How to remove foam inserts from trunk on 3 touring?
Discussion in 'Gen 4 Prius Main Forum' started by mlbex100, May 2, 2017.
  1. mlbex100
    mlbex100 Junior Member
    49
    22
    South Bay
    Three Touring
    If you lift the trunk cover to reveal the spare tier, there are three black injection-molded foam 'inserts': one over the spare tire and two on either side. The one over the tire just pulls away, but the two on either side are fastened to the metal floor with these odd connectors, and I can't figure out how to disconnect them without damaging them.
    They're OK around town, but when I travel, I like to take my toys with me, and that's a lot of wasted space. I could just pull and break the foam, but no, I want to reinstall them for everyday use.
    Can someone tell me how to disconnect and reconnect whatever those things are that hold the foam inserts onto the sheet metal without damaging them?
    Thanks, mlbex.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
  3. mlbex100
    49
    22
    South Bay
    Three Touring
    That helped, Thanks. It didn't really say how to get them out, but it looks like you have to just force them and know that they might become unusable.
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Sorry, that about sums it up. Although I searched, I couldn't find the thread I remembered. Good luck with the job. (y)
  5. Elektroingenieur
    2,515
    3,288
    Three Touring
    In the Repair Manual (available by subscription to techinfo.toyota.com), under Vehicle Interior: Interior Panels / Trim: Roof Headlining: Removal, the suggested procedure is: “Using a screwdriver with its tip wrapped with protective tape, while pulling the deck floor box LH [or RH] as shown in the illustration, turn the clip to remove the deck floor box LH [or RH].”
    “Deck floor box” is Toyota’s term for the foam inserts, and the illustration shows pulling upwards at the outer (farthest from vehicle centerline) edge of the insert, as you turn the fastener with the screwdriver.
    RCO likes this.
  6. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    There are some threads on modifying the inserts and even swapping out the inserts level 3 with level 4 no spare. Not sure if we have any removal instructions.
    Apparently both Level 3 (w/ spare) and Level 4 (no spare ) have the depression for the spare tire in the sheet metal bottom, so it's just the insert that's different (for the most part, based on 2016 model).
  7. Mendel Leisk
    42,345
    And leave the spare at home? (n)
  8. mlbex100
    49
    22
    South Bay
    Three Touring
    I got 'em. After talking to the Toyota parts person, I took a big screwdriver and lifted. They popped up one by one. No turning anything, just upwards force. I put a piece of plywood over the spare, threw a carpet over it, and got about 4 inches more vertical space.
    Also, the driver's side back seat comes out easily, creating a bit more room. I got all my toys to fit.
    First road trip yesterday. It handled the twisty mountain roads gracefully and got 54 mph (indicated, not measured)
    Mambo Dave, kithmo, krmcg and 2 others like this.
  9. PriusOffroad
    PriusOffroad Active Member
    108
    170
    Chico, CA
    krmcg likes this.
  10. jtg61
    jtg61 Member
    46
    43
    Ocala FL
    It is my understanding that the foam in the rear cargo area of the Prius is there for rear accident absorption. If you remove it, a rear end collision would be more severe to the point of puncturing the gas tank and/or causing a fire in the lithium batteries under the rear seat. It is there for a reason and pulling it out makes the car unsafe in a rear end collision. I wouldn't take it out under any circumstances.
  11. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    I find this hard to believe. Do you have any link with substantive proof to support your theory?
    I have compared both the foam from both spare and no-spare Prii. I can't see any significant attempt in either design that would indicate anything that supports your theory, but for sure, I'm willing to be proved wrong.
    It is my understanding that the only thing that offers structural protection in a collision would be carefully engineered sacrificial structural steel/aluminum, not styrofoam.
    Mendel Leisk and krmcg like this.
  12. jtg61
    jtg61 Member
    46
    43
    Ocala FL
    I can't find anything definitive. I think I read some random comments in the past in these forums that it might serve this purpose.
  13. Mendel Leisk
    42,345
    I think it's just filler, to keep the hatch floor from collapsing?
    krmcg likes this.
  14. PriusOffroad
    108
    170
    Chico, CA
    Thats a pretty bold statement to make based off of reading it somewhere in comments. Considering this is held down by plastic clips the chance of this giving any horizontal structural integrity in the event of a collision is slim to none. I would also be willing the bet the bolted in steel angle iron cross braces would provide substantially more impact resistance than the foam. The foam is there to support the rear hatch.
    krmcg likes this.
  15. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    When you write that you lifted, do you mean from the edge of the foam, or you lifted upon the plastic fasteners?
    I just placed the order for a used, but in great condition, Gen4 Prius wheel to use as a spare (full sized aluminum - I have places to be). I'm going to have to take that foam out, source a jack, and a tire.
