How to Program a New Key Fob for Full SKS Functionality
Discussion in 'Gen 2 Prius Main Forum' started by usnavystgc, Oct 29, 2013.
  1. SusanS
    SusanS Junior Member
    I checked in 2014 and my SKS was working by the end of my thread. Here we are in 2017 and something has happened to BOTH of my remotes. They are both silver logo fobs, but right now neither one will open the door by touching the door neither one will start the car unless a fob is in the slot.
    Am I out of luck? It says to use the "old" (working) and the "new" (to be programmed) remotes. But I don't have one that the SKS works. Any hints? I am willing to do it numerous times. I got all the way through all the steps (including 9a., 9b., and 9c.) but when I got out of the car, it didn't work. Also, is there any hints about what lights will go on on the dashboard while this it taking place?
    I recently had the car at the body shop and the keys were not used at all while it awaited repairs. Do you think it became unprogrammed because it was not used for about a month?
  2. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    You need to replace the CR2032 batteries in the fobs.
  3. dolj
    dolj Senior Member
    8,652
    4,402
    Wellington, New Zealand
    No, but you never mentioned whether you checked the SKS on/off switch below the steering wheel, in case someone switched it off while in the shop. If it is on then the battery in the fob is the next step.
  4. PriVusLY
    PriVusLY Junior Member
    30
    Appleton, WI
    Big vote of thanks to: usnavystgc | PriusChat
    For future users of Procedure A, follow the tip (that is located somewhere in this thread) to perform the procedure in fairly quick progression, otherwise it doesn't work ... e.g. the anti-theft light won't get to the continuously-on state, or if you get that far and don't plug in the new fob quick enough the anti-theft light never stops flashing
  5. Transtec24
    Transtec24 New Member
    southern Il
    I have a scan tool & fully understand how to use it. also the interlock is installed correctly & fully locked in place. No codes in any of the systems
  6. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    I am selling a 2007 Prius with 2 key fobs.
    I own and am keeping a different 2007 Prius with only 1 key fob.
    My question is --- can I take one of the key fobs from the one I am selling --- and use it / program it to the one I am keeping so that I have a spare?
  7. JC91006
    16,936
    8,647
    You can self program it to start the car in the key slot. If you need sks, you would need to reseed the car and program.
    Yes, it's possible
    MilkyWay likes this.
  8. Baldbubba
    Baldbubba Member
    142
    27
    in PRIUS down by the river
    i have an issue, but not a problem,, did chicken dance worked great, however when fob is inserted in slot it will not doing anything, however take it out of slot an push power button and all is well, car starts fine, sks works great, if i have reached possible limits of number of units has programmed, could that be the problem? purchased fob from a dealer as new fob,, any ideas? it really is not a problem just an issue,, btw the other fob i have still works like it is supposed to.
  9. JC91006
    16,936
    8,647
    There's a programming step for the key slot. It's 2 different steps total
  10. Baldbubba
    Baldbubba Member
    142
    27
    what are those steps?
  11. JC91006
    16,936
    8,647
    First post on this thread, procedure A
  12. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    The "slot" portion of the key does not have a limit on the number of times you can program it.
    usnavystgc likes this.
  13. Baldbubba
    Baldbubba Member
    142
    27
    ok thank u
  14. Jimbolimbo
    Jimbolimbo Junior Member
    17
    Global Citizen with a focus on the western USA
    Success!
    Ordered a new fob direct from Toyota via Amazon Prime $110 delivered in 2 days. Took longer to read this thread than to program the fob.
    I started with one falling apart fob that seem to have intermittent SKS capability. Turns out low battery was at fault for limited SKS function. Then I rehoused the old case with a $14 shell.
    I did have to repeat one step (2005) and at the end you gotta be patient! Wait for the system, let it delay.
    I tried it once with batteries that I thought had a little juice left in them, didn't work full sks. I then put brand new batteries in both remotes, and boom it was like night and day. Worked first time.
    Thank you all, thank you, thank you very much :)
  15. BK310CH
    BK310CH Junior Member
    29
    33
    Niagara Falls
    I
    I need to get this done. I live in fear of losing the one fob we have for my wife's 07.
  16. Queueball
    Queueball Junior Member
    17
    Saline, MI
    2019 Prius
    "Have a 2005 Prius with SKS (Silver logo Key). One of my two key fobs stopped working. indicator light would not come on when buttons were pressed. Replacing the battery did not help. Other key working just fine. I surmised one of the keys was dead and needed replacement.
    I also have a 2005 with silver fob logo and SKS. Years ago one of my two original fobs SKS functionality stopped working so I purchased a replacement but saved the original. This week one of the two fobs in service also lost SKS functionality. In an attempt to reprogram the fob I tried USNavy's very helpful "Procedure B" but to no avail. I also noticed that the red indicator light on the fob no longer illuminated when the lock or unlock button was pressed. While investigating more closely I determined that the panic button had become wedged resulting it in it being always depressed. With a little jiggling and removal of a crust of pocket lint from the perimeter of the red button it returned to its normal position allowing the alarm to engage when pressed for a few seconds. I've never had occasion to use the panic button and had not tested it before. So now I have a working panic button but the real benefit is that all SKS functionality returned to that fob. I checked the original fob that I had retired long ago and found it had the same problem. I freed that button and popped in a new battery and that one is fully functional again! Woohoo!
    A down side is that the red button is now less secure so I expect eventually I will discover it has gone missing. I see sellers on Amazon offering aftermarket replacement fob case ($14) and skins (two for $10) so easy remedies are available.
    Hope this helps someone save $120 on a replacement and the associated lost time.
  17. AVOID92X
    AVOID92X Junior Member
    24
    Daytona Toyota's prices and everyplace else is up around $150+. I reached out to Daytona Toyota, and they said that Toyota had a big price increase on key fobs.
    However, I did find this fob that comes without the key for $111 + $7 shipping, and I can confirm it worked flawlessly. I ordered a key slow boat from China for $2 to fit into the fob.
    OEM TOYOTA PRIUS KEY FOB CLICKER DOOR TRANSMITTER 89904-47011
  18. sleibo1
    sleibo1 Junior Member
    Richmond VA
    This technique is brilliant! Thank you! How did you ever discover this? It worked like a charm. Had to repeat steps 9 2X but worked! Thank you
  19. bpelham
    bpelham Junior Member
    London, UK
    Another success story here. Directions are very clear and I got it right on the first try!
  20. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Where did you find it for $111?
    #440 StephenJ, Sep 3, 2017
