How to Program a New Key Fob for Full SKS Functionality
Discussion in 'Gen 2 Prius Main Forum' started by usnavystgc, Oct 29, 2013.
  1. exar
    exar Junior Member
    Out of curiosity, how do you register a non-SKS fob so that the buttons work? Is it the same procedure for the SKS fob, except that the non-SKS circuit board wouldn't get a "car ID" burned in?
  2. 08PriusXSJ
    08PriusXSJ Junior Member
    42
    Connecticut
    Sounds so complicated an sorry to hear those troubles.
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    I assume that the same registration process would work. But I've only got a 2006 SKS Prius, and no experience with the non-SKS version. I can confirm that the non-SKS keyfob will not register on a SKS vehicle...(n)
    The SKS circuit board is not just an enhanced version of the non-SKS circuit board. As I recall from 10 years ago, the non-SKS version uses a fully documented Texas Instruments chip, while the SKS version is some other company with no publicly available documentation. And Gen3 is entirely different than Gen2 - it doesn't have a transponder or use a keyslot.
  4. tessar
    tessar Member
    103
    Silicon Vallley, CA
    I am unable to advance beyond Procedure A, Step 3. The red anti-theft light blinks after removing the old fob instead of staying on. I have installed new batteries in both the old and new fobs. If I try inserting the new fob with the red light blinking, then it does not stop blinking.
    Suggestions please...
  5. JC91006
    16,881
    8,621
    Try waiting a couple minutes longer for the lights to turn off
  6. tessar
    tessar Member
    103
    Silicon Vallley, CA
    I was able to execute Procedure A by reducing the time intervals on the cycles. I was thinking this is old technology so it needs long cycle intervals. Such is not the case. Procedure B was a breeze after Procedure A.
    usnavystgc likes this.
  7. usnavystgc
    3,159
    990
    Tucson, AZ
    I appreciate RobH and JC stepping in to answer the questions. Although I know this procedure well, I don't know the ins and outs of too many things beyond that.
    Thanks to both of you!!! :)
  8. CheapSk8
    CheapSk8 Junior Member
    Iowa
    I just successfully programmed a second Smart Key Fob using the instructions in the OP. I had to run through Section A 2 times and Section B 2 times due to my mistakes. Thanks so much.
    Paid $89 on eBAy for my New unused Smart Key w/chrome logo
    Thanks a Ton
  9. WinstonW
    WinstonW New Member
    Sacramento
    I purchased a smart key fob on Amazon and used these instructions to program. I used procedure B, worked great! I did have to repeat step 9b twice - as indicated I may have to do in the instructions.
    usnavystgc and gta_ like this.
  10. RobH
    RobH Senior Member
    2,385
    991
    70
    You need to also do procedure A to program the transponder portion. It is used when the keyfob is inserted into the keyslot in the dash. Works when the keyfob battery dies and you lose the keyfob in your pocket function. Gen3+ (2010+) is different (doesn't use a transponder).
  11. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    I'm going to give this a try on my used fob. I don't figure it can hurt to try. If it doesn't work, I'll shell out the money for a new fob and program it. I'll update when I can.
  12. RobH
    RobH Senior Member
    2,385
    991
    70
    The black logo keyfob doesn't have a car-id programmed into it. I can't confirm it, but I suspect that you can reuse a black logo keyfob without all the games required with the silver logo version.
  13. kevin3
    kevin3 Junior Member
    25
    Sacramento, california
    Works, thanks!!!
    Procedure A on the first try and procedure B on the second try had to hold lock unlock twice.
  14. Bruce Van
    Bruce Van New Member
    Elgin Il
    Three Touring
    Worked 1st time and completed in 5 minutes. Thanks for the instructions
  15. StanFL
    StanFL New Member
    Part A failed and it took me a while to understand why. I had one key fob for our 2008 SKS Prius, and the shell got broken. I replaced the shell before I understood there were two kinds of shells, and loaded my elex and battery into a black keyfob. When I put the electronics into the new shell, I got my SKS functionality back. At the same time, I purchased from a dealer a new SKS keyfob so we could have two working ones. I tried to program it, but step 3 failed and the red anti-theft life just blinked. It actually just keeps blinking, for hours now. Nothing turns it off. I have tried Part A a few times, but then I noticed that the new shell inserted into the slot will not allow the car to start. So, I'm thinking there is some other difference in the shells than just the logo. I"ll order a new silver-logo shell, swap the elex again, and see what happens.
  16. JC91006
    16,881
    8,621
    The shell shouldn't make a difference, it's a plastic shell
    Try to disconnect the 12v negative for a minute to reset the car. It's probably stuck in programming mode
  17. RobH
    RobH Senior Member
    2,385
    991
    70
    There is a separate chip (the transponder) in the shell in addition to the circuit board. Hope you didn't throw it away with the old broken shell...
  18. StanFL
    StanFL New Member
    Thanks for the tip on the shell. Is there any easy way to disconnect the 12v other than digging around in the trunk?
  19. StanFL
    StanFL New Member
    I didn't see any second chip in the shell. I'm looking at the parts now and don't see anything that looks like a chip. Just plastic. Can you be more explicit on where it is and how big it is?
  20. JC91006
    16,881
    8,621
    The trunk is where you would disconnect it. There's a 12v ground connection to the prius body, I guess you can disconnect that for a few seconds. Just need a 10mm wrench or socket
