How to recharge your traction battery While in drive mode
Discussion in 'Prime Main Forum (2017-2022)' started by Pdxprimeguy, Apr 25, 2019.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    From a $$$ perspective, it might make sense, but from and efficiency perspective, probably not. As of right now, in our particular case , $/mile is about the same between hybrid and EV. Normally, charging from home is about 40% cheaper per mile, but as you pointed out, gas prices are currently low.
  2. thymara
    thymara Junior Member
    59
    Edmonton, Alberta
    2020 Prius Prime
    Things I don't know. How efficient is plug-in charging? I know the capacity of the traction battery but how much electricity is actually required to fill the battery according to the electric company.
    Since DC charging in charge mode is ~ twice as fast as AC plug-in charging does that mean that the cost of gas to charge is actually cheaper relative to plugin charging assuming that, based on rates, the costs are equivalent (obviously not true in all cases, only this special case)?
    Watched the .81/100 km video. Highway driving, especially on single lane roads at half or less than the speed limit, should, at a minimum, get you a ticket and in some places could result in road rage and even death. The information gained appears to be so impractical as to be useless.
  3. Salamander_King
    Salamander_King Senior Member
    11,016
    8,949
    New England
    I don't use CHG mode to charge the traction battery, but instead, I use HV mode to charge the traction battery. In my routine ~18 miles commute trip I can gain up to 10% of SOC.
  4. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Charge-Mode for using up winter gas (haven't filled the tank since February) is a unique situation.
  5. CharlesH
    2,796
    1,163
    Roseville, CA
    Not disagreeing, just adding: There are very few cases where CHARGE mode is more efficient than just using HV mode. You are burning gasoline either way, but in CHARGE mode you are using the gasoline engine to turn a motor/generator to produce electricity to charge the battery, and the charge is later used to move the car via the motor/generator. Two conversion losses. In HV mode, you are using the gasoline engine to directly move the car, with some of the energy being used to put energy into the battery, to help keep the gasoline engine running at its peak efficiency. Unlike electric motors, the efficiency of gasoline engines depends a whole lot on their speed and load, and HV mode helps keep the gasoline engine operating in that "sweet spot", and be turned off altogether otherwise.
