How to Pulse and Glide?
Discussion in 'Prius c Fuel Economy' started by highroller, Mar 10, 2014.
  1. highroller
    highroller Junior Member
    79
    I own a Prius C 2013. I read about Pulse and Glide, and I also watched youtube about it. I somehow have never seen a situation where there is no arrow in the Energy Monitor. The best I have ever seen is arrow coming out of the battery only which is EV mode. Some people say 35-45 is the best speed for P&G, but I never see "no arrow". What speed makes the car run without arrow?
  2. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    It's not so much the speed but your foot relative to the accelerator pedal position. You really need to feather the pedal so there is no arrows flowing from anywhere. Elevation changes, road surface conditions, weather and a whole host of things compound the situation.
    Driving at between 35 and 45 mph is probably the easiest way to force the car into a glide when learning. Once you master the accelerator, you can do it at almost any speed.
    Technigogo likes this.
  3. drysider
    drysider Active Member
    823
    337
    Liberty Lake WA
    Glide is not so much about the energy flow as running with the engine off. It is possible to get zero charge/discharge to the battery when gliding, but it takes a steady foot and some experience. Using some of the battery (discharging) helps extend the glide.
  4. highroller
    79
    I tried again today, and I could barely get 2 seconds of "no arrow". The second best I could do is having arrow flowing from the battery. But it's not good enough because eventually the battery is going to run out.
  5. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    Rather than watching the arrow display, I find it easier to moniter the HSI. Glide is no indicator in the brake or in the power.
    SCH-I545 ?
  6. highroller
    79
    There are whole range between brake and power, and I am certain that it's not glide in the whole range.
  7. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    Brake and the three sections that are "not brake" I don't feel like going out to my car to see what they are labeled.
    SCH-I545 ?
  8. Emcguy
    Emcguy Member
    177
    29
    Australia
    It's more a conceptual thing. Don't be afraid to use gas to get up to speed but also don't forget to release and depress the throttle once the target speed is reached to trigger EV. I would class anything below 50% on the HSI as a glide. Obviously the less throttle you can get away with, the longer the glide can last.
  9. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    You will see this best on a long gentle downhill run, where gravity and wind resistance about cancel each other out. Your speed will be steady, up to about 42, and the ICE will be off. If your foot is off the pedal you will get a little regen (arrows to the battery ). Feather the gas pedal just a little to get no arrows.
    GT-I9300 ?
  10. highroller
    79
    No, anything below 50% is not a true glide because arrows are coming out of the battery.
  11. highroller
    79
    so it means glide is possible when there is no Yellow and no Blue when it is at exactly zero? But the car will slow down very fast even if it is up at speed limit in city driving.
  12. bisco
    52,863
    it's next to impossible to glide in the current generation of pri. if you get the indicator just above regen so you are sure you're not slowing down, the electrical use is minimal and constitutes a true glide. this will not wear your battery down unless you can pull off a couple miles of it. ken from japan (master hypermiler) recommends this method.
  13. Emcguy
    Emcguy Member
    177
    29
    Australia
    No arrows is effectively neutral, this will cause the car to gradually slow and annoy / endanger other traffic. I wouldn't recommend driving like this.
  14. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    I find it pretty easy, myself. Here is a short video. The road is a slight descending grade. The speed limit is only 35. If your car slows down too much then "pulse" if bit to pick up the speed. Try to stay in the bottom half of the ECO band "EV" during pulse to maximize the fuel economy, then "Glide" again. As you can see, it is easy to maintain lower speeds with just a slight downhill using the Glide technique. The Prius is simply designed for it.
  15. firstrival
    firstrival Member
    102
    Why is there no "EV" indication when your ICE is off?
  16. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    2010 model does not have that
    SCH-I545 ?
  17. highroller
    79
    Right before I glide, do I need to release the accelerator completely then reapply accelerator just above regen? or do I just raise my accelerator foot til it reaches just above regen?
  18. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Release then quick re-apply to ensure the computer controlled throttle allows the engine to idle/shut off.
  19. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I've found there to be a certain "feel" just at the transition from "power" to "over-run" as you take your foot off the accelerator, and after a while, it's possible to get it "just right" each and every time! (…of course, YMMV ;) )
  20. bisco
    52,863
    notice how technigogo's bar is either off or slightly to the right? that's what you want. slightly to the left slows you down too much.
