How to put Gen1 Prius into Neutral with dead battery
Discussion in 'Generation 1 Prius Discussion' started by 3prongpaul, Jan 5, 2013.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    728
    Boulder Hybids, Boulder, CO
    I'm sure it's been mentioned before, but if you need to put an 01-03 Prius into Neutral with dead battery (i.e. to push the car so you can reach it with jumper cables) you need to remove the rectangular panel on the bottom drivers side of the steering column. It's tiny, smaller than a postage stamp. Use a strong pen-knife or very small screwdriver to pop the panel out.
    You may want to remove the panel when things are good, so if you ever have to use the gearshift release you don't have to hunt around for a knife since it's on pretty tight from the factory. (just leave it off once removed).
    Once panel is off stick a finger into the hole and voila, shifter will move into neutral (or any position) without power.
    BTW, Gen2 Prius (2004-2009) use a fully electronic shifter. No easy way to get car into neutral without power.
    LDT08, slimfrancis, scotman27 and 2 others like this.
  2. youngnbald
    youngnbald Junior Member
    66
    Bloomington, Illinois
    2001 Prius
    I
    Good info to know!
  3. ChapmanF
    17,347
    Another thing you can do when things are good is try whether you can reach the release lever without disturbing the little panel, just by squeezing a finger around the end of the column shroud. I tried that when I first got the car and, with my fingers at least, it's not a problem, as long as I don't mind the indentation left on my finger by the plastic shroud.
    -Chap
