How to refill refrigerant.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vallesj, Aug 22, 2024.
  1. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    If you look on air conditioning cooling charts and all that sort of stuff you will see a target temperature for the outside relative humidity and outside temperature being in a range and so on In most cars where it's real hot if you've got 54° or colder air coming out of the vents you're probably in pretty good shape most of my cars are pushing like 46 something like that seem to be working fine I'm sure they're not overcharged if anything they're a tad under The electric compressors the minute you get a little bit overcharged if you're into any of this at all you can hear the compressor start to load up and chug almost like a freight train at that point you just give up a few shots out your yellow hose if you have a reclaimed setup you can shoot it into there 134a a couple shots into the air never going to hurt anybody so there you go and then like I say in your vehicle depending upon where you are and the kind of driving you do lots of bouncing the car around and whatnot You're going to need to top off about every 18 to 24 months If you run the air regularly Mobile systems and systems like this are allowed to leak and allowable amount there's data on this all over DuPont's site and other sites this is just part of the use of gases whatever they are refrigerant or otherwise so there is an allowance that is allowed You're shooting for nothing but you know there is a tolerance o rings gaskets people not connecting the gauges the same way all that stuff leaves room for something to escape even if it's minute.
  2. vallesj
    vallesj Junior Member
    98
    So yes, it is fine that way, and I can check probably a year later if need to add more. But If I got balls to try the "train-chug" compressor behavior; the hose I got from walmart only connects to L, so it is there where I may need to press it to let escape the small, but still allowable by EPA gas?
  3. Tombukt2
    13,864
    2,519
    Durham NC
    Yeah I'm using manifold gauges so I can see the high side and I've got a valve that allows gas to escape and for other gases I have this thing that turns the gas into a liquid and all of that like I said I just run it up until a thing just barely starts to labor two shots out leave it all connected running about 20 minutes Make sure everything is smooth and nice no funny business and this is being done on a very hot day preferably
  4. stokesey
    stokesey Junior Member
    93
    Southern Cal
    I'm revisiting this thread as I'm trying to re-gas a new AC compressor on my 3rd gen. It seems this can be done "by feel" but there are pretty tight tolerances. I've pulled -30psi vacuum and then very slowly added around 8oz of refrigerant. I'm using the sight glass method, giving her little toots every 60s or so. I do hear the compressor kick on and then my low side drops to -10psi vacuum. At that point the sight glass tends to stay full after a shot. Not blowing too cold yet so I guess I slowly add until I feel joy?
    #1 goal here is to not blow my new compressor. Thanks for any tips.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    You need 16.64 ounces of pure r134a and up to 4.5 ounces of ND-11 refrigerant oil, depending how much was in the compressor.
    #25 rjparker, Jul 30, 2026
  6. stokesey
    93
    Southern Cal
    Thanks, you saved me from needing to convert grams to ounces, web says 470g. Compressor is a semi-reliable rebuild pre-filled with oil. And figured don't mess with it as I know its expensive sh*t and the level is touchy. Blowing cold now with very close to 470g loaded in.
    I notice low pressure side rockets up to 50-60 psi if I shut down, so I am guessing its better to stay in maintenance mode while gassing her up? Also no sight glass activity for the last half of my charge. Low side around 10-20psi as I add it. My high side gauge is proving unreliable, won't go over about 120psi. So I am using scan tool. 900kPa which I guess is around 130psi. Still would prefer that value to be higher. Compressor went as high as 8000rpm, now is riding around 7k.
    Crossing my fingers I got this right but I will keep a close eye on the pressure readings. Thanks for the help.
    Final note to others on this path: if your refrigerant is low, it appears that the compressor won't kick on in regular gas and hybrid mode (foot on gas etc). Maintenance mode kicks it on again.
  7. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    Not possible.
    Maybe ~30 inches Hg.
  8. stokesey
    93
    Southern Cal
    Pedantic, but true. I never noticed that my gauges switch from psi to mmHg on the negative side. Also they say RETARD above 300psi:eek:. Who are they calling a retard? But maybe that's what happens when you get that much pressure(y)
  9. stokesey
    93
    Southern Cal
    Oh one more thing, I'm doing a postmortem on my AC compressor, does anyone know the name of the security fasteners that secure the cover on the electrical side of the unit? They look to be somewhere in between hex and e-torx. 6 lobes, but not quite e-torx. Can probably force them off but I figure do the job right if I can.
    The connector reports about 1.2megaohms, apparently this is low enough to take down the entire hybrid system as it reads as a ground fault. 200V supply so I guess that makes sense. Forgot to test resistance on my new unit.
  10. stokesey
    93
    Southern Cal
    Looks like they're either Torx plus or Torx paralobe heads
  11. Tombukt2
    13,864
    2,519
    Durham NC
    You just gas it up like a regular system you don't sit in negatives on lo you gas it up to get it to 37 or so psi on lo side steady fat hose is cooooold.
  12. stokesey
    93
    Southern Cal
    Lol, thanks, I was paranoid so I brought it up to pressure really slow. I heard so many people say "if you're an ounce over you'll blow the compressor because it's 3 stage" or whatever. Also some said you won't use a whole can of refrigerant. Must be they have 16 or 20oz cans because in these parts getting 12 ouncers and it takes 1.5 of those to fill it.
    Your comment about the train chugging hit the mark. The second I heard it I gassed off a couple toots. Also it seems that running the system a little low on gas is better than overcharging.
    Once I started getting data w the scan tool I felt better as well. Helps to know what the system is doing.
  13. stokesey
    93
    Southern Cal
    Postmortem on the AC compressor complete. Pretty confident that the control board got fried.
    The case had about 2 drops of coolant in it. Possibly they triggered the ground fault detection in the hybrid system incorrectly? Too late now as this component is not serviceable. It's assembled with lots of epoxy and thermal paste.
