How to reduce wind noise...easy too.
Discussion in 'Gen 4 Prius Main Forum' started by Southern_nj, May 8, 2017.
  1. Southern_nj
    Southern_nj Junior Member
    New jersey
    I have a brand new 2017 Prius 3. I ended up complaining to the dealer about the excessive wind noise around the drivers side window area. After leaving my car for the day at the dealer I came back at the end of the day with even more noise starting at 33 mph post their repair. I then started pushing in the gasket around the small triangle window and noticed the wind noise was reduced. I then took black electrical tape and taped the outside window and trim area completely. What a difference. It was so impressed with the reduced sound, I even taped the passenger side as well.
    Dealer update
    I called my dealer and told him about my fix and since then they ordered a brand new window and will hire a glass installer for the fix. Not too sure I want the factory OEM window taken out and a new window reinstalled.
    Has anyone else had the same wind noise if so, how did you fix it.
    goldfinger, RCO and bisco like this.
    49,492
    that's a new one, well done!(y)
    RCO likes this.
  3. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    Interesting fix - could you please post pics?
    BTW: I have instead a noise coming from the steering column/behind the steering wheel, above 60km/h // 40mph, essentially linked to specific rpms of the ICE and ambient temperature. I don't hear it with music on, otherwise is driving me insane. Talked with my dealer and said that they would have to open up everything, and I really don't want that! (because then other noises will come up!)
    RCO likes this.
  4. goldfinger
    goldfinger Active Member
    535
    402
    Buffalo
    Ditto on the pictures.
    Concerning the steering column noise take a look here. a Steering issue in gen 4th 2016 | PriusChat
  5. Dan in Easton
    Dan in Easton New Member
    Easton, MD
    2018 Prius c
    Is there anyway you can post photos of how you put electrical tape on the outside window and trim area? Thanks, Dan
    RCO likes this.
  6. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Welcome to Prius Chat Dan! (y)
  7. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    That's what happens when you go and put the steering wheel on the wrong side :p
    padroo, RCO and alanclarkeau like this.
  8. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    But it is on the right side when they're reversing @kithmo .
    kithmo likes this.
  9. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    only if they're sitting in the back, then they're at the wrong end.:eek:
    RCO likes this.
  10. padroo
    padroo Senior Member
    2,763
    2,250
    I normally don't notice wind noise but now that you mention it I do hear some around the drivers door.
    RCO likes this.
  11. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    I find road noise on some metalled surfaces is very invasive.
  12. pilotgrrl
    pilotgrrl Senior Member
    891
    1,796
    Chicagoan in TX
    The buffeting is worse than my Gen 2, but overall, it's a quieter car, although the Powers That Be groove all the paving here. I think it's because people can't deal with driving in precipitation.
    RCO likes this.
