How to properly mod front HID headllight?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ian2002525, Jun 16, 2015.
  1. ian2002525
    ian2002525 Junior Member
    22
    Nashville, TN
    I have a 13 prius, I don't like the factory yellow color low beam light.
    What's the best/proper way to make the low beam color to sharp white light? (5000k)
    I'm just thinking to get a set of HID bulb from ebay:
    HID Replacement Bulb 2pcs All Color H11 9006 9005 H4 H7 9007 H13 H10 880 H3 H1 | eBay
    But I'm not sure the outcome would be great by just simply changing out the low beam bulb to a 5000K one.
    If anybody done this and know what the best way to do it, please share with us thanks!!
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    You can't just put HID bulbs in the oem headlights. You need a kit with bulbs and ballasts, minimum.
    From the item linked in post above, item description:
    "I'm confused!
    Can I just buy these bulbs if my vehicle has factory halogen bulbs?
    Negative. You need an HID conversion kit already to buy these bulbs. These bulbs are for people who already have HID ballasts (aftermarket type with the shown connector)."
    #2 xliderider, Jun 16, 2015
    Priusguy78213 and sfv41901 like this.
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    #3 sfv41901, Jun 16, 2015
  4. ian2002525
    22
    Nashville, TN
    Thanks for everyone's input, I thought our Prius has factory HID headlight LOL...
    So should I go 35W or 50W? 5000k or 6000k ??
  5. alekska
    alekska Active Member
    435
    138
    Atl
    35 W is just fine.
    As for the color temperature:
    4300 K - OEM on most cars, highest output, just white
    5000 K - lower output but more bluer color
    6000 K - even lower output, blue color, hard to see in rain and fog
    You choose.
    - Alex
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    35w @ 5k
    Snt rom VS984GusiTaatalk
  7. putty
    putty Member
    147
    39
    somewhere in the swamps of Jersey
    #7 putty, Jun 16, 2015
    Priusguy78213 likes this.
  8. Markee
    Markee Member
    336
    South Florida Broward County
    I also have a 2013 I'd want to upgrade to which ever one will give me the best visibility ?
    Can someone that has actually used them please chime in with some wisdom
    I don't have a clue on which one to go with
    Also is theres any link to a walk through on how to install maybe a video ?
    #8 Markee, Jun 17, 2015
  9. ian2002525
    22
    Nashville, TN
    What's the main difference between $50 ebay HID conversion kit VS. $100+ brand name HID conversion kit??
    Both are 5000K bulb and 1 yr warranty.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I would have to say quality & customer service is the main difference
    DDM sells HID kits under $100
    TRS sells HID kits over $100
    Quality & Customer Service is what separates these 2 companies
    VS980 4G ?
  11. Spooled
    Spooled Member
    142
    26
    Concord, CA
    The main difference is the price
    I have a 55w 5000k kit that im running w no relay that i paid 50 for 0 ZERO problems and lots of miles and time at night. Light output is fantastic
    Accordlayingkit likes this.
  12. xliderider
    8,140
    3,280
    Honolulu, HI
    Care to share a link, or name the manufacturer and kit?
  13. Spooled
    Spooled Member
    142
    26
    Concord, CA
    I think its Inovative on amazon
  14. xliderider
    8,140
    3,280
    Honolulu, HI
    Innovited?
  15. Spooled
    Spooled Member
    142
    26
    Concord, CA
    yea thats the one very high quality kit
    xliderider likes this.
  16. Markee
    Markee Member
    336
    Is there a big difference upgrading to this from the H9 Mod ?
  17. xliderider
    8,140
    3,280
    Honolulu, HI
    I'm deliberating whether to upgrade to HID on my Camry. The H9 bulb upgrade gave me a 50% upgrade in light output, but it's not as bright as on the Prius.
    The reason is that the operating voltage on the Camry is about 13.5v; whereas the Prius operates at about 14.4v off the DC to DC inverter.
    I'm going to make a 14 awg relay wiring harness and tap power straight from the Camry's battery to the 65w H9 bulbs. This, in theory, will increase the available amperes (current flow) available through the H9 bulbs. The oem lowbeam headlight wire gauge in the Camry seems thinner than the ones in the Prius. I'm hoping it results in brighter output, if the wiring is a limiting factor.
    If I don't get the desired output, I'll upgrade to 35w HID using the custom relay wiring harness.
    But to answer your question, a 35w HID kit might give you a 50% output increase over H9, or double the oem 55w H11 halogen bulbs. The 55w H11 HID might give you 3x the oem H11 output.
