How to Program a New Key Fob for Full SKS Functionality
Discussion in 'Gen 2 Prius Main Forum' started by usnavystgc, Oct 29, 2013.
  1. PAUL SCHULTZ
    PAUL SCHULTZ Member
    103
    66
    Michigan
    Another success! Thanks for this great write up. Worked the first time through with both Procedures A and B. For step 9c I held the lock button for 5-10 seconds and didn't have any lock-unlock cycle. But, everything worked so all is good!
    Bought my gen 2 SKS FOB online @ PartBull .... Price ~$124 for a new FOB.
    "GENUINE 8999447061 REMOTE CONTROL TRANSMITTER FOR KEYLESS ENTRY AND ALARM SYSTEM"
    Paul.
    usnavystgc likes this.
  2. DonutHands
    DonutHands Junior Member
    Sorry if this is already answered, 25 pages nearly 500 posts is hard to sift through.
    Can Procedure A and C be preformed on a used key fob? This would be for emergencies so Id like to save money on the used key and just leave out the SKS functionality if possible.
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Yes on A. Works for both black and silver logo keyfobs on SKS and non-SKS cars.
    C is for non-SKS (black logo) keyfobs. It will not get you door lock/unlock on a SKS car.
    Raytheeagle likes this.
  4. DonutHands
    Hmm, so is there no way to get button lock/unlock on a used SKS car/fob? I know im SOL on the smart key functions.
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Not unless you use Techstream.
    You will also need to purchase a seed code.
  6. DonutHands
    Well, I guess starting the car and opening the door with with the physical key is better than nothing.
  7. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Or buy a viginized used key.
  8. RobH
    RobH Senior Member
    2,385
    991
    70
    Don't think this is available for Gen2...
  9. SRQ
    SRQ Member
    158
    56
    So I've tried both Procedure A & B and have NOT been able to get it to work at all. I have an '08 with 190k miles with SKS functionality and an original silver logo on the back. I replaced the battery in the FOB. However, I do have an aftermarket shell over my key FOB that replaced the worn out plastic, but that shouldn't affect the chicken dance, should it? I'm considering swapping out the physical plastic shells between the two to experiement.
    I've tried both procedures with the FOB with a new battery, with the SKS button pushed in and out. The hangup steps are:
    Procedure A: 3. Remove old fob from slot. Car is in fob programming mode at this point. Red anti-theft light remains on. When I perform this step, the Red anti-theft light does not remain on, it simply continues to blink.
    Procedure B: 7. Without pressing the brake, press power button, wait a second, press it again, wait a second, press it a third time to turn car back off. When I press the power button, nothing happens, both with the SKS button turned on and turned off.
    I'm very good at following instructions, and although a little convoluted, I can follow these to the "T". However, it seems that I'm either doing something wrong procedurally or there is another factor at play.
  10. JC91006
    16,936
    8,647
    On procedure A, when you remove the old fob, you then insert new fob. Once programming is completed, the light stops flashing. Takes about a minute
  11. SRQ
    SRQ Member
    158
    56
    The problem with Procedure A is that the red anti theft light continues blinking after the procedural steps prior to that point; I can't get it to stay steady in order to be able to put in the new FOB.
  12. JC91006
    16,936
    8,647
    There is a limit of 5 fobs that can be stored into the car's computer. But I'm not sure if the Procedure A ones have a limit. I think only the SKS procedure B parts are limited.
    I've done this many times and it's worked as stated in the instructions. Maybe you can try to reset your car and then continue?
    To reset, disconnect your 12v negative terminal for 1 minute and reconnect. After you reconnect you will have to reset your radio stations, clock, and auto window for the driver.
  13. SRQ
    SRQ Member
    158
    56
    I'll give resetting the car a shot; it is unlikely that the 5 FOB limit has been reached as I purchased the vehicle when it had 27k miles and have had it up until the current 190k.
  14. strawbrad
    953
    1,007
    When I tried this years ago I had a problem with a sticky door switch. When I opened and closed the door a bunch of times the switch remained closed. You should here the door chime when opening and closing.
    ITBland likes this.
  15. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    When you changed the key shell, did you move over the RFID chip as well as the PCB?
    The RFID chip sits at the front of the back half of the shell.
    #495 dolj, Jun 15, 2018
    ITBland, JC91006 and PAUL SCHULTZ like this.
  16. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    I have a non-SKS 2004. When I looked at the keys using TechStream, there were 5 slots. I reset all and reprogrammed my original fob and added two more.
  17. SRQ
    SRQ Member
    158
    56
    No, I did not. I think I still have the original shell; if I can't find it, what are my options at this point?
  18. dolj
    dolj Senior Member
    8,635
    4,389
    Ok, that is the reason, you are having problems. The RFID is required start the car in slot, and is required for the chicken dance.
    Not good, you will be in for a very expensive new key at the dealer. It would be better all around to find the old key shell.
    Or, put up with no "key-in-the-slot" functionality.
  19. RobH
    RobH Senior Member
    2,385
    991
    70
    Search for a locksmith who can handle an "all keys lost" situation on a Toyota. Pop-A-Lock is a chain that has the resources, although it still comes down to the individual locksmith.
  20. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    I just did the chicken dance successfully tonight! It took some time but I’m glad it worked. Thank you so much for the detailed instructions!
