How to remove and install EXTERIOR pillar panel (photo inside).
Discussion in 'Gen 4 Prius Accessories and Modifications' started by LyssaChap, Apr 8, 2020.
  1. LyssaChap
    LyssaChap New Member
    St. Louis, MO
    Good afternoon, all!
    I bought a newer'ish 2017 Toyota Prius II and its in perfect condition, except it appears one of the exterior trim panels (part # 62505-47011 - that black triangular shape in the middle of the photo, but on my right passenger side) got scratched up and the clear coat is peeling off at the sight of that scratch...
    I have a local place who will order the part for me but I cannot find a video on how to install as right now -things are weird and we are in quarantine so ultimately I wanted to try to do it myself... if you all say its a terrible idea to attempt it myself - I will wait until post-quarantine and have it done by the shop but the labor is pretty pricey, unfortunately.
    Thanks for your help!
  2. krmcg
    2,592
    2,393
    Whittier, CA
    It just pulls straight off. There are some plastic clips and some double-back tape so there is some resistance. grab at the front edge and pull "out" and back... it's easy!
    alanclarkeau and bisco like this.
  3. Mendel Leisk
    42,365
    And, there's a lot of those peeling. Was it a recall item or no? Maybe not.
    alanclarkeau likes this.
  4. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    Yes I seem to remember that some dealers were replacing them FOC.
    alanclarkeau and Mendel Leisk like this.
  5. LyssaChap
    St. Louis, MO
    Interesting... thanks for the tip.
    Are we talking like bottom edge or the side edge that’s exposed when the door is open? And do I need a butter knife?
    Maybe there is a video but I’m not putting in the right search terms?
    #5 LyssaChap, Apr 9, 2020
  6. Mendel Leisk
    42,365
  7. LyssaChap
    St. Louis, MO
    Thank you. Tried google several times but I’m guessing the terminology words I was searching for was not grabbing what was needed... I don’t usually ask for help unless I’ve exhausted all other avenues ;)
  8. PianoBench
    PianoBench Member
    155
    95
    San Francisco
    Here is a diagram that may help. You can also order official replacement parts from them. Or from your toyota dealer.
    The part number from the links below is "62505-47011." You can google image search that and see where the pins are that you need to pry off.
    all other diagrams:
    Genuine Toyota - Prius - ZVW50 - S TYPE - 2ZRFXE - 2019 OEM parts supplied from Japan - Nengun Performance
    side moulding diagram:
    Genuine Side Moulding 1 OEM parts for the Toyota - Prius - ZVW50 - S TYPE - 2ZRFXE - 2019 supplied from Japan - Nengun Performance
  9. estebinbin
    estebinbin Member
    184
    47
    I see that this conversation is from last year, hopefully I can get a few answers. Does anyone currently know if there was a recall/replacement program for this? And anyone out there know if the c pillar exterior black cover is the same for the prius prime as the regular prius in this discussion. Thanks, any words on this would be a great help
  10. Elektroingenieur
    2,515
    3,288
    Three Touring
    I don’t know of a customer support program or service campaign that would cover this part after the warranty expires, but it wouldn’t hurt to ask your Toyota dealer for goodwill consideration.
    According to parts.toyota.com, the same quarter pillar cover sub-assemblies, part numbers 62505-47011 (RH) and 62506-47011 (LH), are used on fourth-generation Prius and Prius Prime cars.
  11. krmcg
    2,592
    2,393
    Whittier, CA
    And these part numbers are different from the original parts that failed. The replacement panels I installed with the above part numbers are aging gracefully.
