How to manage EV Range
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 510bg, Aug 5, 2013.
  1. 510bg
    510bg Member
    142
    I'm having issues with left over EV range at the end of my commute today I has 5 EV range left when I pulled into the garage. Here's more info on my route.
    Less then 1 mile to the free way start in EV Mode once I approach the freeway I change to HV mode drive 30-40 miles exit freeway change to EV Mode. Drive 2-3 miles reach destination. I was able to regen 2-3 EV miles on my round trip commute. Any suggestion on how to use up the remaining EV before I end my commute?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Switch to EV mode on the freeway. It'll use the battery and operate the gas engine at lower rpm. We call it EV-BOOST.
    510bg likes this.
  3. 510bg
    510bg Member
    142
    I'll try this tomorrow. Thank you
  4. g4_power
    g4_power Junior Member
    105
    I
    Like usb said, use EV on the freeway. Try using HV while accelerating and switch over to EV after you get to the cruising speed. This may give you more EV miles.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    If it is safe to do so you could switch to EV mode 5 miles from home and drive under 62 mph on the freeway. This is what I do. I always have leftover EV coming home and I use it up in the right lanes with trucks that are going under that speed anyway.
    markabele and 510bg like this.
  6. Bonefish Blues
    98
    31
    Oxford, UK
    Every time I see this referenced a bit of me dies inside...
    Darned (as you might put it) Euro-spec PiPs!
    Astolat likes this.
  7. Astolat
    Astolat Member
    229
    73
    Guildford UK
    And the "under 62 mph"... Looks like a mistype to us!
  8. 510bg
    510bg Member
    142
    In was able to go 63-64 in EV mode
  9. 3PriusMike
    3,101
    2,419
    Silicon Valley
    Yes, I think there is a bit of hysteresis from 62 - 65 mph.
    Mike
  10. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Did you use up all EV miles today?
  11. 510bg
    510bg Member
    142
    During my work travels I charged 3 times I got home with 3 EV miles left. I just need to turn on EV Sooner. I just need to program my mind turn on EV LOL.
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    You could try a simpler method. PiP starts in EV mode by default. Don't touch the EV/HV button. Let it do it's thing and it'll use up all the EV miles before you get to work.
  13. 510bg
    510bg Member
    142
    Ill give this a try on my home commute on Friday. I appreciate all the feedback
  14. pwp1943
    pwp1943 PHEV Afficionado
    51
    Boston
    2013 Prius Plug-in
    I’m interested in the “EV boost” idea. It’s not clear to me how it works or how it helps improve mpg at freeway speeds. I usually try to cruise at 70 mph (65 mph limit). At that speed I think the ICE is generating propulsion. How does the battery get involved? Assume there are still 10 miles of EV showing on the display and I will be travelling 25 miles.
  15. 3PriusMike
    3,101
    2,419
    Silicon Valley
    EV boost is when you are in EV mode but you speed up to >62 mph. The gas engine comes on. And then the engine and battery share the work to propel the car. It is a bit difficult to precisely measure the improvement...but you can definely see 70 - 80 mpg, for example on a trip of 20 - 50 miles. If you just drove 10 miles in EV (at less than 62 mph) and then the remainder in HV you might see the same net mpg. But with EV boost you are driving >62 mph (roughly) the whole time.
    Mike
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Prius gas engine is an amazing combustion engine. It can be at near peak efficiency while producing the lowly 13hp (around 1,000 rpm), thanks to the combination of Atkinson cycle and EGR.
    At 70 mph, say you would need ~20hp. The PHV battery can fill in 7hp and keep the gas engine at 1,000 rpm. The flexibility of eCVT makes this possible.
    To my knowledge, EV-BOOST is unique to PiP as it requires an efficient operation at very low partial load. Ford Energi gas engine will not be able to do it since the displacement is larger (2.0 vs 1.8) and the lack of EGR. On top of that, Energi models were geared differently to allow higher EV speed (85 mph).
    markabele likes this.
  17. pwp1943
    51
    Boston
    2013 Prius Plug-in
    So, if I do the speed limit of 65 mph, which of the buttons on the console do I need to push for EV Boost to occur? I have been pushing the HV button because I know the engine will be on at greater than 62 mph. I push the HV button about a mile before approaching the on ramp to make it easier to blend into traffic. I want to have the engine warmed up a bit to give me the increased power I need to avoid the 18 wheelers chugging along at 70 mph. Here in MA, the 65 mph speed limit is just a good idea.
  18. john1701a
    john1701a Prius Guru
    12,833
    5,311
    58
    The button is a toggle. Just press it again to switch back to EV. When traveling faster than 62 mph, the engine will continue to spin but either use less fuel or none at all. It takes very little horsepower to maintain a cruise at 65 mph. You'll see the MPG pegged at 100 even though the engine isn't stopped.
    The purpose of BOOST is to provide more electricity than usual. The result is higher MPG.
    That isn't necessary. Drop the pedal to the floor with the engine still cold. Watch what happens. You can override the 1500 RPM limit that's used for clean & efficient warm-up. That power is there if you need it.
  19. markabele
    5,084
    1,782
    Nebraska
    Please don't do that frequently though.
  20. john1701a
    12,833
    5,311
    58
    I haven't ever actually needed to.
    Someone had to verify it was indeed available; otherwise, we'd have new owners turning on their engines sooner and missing out on efficiency opportunities.
    Chazz8 likes this.
