How to program a non-sks 2008 Prius fob without original
Discussion in 'Gen 2 Prius Main Forum' started by r619, Dec 23, 2013.
  1. r619
    r619 Junior Member
    38
    Atlanta, Georgia
    I recently purchased a used 2008 Prius that does not have the black square on the door handle and I have to put the fob in the slot and push to start the car. So I guess it is a non-sks. It came with two key fob. One was with black Toyota logo on back and had a metal key inside it. I can lock/unlock the door and can start the car. The other one had silver Toyota logo on back and it was missing the metal key. I can only start the car with it, but cannot lock/unlock door remotely. I recently lost the fob with black logo and metal key. So with the fob with silver logo I can only start the car but cannot lock the door, which is dangerous. I know I can program a second key if I have one that is working. But in my case I only have one key now and that does not work. So is there anyway I can program it without the original? If not I am looking for the cheapest way to make it work. Will buying a metal key help me other than physically using it to unlock doors? Or should I just pay a dealer to program the fob that I have. Any feedback will be appreciated.
  2. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    you should take it to a dealer and see what your options are
    when I purchased my car, it came with a little silver ID on the keyring which had a code on it
    I am assuming you do not have that
    I once heard if they had to 'program' a new set of keys from scratch, that it was over one thousand dollars - not sure what it would be today. Just getting another fob and programming it - is several hundred dollars.
    Good Luck!
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
  4. usnavystgc
    3,159
    990
    Tucson, AZ
  5. r619
    r619 Junior Member
    38
    Atlanta, Georgia
    Thank you. I have tried that earlier, but it requires me to have a key that works already. I have lost mine. The one I have can only start the car.
  6. usnavystgc
    3,159
    990
    Tucson, AZ
    Then the dealer or a locksmith is your only choice. I personally would look very hard for the missing fob. It has to be somewhere but, I'm sure you have already done that. Beyond that, its a tough fix for a DIYer.
  7. OMG
    OMG Junior Member
    69
    what does the "little silver ID on the key ring means"? I had it when I got my car but didn't think anything of it. I hope I didn't lose it.
  8. JC91006
    16,936
    8,647
    I believe the silver ID ring is used to cut a new "metal" key. It has the key information for the dealer to make another key. It's not used to duplicate a lost key original key.
  9. usnavystgc
    3,159
    990
    Tucson, AZ
    Yes it is the number sequence to set up the key cutting machine at the dealer. It allows them to cut you a duplicate mechanical key that will open the doors if your fob quits working.
  10. Emilblu
    Emilblu Junior Member
    Wind Lake, Wisconsin
  11. OMG
    OMG Junior Member
    69
    Ok thx, I need to find that little silver ID and hang on to it. I thought it was something left over by the dealer.
  12. JC91006
    16,936
    8,647
    I think if you provide your vehicle VIN# to the dealer, they would have on file the information to make a duplicate metal key. I don't think it's important to have that silver ID, may just be something to use at a locksmith.
    OMG likes this.
  13. OMG
    OMG Junior Member
    69
    Glad to hear because I looked for it but I couldn't find it.
