How to Program a New Key Fob for Full SKS Functionality
Discussion in 'Gen 2 Prius Main Forum' started by usnavystgc, Oct 29, 2013.
  1. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Never mind Avoid92x I didn't notice the link when I was browsing on my phone. Lol
  2. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Are these part numbers for all year and models of 2nd gen? I found the 89994-47061 on this website but it has a list of compatible cars and while it specifically shows 2007 base/touring and 2008 base/touring....for 2009 it only says base and leaves out touring. I have a 2009 touring so I'm a little concerned before I drop $125 for it. You can see the compatibility chart at the bottom of the page.... Genuine 8999447061 Remote Control Transmitter for Keyless Entry and Alarm System | PartBull
    Can anyone confirm for sure that 89994-47061 works with a 09 touring?
    Thanks!
    Stephen
  3. carman993
    carman993 New Member
  4. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Well, with my new 2008 Prius the auction I bought it from supposedly lost key....And they made a new one which has SKS functionality..and it works perfectly fine. There is no logo on the back. No toyota logo on back!
    I took a black/silver logo spare key off a prius I was selling...and the good news is procedure 1 was very easy. Took less than a minute and the spare key turns car on/off.
    The bad news is procedure 2 did not work after attempting 3 times. I am wondering if the battery to the key fob is dead? Will report back later. Not sure why I waited so long to add spare...This was a really easy procedure!
  5. dolj
    dolj Senior Member
    8,630
    4,384
    Wellington, New Zealand
    Nope, the problem is procedure 2 will only work on new virgin key fobs. I hear there is a service you can use to "virgin-ise" a used key fob so you can use procedure 2.
    MilkyWay likes this.
  6. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    But only for Gen3 fobs. Whoever figured out how to do it for Gen3 is probably working on others...
  7. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Thanks! I picked up a brand new Toyota OEM fob with key for $125 shipped from partbull and it programmed and is fully functional on first try! Awesome! Great thread! Thanks for taking the time to write it all up!
    usnavystgc likes this.
  8. KiltedGinger
    KiltedGinger New Member
    Baltimore, MD
    How do I know if I have a Gen II prius?
  9. KiltedGinger
    Baltimore, MD
  10. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    2004-2009 years.
    Smart Key System; i.e., you don't have to touch/click the fob to unlock/lock the door nor put fob in slot to start car. FOB case has a silver Toyota logo on back.
    MilkyWay and gta_ like this.
  11. Ben Callihan
    Ben Callihan New Member
    Joplin, Missouri
    At the end of procedure B my lock/unlock cycles twice instead of just once. I guess there are too many fobs assigned to my car? How do I solve that problem?
  12. GYC
    GYC Junior Member
    NC
    I used a used black logo fob to temporary replace the bad silver logo fob (causing alarm to go off ). It works w/ "A " procedure. Thanks
  13. Peter Chicarielli
    Peter Chicarielli Junior Member
    New Jersey
    I purchased a used key off eBay, and found out after that I can't program a used key for the SKS features. Procedure A worked fine, but I wanted to get the SKS working since the car was capable. I then purchased a new key from a dealer and just tried it again. Procedure A did not work, but B did?? So now everything works except when I actually insert the fob in the slot and try to turn on the engine. Has anyone else experienced this??
  14. JC91006
    16,909
    8,631
    You might have too many keys in your system, there's a limit of 5. You have to delete some
  15. Joey Campbell
    Joey Campbell Junior Member
    New to group ... What is SKS???
  16. MilkyWay
    823
    359
    23
    MI
    It means when u approach your locked door with your key in your pocket the drivers door will automatically unlock by the time you reach door handle.
    SKS stands for smart key system.
  17. Farouk
    Farouk New Member
    San Francisco
    Hi there, I'm trying to program a pre used smart key for my 2008 prius, I can start the car now with the new key. However, trying to program the lock/unlock. I followed all the strips. At the end I got the lock/unlock cycle twice which means that the the registration has been fail. Tried to repeat the steps more and more with same result. Could you please give some advise. Thanks!
  18. JC91006
    16,909
    8,631
    You can't program a used key for sks functions. You would need a new key. Or reseed the car
  19. Farouk
    Farouk New Member
    San Francisco
    What do you mean by reseed the car and how to do this.
    Also need to know if locksmith can program a used sms.
  20. JC91006
    16,909
    8,631
    Reseed means to erase all the keys in memory and then program the used keys.
    This requires special equipment.
    If you started with a brand new key, then you can do the programming yourself.
