kW | flat | brakes the engine to hold target rpm | absorbs spare ~5 kW to recharge | pure quiet, engine load ~45% |
    | Tip-in, ~35 kW | gentle incline | torque command drops toward zero or assists | instantly discharges ~15 kW to MG2 | engine note never changes, battery eats the spike |
    | Floor it, ~75 kW | passing a truck | commands maximum torque split | dumps 60+ kW to MG2 | ECU breaks out of Stealth, engine flashes to ~4500 rpm for parallel push |
    In a small-buffer hybrid the engine would have to mimic the driver's foot step for step. With the macro-buffer it just sees a change in electrical load while its rpm stays flat, right up until you genuinely floor it.
    The boom node is felt, not just heard
    A four-cylinder engine fires twice per revolution, so its second-order vibration at 1,600 rpm sits at exactly 53.3 Hz. That frequency lands squarely in the cabin boom band for a compact unibody platform. The sub-audible dither smears that energy across a 51 to 55 Hz window to prevent standing acoustic waves, but smearing alone does not stop the kinetic energy from transferring through the engine mounts into the floorboards as a low hum.
    The real fix attacks the source by capping engine load near 45% inside this resonance zone, softening the cylinder firing pulses. The 13.6 kWh buffer covers the torque shortfall through MG2. This is done feed-forward via a pre-mapped resonance table in firmware, requiring no cabin microphone or accelerometers. The one honest cost is a couple points of thermal efficiency while load is capped, so it is applied only inside the resonance zone, not everywhere.
    Crossing the cap without a shudder
    A naive implementation of this load cap creates a control trap due to an **actuator latency mismatch** at the boundary. The engine sheds torque via manifold airflow over roughly 100 to 150 ms, while MG2 responds through the inverter in about 10 ms. A driver hovering their foot right at the threshold would cause the ECU to toggle the cap on and off rapidly, and the two actuators, fighting out of phase, would set up a longitudinal driveline oscillation.
    Three standard calibration strategies remove this shudder entirely:
    1. **Schmitt trigger hysteresis.** Engage the load cap at 47% load and do not release it until the raw request falls below 43%, preventing chatter around a single point.
    2. **Slew-rate limiting.** Apply a smooth ramp to the engine load command so the mechanical transition matches the physical constraints of the intake tract.
    3. **MG2 active backfill.** Compute the exact engine torque error and command MG2 to backfill the deficit through the planetary ratio. Because the inverter updates far faster than the engine breathes, the electrical side cleanly masks the mechanical lag, keeping pedal response perfectly linear.
    This backfill operates well within the inverter's existing thermal envelope, covering a load delta of only a handful of kW, far less than MG2 already handles launching the car or grabbing regen. If the inverter does hit a thermal limit and derate during an extended climb, it clamps MG2 current. The backfill then falls short, allowing the 53 Hz boom to return to the cabin, acting as a natural physical warning to the driver that the electrical buffer is spent.
    Catalyst thermal management and the cold-start trap
    Emissions compliance is the true validation hurdle for this mode, and the primary enemy is the cold-start FTP-75 cycle.
    If a driver leaves their driveway in Stealth mode with the battery at 60% SOC, the vehicle defaults to EV operation. The engine stays off and the catalyst stays stone cold. If the driver then executes a heavy highway merge, the engine fires under load against a cold cat, producing a hydrocarbon slug that violates SULEV30 limits. A reactive 15-second spark-retard light-off run during that merge creates a torque hole that can drag pack voltage toward its low-voltage cutoff.
    The solution is a **predictive thermal window**. When the vehicle operates in Auto mode, the ECU monitors state-of-charge math, navigation data, route history, and runs of sharp pedal transients. If these inputs indicate the engine will be needed within the next few minutes, the ECU initiates a quiet, fully decoupled catalyst warm-up phase at ~1,200 rpm with near-zero output load. The catalyst bed reaches its ~400 C light-off temperature silently before a high-load generator demand ever occurs. Once lit, steady loaded operation maintains catalyst temperature far better than stock short-cycling logic.
    The revised ECU logic loop
    The power management ECU executes this control loop every cycle within the Auto button path. If any operating boundary is crossed, it gracefully exits the quiet target to protect the hardware and returns to Stealth logic as soon as conditions clear.
    [ Auto EV/HV selected, Stealth Comfort active ]
    [ Read: road speed V, pedal a, cat temp T, MG1 rpm ]
    [ Boundary conditions ]
    V within speed-linked rpm-floor range ?
    pedal a < 50% ?
    MG1 inside efficient EMF range (no recirculation) ?
    YES NO
    [ Thermal + cabin check ] [ Protective fallback ]
    cat temp > 380 C ? - scale engine rpm up with road speed
    in 53 Hz boom zone ? - parallel blend if past the ceiling
    | - free rev on hard throttle
    +------+------+ - predictive / 15 s cat heat run if cold
    OK NO
    v v
    [ Series [ Corrective ]
    priority ] - run predictive cat warm-up
    lock to - cap load ~45% to kill 53 Hz floor hum,
    speed-linked buffering the torque gap with MG2
    rpm, dithered,
    battery buffers
    all transients
    If the driver outruns the battery capacity, the pack drifts to its lower state-of-charge floor and the vehicle reverts to normal, stock HV hybrid behavior. No limp mode, no warning light, no service call.
    Calibration spec sheet
    * **Feature:** Stealth Comfort mode, the new logic behind the existing [Auto EV/HV] button. The manual [HV/EV] button remains unmodified to force standard EV or charge-sustaining behavior.
    * **Operating envelope:** active up to 50% accelerator pedal input. Blends into a standard parallel mechanical path if pedal input exceeds 50% or if speed exceeds the dynamic ceiling.
    * **Engine target schedule:** speed-linked rpm floor holding ~1,600 rpm up to 45 mph, scaling smoothly to ~2,100 rpm by 70 mph, with a slow +/-50 rpm sub-audible dither across the band to break up standing acoustic waves.
    * **NVH mitigation:** feed-forward engine load cap near 45% inside the 53.3 Hz second-order boom zone, controlled via a Schmitt-trigger hysteresis band (engage 47%, release 43%) paired with a slew-rate-limited load command and synchronous MG2 torque backfill.
    * **Battery state-of-charge band:** target hold between 30% and 70% SOC, using the 13.6 kWh pack as a high-throughput macro-buffer for all transient smoothing.
    * **Driver feedback:** a "Quiet" or "Refined" indicator in the instrument display when the mode is active, so the driver gets clear feedback on which character is engaged, the same way any production drive mode confirms its state.
    * **Engine state policy:** a minimum dwell time once the engine starts plus revised on/off hysteresis to suppress switch-like cycling, with the buffer covering short transients so the engine changes state less often. Shutoff permitted only when catalyst temperature and road load are both favorable.
    * **Catalyst thermal strategy:** predictive thermal window, pre-warming the bed to ~400 C at ~1,200 rpm decoupled before predicted engine loading, backed by a hard 380 C floor that triggers a spark-retard heat run if reached during extended coasting.
    * **Hardware requirements:** none. Executed entirely via a firmware update to the power management control ECU. Active mounts or ANC only if cabin boom proves stubborn beyond the load cap.
    Open validation items
    Across this analysis the hurdles moved from "can it work" to "how much validation," which is where serious production concepts are supposed to end up. The remaining questions are not physics, they are testing, and naming them honestly is part of the pitch:
    **Battery throughput durability.** Using the pack as a macro-buffer raises lifetime energy throughput. Mitigation favors the existing 30 to 70 percent mid-SOC window, which is itself the gentlest regime: it keeps the pack out of the high-voltage, high-temperature calendar stress at the top and the deep-discharge stress at the bottom, and the buffering is shallow cycling around the middle, the least damaging kind of throughput. The traction-battery cooling fan is a legitimate active lever here, not just a backstop. A steady low fan whir is the benign kind of noise, broadband and constant like an HVAC blower or an EV's own thermal management, the sort the ear tunes out, while the alternative it prevents, the engine flaring to high rpm to spare the pack, is exactly the intrusive transient the mode exists to kill. So the fan runs as needed to hold thermal headroom, capped only where it would cross from background hum into an audible whoosh. Spending a little steady, ignorable noise to remove engine thrash is a trade worth making. Toyota would still want multi-year durability data, but the strategy already targets about the most benign degradation envelope available.
    * **Thermal under sustained bursts.** Repeated 20 to 30 kW discharge in hot weather has to be validated against battery and inverter temperature limits, with the derate behavior characterized rather than assumed.
    **Emissions certification across corner cases.** The predictive catalyst strategy is sound in principle, but proving it across the full corner-case matrix of the cert cycles is expensive and slow.
    * **Customer consistency at the buffer floor.** When SOC reaches its lower limit the experience reverts to stock HV. That handoff has to be transparent and predictable, because Toyota is obsessive about consistent behavior, and an experience that quietly changes character is exactly what it guards against.
    None of these are reasons the concept cannot work. They are the cost of proving that it does. And they are all manufacturer-side costs, calibration effort, validation time, throughput and thermal accounting. The customer-visible tradeoffs, by contrast, appear minimal: peak power, EV-mode function, HV charge preservation, charging behavior, and range all remain unchanged, in exchange for less engine hunting, less drone, and a more EV-like response. That is the honest scope of this document: a physics-clean concept whose path to production runs through validation and a willingness to trade a fraction of absolute efficiency for a more premium experience, not through any new invention.
    Proposed validation plan
    Those open items resolve through a standard mixed regime, powertrain hardware-in-the-loop plus environmental chassis-dyno testing. Three tests carry most of the risk. Note that the numbers in the table below are acceptance gates and design targets the calibration would be held to, not predicted results. The baselines are representative reference values, and the target column states the goal to confirm on the rig, not a measurement that has been taken.
    **Test 1, FTP-75 cold-start and catalyst thermal.** Objective: verify the 1,200 rpm decoupled pre-warm does not compromise emissions. Setup: environmental chamber with a 20 C thermal soak. Procedure: run FTP-75 Phase 1, commanding the engine to 1,200 rpm decoupled at minimum load on the predictive trigger. Measure catalyst bed temperature and raw tailpipe HC and NOx over the first 120 seconds.
    **Test 2, high-speed eCVT recirculation and thermal stress.** Objective: confirm the speed-linked floor keeps MG1 out of the back-EMF recirculation zone. Setup: powertrain dyno coupled to the output shafts with simulated aero drag. Procedure: hold 75 mph at 3% grade and compare stock behavior against the speed-linked floor. Measure MG1 speed, phase current, inverter IGBT temperature, and net battery throughput.
    **Test 3, transient anti-shudder tip-in.** Objective: confirm the MG2 backfill masks the engine's manifold lag during an EV-to-hybrid handoff. Setup: HIL rig with crankshaft and MG2 torque sensors. Procedure: rapid tip-in from 10% to 60% demand at 45 mph. Measure torsional vibration at the output shafts with high-speed encoders.
    | Test | Metric | Reference baseline | Design target | Pass gate |
    | Cold-start emissions | time to cat light-off (300 C) | ~45 s | under 30 s | within 35 s, no HC breakthrough |
    | | Phase 1 cumulative NOx | representative | reduced | meets LEV3 / SULEV30 |
    | eCVT recirculation | MG1 minimum speed | ~-6,200 rpm | ~-4,100 rpm | above -4,500 rpm |
    | | inverter core temp rise | representative | sharply reduced | stabilize below 95 C |
    | Anti-shudder tip-in | output-shaft torsional vibration | ~+/-4.5 Nm | ~+/-0.8 Nm | under +/-1.2 Nm |
    | | torque-delivery latency | ~120 ms (engine alone) | ~12 ms (MG2 masked) | within 15 ms |
    The expected direction, the one the speed-linked floor was designed for, is that keeping MG1 out of the recirculation zone sharply cuts inverter thermal stress during highway cruising, buying headroom that offsets the modest rise in battery throughput from low-speed smoothing. The magnitude of that win is exactly what Test 2 exists to quantify, and it should not be asserted before it is measured.
    Conclusion
    This strategy leverages the physical overhead of the 5th-generation Prius Prime's 13.6 kWh battery pack and transaxle to shift calibration priorities from marginal fuel-consumption gains to premium cabin NVH. By managing transaxle kinematics through a speed-linked floor, isolating structural resonance via a rate-limited load cap with active electric backfill, and managing emissions through a predictive thermal window, the calibration remains entirely production-feasible. It delivers a premium electric-vehicle driving experience using the existing mass-market component catalog, requiring only optimization within the power management software architecture.
    The conceptual leap underneath all of it is simple. The 13.6 kWh pack stops being merely an energy store for EV range and becomes a real-time NVH actuator, a torque reservoir that smooths engine behavior, masks actuator latency, suppresses transient vibration, reduces engine cycling, and reshapes the subjective character of the car. Most refinement is bought with hardware, acoustic glass, active mounts, extra insulation. This buys it with energy-management strategy instead. It is still firmware only, with no new hardware, but it is genuine calibration work, not a weekend flash.
    There is also a clean precedent for the single judgment call this asks Toyota to make, trading a sliver of efficiency for desirability. The lineup already does exactly that at the wheel wells. The XSE's 19-inch wheels drop the Prime from 52 to 48 mpg combined, an 8% hit, purely for how the car looks, and because trims certify separately the headline 52 mpg survives on the SE. If Toyota will spend 4 mpg on appearance, an opt-in software mode that trades a far smaller fraction, possibly none, for an EV-like cabin is the same trade made for a better reason. The argument that efficiency must be protected at all costs is one the product lineup has already answered for itself.
    *Figures are from an independent first-principles model, road load plus a friction and pumping efficiency map anchored to EPA dynamometer data on Toyota's Dynamic Force Atkinson engines, with kinematics from the 5th gen planetary geometry. The economy range reflects repeated model runs across multiple drive scenarios, not a dyno measurement. This is an engineering estimate intended to justify a prototype and a cert-cycle measurement, not a finished calibration, but the shape and the conclusions hold.*
  2. Driver1
    Driver1 New Member
    Georgia
    2026 Prius Plug-in
    XSE Premium
    Make the Plug-in Actually *Prime*
    A Long-Range EV With an Onboard Generator — Already Built, Just Wired Wrong
    The Promise
    You get into the car. It pulls away in silence, like any EV — instant torque, no noise, no drama. You merge onto traffic and the power is just *there*. On your daily run through town, you'd swear you were driving an electric car.
    Except you never plug in if you don't want to. You never hunt for a charger. You never watch a range number and do anxious math in your head. There's a gas tank backing you up, so 44 miles or 440 miles, the car just goes.
    That's the pitch. **It's a low-powered EV with a smart onboard generator** — not a hybrid that occasionally drives on electric, but an electric car that happens to make its own electricity when it needs to.
    What's Wrong Today
    The hardware is already in the Prime. Big motors that move the car to highway speed on electricity alone. A 13.6 kWh battery. One of the most efficient gas engines on earth. Toyota built a genuine EV-capable drivetrain.
    Then they wired the software backwards.
    Right now the engine doesn't help you drive — it wakes up to *charge the battery*, screaming to 4,200 RPM while the car barely accelerates. You go from whisper-quiet Tesla-like cruising to a PT Cruiser thrashing up a hill, and the engine isn't even moving you, it's spinning a generator. That mismatch — silent one second, thrashing the next — is the single worst thing about owning the car. It's the thing that makes a "Prime" feel like just a plug-in hybrid instead of something special.
    The Inversion
    Flip the hierarchy.
    Instead of *gas-first with a little electric help*, make it *electric-first with the engine as a quiet assistant*. The battery does the driving and absorbs every surge. The engine only comes in when it's genuinely useful — and when it does, it stays low, loaded, and barely audible, because the battery is covering the spikes instead of the engine chasing your foot.
    - **Around town, light pedal:** pure quiet electric.
    - **Steady cruising:** the engine slips in low and even, holding one calm pitch, topping the battery and helping push — you barely feel it.
    - **Floor it to pass:** *now* the engine wakes up with everything it's got, and it sounds like it means it.
    - **Last leg home:** drain the pack down so you arrive empty and take a full charge overnight on cheap power.
    Two personalities, one button you already have. Quiet refinement by default, real power the moment you ask.
    Why It Matters to Real People
    Most drivers can't home-charge and don't live near a Supercharger. A pure EV strands them. A Tesla on Supercharging is only running about 25–27 mpg-equivalent in real cost anyway — and that's *if* they can find a charger.
    This car asks nothing of them. No home charger. No infrastructure. No $10,000 battery replacement looming in five years. It conforms to your life instead of making you rearrange your life around it. You get the EV experience today, on the gas and electric grid that already exists at every street corner on earth.
    It's the step Toyota skipped. They went from regular hybrid straight toward full EV and missed the obvious bridge sitting in their own showroom.
    The Part Nobody Can Argue With
    This is **software**. No new parts. No new battery. No retooling. The motors are big enough. The pack is big enough. The engine is efficient enough. Everything needed is already bolted into the car — it just needs to be told to behave differently: hold the engine in its quiet, efficient sweet spot, widen the operating band, and stop thrashing to charge at the worst possible moment.
    And before anyone says "Toyota already optimized this for efficiency" — Toyota itself spends 4 mpg on nineteen-inch wheels for the XSE, purely for looks. If they'll trade efficiency for *appearance*, an opt-in software mode that trades little or nothing for a genuinely premium driving experience is the same trade made for a far better reason.
    They built the best version of this car by accident and never saw it. This just turns it on.
    #2 Driver1, Jun 5, 2026
    Quovadis007 and 2023p like this.
  3. lostsoul
    lostsoul New Member
    16
    US
    2026 Prius Plug-in
    Allot of that is above my pay grade. lol All I know is with the range I need I like being able to pick to run ev or gas. Especially, now that gas is high. We like that so much we got a rav4 plug in for the wife. The only question now is will it be reliable for many decades like older Toyotas. So much tech and now with the oil change I worry.
    52,883
    the long ev range, small engine drive train hasn't sold well. at some point, a Bev is cheaper and simpler
  5. Driver1
    Driver1 New Member
    Georgia
    2026 Prius Plug-in
    XSE Premium
    It's not that at all, its exactly what they have in the Plug-in versions its just using recalibrating battery management as a Automated wide band buffer system instead of the narrow band like the regular hybrid, then let it be a EV around town and better mannered cruiser. Toyota only thought of this as a One or the Other proposition, Hybrid or a EV with the Plug-in/Prime, they never said wait if we use the battery pack in a wider range it is a EV around town and a well mannered Hybrid at mid to high speed.
    Basically a EV like driving experience with what the Hybrid system quietly humming away at mid to high speed during regular driving.
    #5 Driver1, Jun 5, 2026
    Quovadis007 likes this.
  6. Hammersmith
    Hammersmith Senior Member
    2,497
    2,557
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Two words: Conversion losses.
    Check out Technology Connections' video on hybrids:
    Templeton and phasechange like this.
  7. Trollbait
    12,832
    You are asking for a more blended mode PHEV. Those have the wider buffer you are asking for, which works out to the engine coming on sooner and more often. Buyers in the US do not want that. When they have the car in EV mode, they don't want the engine coming on at all. To sell, a PHEV needs the engine to stay off at freeway speeds, while still having a decent advertise EV range. A wide range battery buffer works against those.
    The fact is that an engine coming on while EV mode will always be noticed. Toyota put a harmonic balance in the Prius PHEV engine to make it smoother running than the hybrid's. Yet you still find it harsh.
    Disconnecting the engine speed from road speed isn't possible with the Toyota power-split system. You need 100% series hybrid operation, and that isn't possible here. As pointed out, series hybrids have conversion losses that increase with speed. Then the slow, steady engine hum may not be as great as you envision. Audi had A2 PHEV prototypes that were pure series hybrids. The tiny rotary engines would run at just one speed. They had to change that because people were finding the steady hum not connected to road speed disorienting.
    The software for overseas models might work more like you want. They have different modes than the North American model. Or look at Hyundai/Kia and Honda. Their PHEVs might work as you wish.
  8. Driver1
    Driver1 New Member
    Georgia
    2026 Prius Plug-in
    XSE Premium
    First, the core of it, because I think it's reading as more exotic than it is. This isn't a new architecture and it isn't an either/or. It's just the hybrid doing what it already does, leaning on EV at low speed from the big battery and recharging at mid speed, only in bigger, smoother swings instead of tiny rapid ones. The engine still drives the wheels. It's just demanding more amps at mid speed to rebuild a wider battery buffer, then riding that buffer at low speed. Same operations the car runs today, just macro instead of micro. That's the whole idea, and it's why nothing fundamental has to change.
    To address you point by point:
    1. It doesn't touch EV mode. EV stays exactly as it is today. This only changes how the engine behaves when it's already running in HV/Auto. It does not bring the engine on sooner.
    2. Holding engine rpm while road speed varies isn't "100% series," it's normal eCVT behavior. MG1 already lets the engine spin at its own rpm independent of the wheels. Nothing new there.
    3. The MG1 high-speed limit is real, which is exactly why engine rpm rises with speed (roughly 1600 low, 2100 by 70) instead of being pinned. That covers the recirculation losses too.
    4. The Audi A2 drone was a fixed single speed disconnected from the road. This isn't fixed, the pitch still tracks speed, so it sidesteps that.
    5. Agreed that engine-on is noticeable and that series losses climb with speed, which is exactly why it's a bounded HV comfort overlay, not a full series mode. Honda i-MMD is the fair refinement comparison, the Prime just has a bigger buffer to lean on.
  9. Winston Smith
    Winston Smith Active Member
    476
    344
    OH
    2024 Prius
    LE AWD-e
    Can't you already do that with your car by putting it into battery only mode around town?
    Gokhan likes this.
  10. Driver1
    Driver1 New Member
    Georgia
    2026 Prius Plug-in
    XSE Premium
    Yeah, kinda... if you want to do a manual shift by hitting the button but there's nothing that effectively lets you regen the battery back to a certain point which I found 60% to be the maximum for a upper limit on hard braking regen to keep the battery in its happy place.
    I'm actually doing this now manually to see if a module is worth making to do it for me automatically. That wouldn't be hard, just figuring out how to keep the battery from hitting Zero on a few hundred mile trip or keeping it in pure HV mode with a wide band. Basically for the i never plug in my Plug-in people that run in pure HV mode or put more than 30 ~ 40 miles per day on, this would make it retain more manners under 30 ~ 40 mph.
    From my initial loose testing im seeing all benefit and no downside from this. Its looking like Toyota engineers may have left a tuning opportunity slip by them on refinement with no downside.
    #10 Driver1, Jun 8, 2026
  11. notspam3
    notspam3 Member
    139
    76
    Toronto
    2024 Prius Prime
    XSE Premium
    If THIS is your problem on a new 2026 Prime XSE then take it to the dealer as you have a warranty issue.
    Skip the AI verbal diarrhea to solve a problem that you can't fix and that doesn't exist for most consumers.
  12. Winston Smith
    476
    344
    OH
    2024 Prius
    LE AWD-e
    Regen or engine generated charge?
    My WAG would be that engineers identified battery wear from cycling and very intentionally avoid having the car operate in a wider HV band so the entire system makes to the end of the warranty period. That's not an informed calculation, but understressing drive components appears to be a doctrine at Toyota that predates hybrids.
    I'll also guess that Toyota didn't prioritize the sort of serene character you are pursuing because Toyota's small car audience don't prioritize it. I've heard Lexus owners drone on (small pun) about how quiet and refined their cars are, but an unpleasant tone and a somewhat cheap aesthetic are part of the Toyota aura. A small Audi in feel and sound will be a silk purse and Corolla a sow's ear. You'd wonder why people buy Corolla's until you see an Audi's turbo failure rate of the top of the engine valves covered in tar.
    For people who really like the whisper of an electric motor, Tesla and Lucid provide experiences a lot of people are nutty about. How could a hybridized and dressed up Corolla compete for that audience?
    I'd be interested to see what you do. Toyota is also the company who denied a warranty claim on a new GR Corolla when it caught fire because the owner exceeded 85 MPH. If you defeat the current PHEV programming to force greater discharge of the battery so the engine doesn't come on as soon, you'll have the same thrashy engine problem and a more stressed battery. You might also find yourself in a tussle with Toyota about whether your warranty will cover a battery replacement.
  13. Driver1
    Driver1 New Member
    Georgia
    2026 Prius Plug-in
    XSE Premium
    Talked to Toyota and been to the dealer. They are just the shrug off department...
    Ai assisted not written.
    GcinFl and bisco like this.
  14. Driver1
    Driver1 New Member
    Georgia
    2026 Prius Plug-in
    XSE Premium
    Yeah you all play the take my money then tell me to shut up game and I dont and I normally dont complain. I've owned 1 Kia new, 2 New Genesis G70, 2 Pre-owned G80. Yeah im not comparing the Prius to the Genesis, I'm pointing out the fact that I buy things and don't want to jump to complaining. Im not that Karen.
    Quick note before the meat
    This is AI assisted, not AI written. I ran the tests, watched the live pack data, made the calls. AI helped me organize it and poke holes in it, same as I'd use a scan tool or a service manual.
    And to be straight about the mix: some of this is documented fact and some is informed speculation. I'll tell you which is which as I go.
    The thesis
    The Toyota people defend in these threads is the over-engineer-everything, under-promise and over-build outfit that earned the halo. That's not the Toyota shipping cars right now. Watch how the current one actually behaves instead of assuming the old one, and a bunch of separate decisions start lining up into a pattern.
    What's not speculation: the V35A
    The twin turbo 3.4L V6, straight off the NHTSA record:
    **May 2024:** about 102,000 Tundra and Lexus LX recalled. Machining debris gets trapped in the #1 main bearing and kills the engine under load. The fix was a full engine replacement, up to $25k each.
    - **Nov 2025:** about 127,000 more, including engines built after Toyota had already added debris removal steps.
    - **May 2026:** another 44,000 Tundras. Running total is now closing in on 270,000.
    - **The bad part:** those later engines were the supposedly fixed ones. Toyota even revised the #1 main bearing to handle contamination better, and engines built after the change still showed the same wear in teardown.
    Toyota officially still blames debris and hasn't admitted a design flaw. But you don't redesign a bearing that was fine. Four years, multiple campaigns, and a fix that needed fixing, all from the company whose entire premium is "it just runs forever."
    The oil tells the same story
    - Toyota specs 0W-8 and 0W-16 here while the same engines get 30 weight in other markets. Same block, different number depending on whose fuel economy rules they're trying to satisfy.
    - GM is running the play in reverse right now. The 6.2L L87, federal probe over 870,000 vehicles, recall in the several hundred thousand range for crank and rod failures, and a big part of the fix is bumping the factory 0W-20 up to 0W-40. They reach for the thick oil only after engines start grenading and the lawyers show up.
    So here's the fact: the viscosity spec moves by region, and it moves again under legal pressure. The number on the cap isn't some longevity optimum handed down from a temple of reliability. It's a compliance and accounting number, and it changes the second failures get expensive.
    Where I'm openly speculating
    Two readings here. They could both be true at the same time, because they don't cancel each other out.
    **The fear angle.** The BYD turn is real. The China market bZ3 and bZ5 run BYD LFP and Blade battery tech, and Toyota says so openly. A company this proud, with its own solid state program, doesn't hand battery duty to a competitor unless it sees something it can't match in house right now. Put that next to a V35A program that couldn't clean its own engines across four tries and you get a company moving faster than it can reliably back up, reaching outside where its own work is shaky.
    **The greed angle.** The current plug-in is a stretched, reskinned platform sold on heritage pricing. Corolla bones, Prius badge, premium number. When it didn't move on its own, the chassis got dropped into the SE trim to push inventory. That's a margin call, not an engineering one.
    **The charger, and I'm calling this a gripe, not evidence.** The 3.3 kW onboard charger. To be precise, charger wattage is an AC wall charging spec and proves nothing mechanical about the battery. But it fits whichever lens you like: cheap if you read greed, cautious if you think they'd rather not push the system hard, or just "it charges overnight anyway, why pay for more." Take your pick. Minor gripe, not proof.
    What ties it together
    This isn't how the Japanese carried themselves in their prime. The old code was under-promise, over-build, and eat the cost to protect the name. What I'm watching now looks more like used car salesman tactics that happen to produce new cars:
    - Lean on the legacy reputation
    - Price to the legend instead of the product
    - Move spec numbers to satisfy regulators, not owners
    - Shuffle trims to clear inventory
    - Outsource the hard parts when the in house work slips
    The badge still says Toyota. The behavior says something else.
    The fair counter
    To keep myself honest, the other side of it:
    - Toyota is being proactive issuing these recalls instead of burying them.
    - The hybrid drivetrain, including the Prius, has a strong real world record and is not part of the V35A mess. That's a truck and SUV V6 problem.
    - The conservative SOC band this whole thread started over is arguably owner protection, not penny pinching.
    A reasonable person can look at all this and call it a company managing a hard transition rather than one that's lost the plot. I don't fully buy that, but it's fair and I'm not going to pretend it isn't there.
    One detour to 88 mph
    Marty had to hit 88 mph to travel through time. Toyota only needs 86 to travel through your warranty. Oh so sorry, the coverage went real fast because you went too fast. Lol
    Bottom line
    The facts are sourced. The recall numbers, the BYD partnerships, the oil specs are all on the record. The motives are my read, offered as a read. I might be wrong about the why. I'm pretty confident about the what. And the what is enough to retire the "never question the factory, Toyota knows best" line, because it's built on a Toyota that, going by current behavior, doesn't really exist anymore.
  15. Winston Smith
    476
    344
    OH
    2024 Prius
    LE AWD-e
    If AI "assisted" you with that, I'm not sure it is really assisting you.
    RobotBastard and mingc like this.
  16. Driver1
    Driver1 New Member
    Georgia
    2026 Prius Plug-in
    XSE Premium
    Meh
  17. mingc
    mingc Member
    104
    74
    Portland, OR
    2023 Prius
    XLE AWD-e
    Yup. @Driver1, you lost me about 1/4 way through your 1st post. You need to assist your AI and then some.
    RobotBastard likes this.
  18. Driver1
    Driver1 New Member
    Georgia
    2026 Prius Plug-in
    XSE Premium
    Ok, so point by point whats your actual questions about my posts? Dont just hand wave and say I dont know etc. Be real, whats confusing you? Do you own one or not?
  19. Blackat
    Blackat Active Member
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    TL;DR
    ETC(SS) likes this.
  20. Winston Smith
    476
    344
    OH
    2024 Prius
    LE AWD-e
    One of the nice things about this format is that it lets people make statements and ask questions, and others to respond.
    If you want people to respond to your though, it helps a lot if it is coherent and your thought. It also improves the process if you read what people write.
    The problem people are identifying is that dragging a lot of AI content that doesn't pertain to your point into a post keeps people from trying to decipher your thought. If you respond about people telling your to shut up even though no one did that, people wonder whether you are reading posts.
    Hope that helps.
    RobotBastard and 2023p like this.
