How to properly tip-off Your A/C (!! NOT !!) Pt:1
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lech auto air conditionin, Jul 22, 2019.
  1. lech auto air conditionin
    830
    606
    261
    san francisco
    Here is just another example of how not to top off your AC refrigerant charge with a little Can from the auto parts store with a little low side gauge. Vehicle had a nearly plugged filthy cabin air filter. even if it was possible to properly top off your AC refrigerant you would never be able to do it correctly with a partially plugged cabin air filter airflow is in central and directly correlated with the low side pressure of your refrigerant . This vehicle had over 800 g in a 520 g system he also has a condenser that’s extremely oxidize the aluminum fins are falling apart .
    Three part series the problems associated with using small cans of refrigerant and a filthy cabin air filter.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Where are parts 2 and 3 of the video?
  3. lech auto air conditionin
    830
    606
    261
    san francisco
    They are coming No time I’m working Will upload later tonight
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    this thread title really needs to be brushed up.
  5. lech auto air conditionin
    830
    606
    261
    san francisco
    Just noticed that (tip off) oops , should be (topped off) that’s what happens when you’re working and driving at the same time while writing .
    After I posted I cannot find the edit option that will let me change the title. If somebody can aid me or guide me in the process to change the word ( tip to Top ) I can edit the core text but not the title
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    You’re putting people lives in danger, it can wait.
