How to recharge your traction battery While in drive mode
Discussion in 'Prime Main Forum (2017-2022)' started by Pdxprimeguy, Apr 25, 2019.
  1. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    The other thing to keep in mind is that charge mode charges the pack faster than plugging in.
    Somewhere around twice as fast.
    Than charge mode stops charging at 80% of the charge the pack gets when plugged in.
    I'm still figuring how many Kilo Watts are in the EV portion of the pack --
    around ~ 6.3 Kw from charge source when plugged in and
    around ~ 5.5 Kw usable to the tires -- in EV mode.
    Than there is the Top of the pack that is never used
    around ~ 15% of the pack total capacity or
    around ~ 1 Kw
    And the bottom of the pack
    around ~ 15% of the packs total capacity or
    around ~ 1 Kw some of which is used in HV mode when there is no EV mode charge left.
    as shown above both the packs total Kw and % of charge don't add up perfectly yet,
    but it's close enough for me so far.
    Pdxprimeguy and mr88cet like this.
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I haven’t used it enough to personally confirm this, but yes, that’s a interesting observation.
  3. vvillovv
    4,321
    1,510
    NY
    It only takes a few tests with no traffic to get a close reference.
    2 hours to full charge
    Drive in EV until that charge is used up
    Put the Prime in Charge Mode and drive until it stops charging
    Don't watch the mpg gauge while testing :D
    bruceha_2000 and Prius from Dad like this.
  4. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Here's lots of detail for you to add to the understanding of how it all works:
    Tideland Prius and vvillovv like this.
  5. mr88cet
    2,313
    1,335
    Austin, TX
    From what I’ve seen in the 2-3 times I’ve used it, Charge Mode charges up to 80% (and I think I saw that documented in the manual too).
    Pdxprimeguy likes this.
  6. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    That is correct.
  7. Trollbait
    12,534
    Charge mode is DC charging.
    In some markets, like Japan, the Prime gets CHAdeMO, and can use DC chargers.
  8. vvillovv
    4,321
    1,510
    NY
    Besides the other things, I notice the pack temp only went up 5* F
    I've watched the clip about 10 times both above and at youtube
    and I still don't get all the stuff being shown... I also have the hybrid assistant and have
    logged 3 trips all in EV mode so far.
    hybrid assistant shows a lot more in HV mode than in EV mode.
    maybe one day an app will show what mg1 and mg2 are doing both in EV and HV modes.
    If both mg1 and mg2 can work as drive motors I wonder if they can both work as generators under
    specific circumstances.
    thanks for sharing another great video
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    One other time I might use charge mode. To put maximum range in car. Charge battery in charge mode, fill up with gas afterward and you will have about 25 miles reserve range in the battery. Handy when headed out in the boonies.
  10. mr88cet
    2,313
    1,335
    Austin, TX
    The 2-3 times I’ve used Charge Mode was on a trip back from Houston: The battery was empty, but I had a fairly-full tank of gas, initially.
    Since, other than such (fairly-rare) road trips, I pretty much always drive on EV, I try to not to start with much more than a quarterish tank of gas when I begin a many-month stint of mostly-EVing around town. I don’t want the gas to get too stale.
    About half-way through those return trips, it became obvious that I would land home with a depleted battery and a too-full tank. Soooo.... Charge Mode!
    #30 mr88cet, Apr 26, 2019
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    I almost laughed out loud. That's jacket weather for my wife and I'm practically in heaven at those temps. :LOL:
    jb in NE likes this.
  12. vvillovv
    4,321
    1,510
    NY
    I'm still mostly guessing what mg1 and mg2 are doing. I saw a bit with scanguage in the PiP, but prime is all different.
    Getting used to new gauges showing up in place of gauges you are used looking at most of the time can be challenging at best.
    So can organizing longer trips when most of the driving is only in EV mode. Don't ask how I know - OK !
  13. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    CHARGE MODA rocks! Just Did a 210 mile trip. I Was able to get about 50 EXTRA miles on electric after the initial pre charged 25 electric miles. After the trip, It Used only 2 gas bars. Will do another trip in 2 days. I highly recommend it if you want to save gas. Never used such little gas on my road trips. The computer doesn’t compute the MPG accurately but it will show on how much gas you used.
    Raytheeagle likes this.
  14. mr88cet
    2,313
    1,335
    Austin, TX
    Actually, I have found Charge Mode useful in one particular way:
    I generally go to the gas station once every couple months or so, at which time I put in a couple gallons or so. That, since I drive around town pretty much entirely on EV, and road trips are historically rare. I don’t want to let the gas in the tank get too stale, over long spans of time driving EV.
    When I do take road trips though, I sometimes find that I have more gas left in the tank than I’d ideally like. If so then, I often will kick it into Charge Mode to trade that leftover gas off against my first charge upon getting home.
    Tideland Prius likes this.
  15. Tideland Prius
    16,555
    It’s also useful if you want to run Remote A/C since you have to have EV charge left for that feature to be available. CHG Mode can help top up a little so that you can run remote A/C.
  16. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    You aren't saving gas. You are exchanging energy from the ICE (gas) for EV range later. It's all coming from your fuel tank assuming you start with a depleted HV battery.
    mr88cet likes this.
  17. phlack
    phlack Junior Member
    32
    2020 Prius PHV
    Old thread, so hopefully someone sees this.
    Does the car have to be moving in order to charge the traction battery? Or can I just put it in charge mode and idle the car (the charging coming directly from the engine)?
  18. john1701a
    12,817
    5,303
    58
    Leaving it in idle works fine, but it's the least efficient. The engine under a load (any speed) would be better.
  19. mr88cet
    2,313
    1,335
    Austin, TX
    Yeah, the car is more efficient to just drive it as a hybrid than to charge the battery this way and then drive on electric with the resulting battery charge. (I’ve measured it.)
    There’s only one scenario I’ve found where charge mode is worth it: 2-3 times I’ve driven back to Austin from Houston, and found that I’ll end up with too much gas in the tank. “Too much gas” in the sense that, in town, unlike on such a road trip, I drive almost entirely on electric. I therefore rarely tank up with more than 3/8 of a tank, or else the gas will just go stale in the tank. So, those 2-3 times, rather than leaving too much gas in the tank, it’s better to burn it and not charge up when I get home.
    #39 mr88cet, Jul 29, 2020
  20. Glenn G
    Glenn G Member
    117
    63
    North Andover
    2018 Prius Prime
    I always learn something from this forum, thanks!
    My take on this is:
    1. Use the charge mode to get the heat operational on cold days Brrr, thanks, those heated seats are nice, but take a while to warm up!
    2. Use the charge mode on highway to charge the battery. At my locus the break even v.s. ICE is ~$3.00 / gallon.
    Gas is still less than $2.00 / gallon in these parts, so it makes sense to use this feature, at least for now.
