How to remove front seats/rear seats ?
Discussion in 'Prius c Main Forum' started by col127, Apr 17, 2013.
  1. col127
    col127 Member
    345
    Illinois
    Is there any writeups/diagrams on how to remove the front seats and rear seats from the Prius C?
    Wanting to put some more sound deadening on the floor of the car and I need to remove the carpet... but I can't do that because the seats are in the way ;)
    Thanks for the help!
    Cannaman420 likes this.
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Not sure about the write up part. But there is a thread about just this thing. Someone puts a ton of deadener in the car and took pictures of the whole process. Can't remember who it was, but it is definitely worth a search.
  3. col127
    col127 Member
    345
    Illinois
  4. wmo168
    wmo168 Member
    239
    49
    South Florida
    2. REMOVE FRONT FLOOR COVER RH
    3. DISCONNECT CABLE FROM NEGATIVE AUXILIARY BATTERY TERMINAL
    CAUTION:
    Wait at least 90 seconds after disconnecting the cable from the negative (-) auxiliary battery terminal to disable the SRS system.
    NOTICE:
    When disconnecting the cable, some systems need to be initialized after the cable is reconnected
    4. REMOVE FRONT SEAT HEADREST ASSEMBLY
    5. REMOVE FRONT OUTER SEAT TRACK BRACKET COVER (for Cold Area Specification Vehicles)
    (a) Lift up the seat track adjusting handle and move the seat to the rearmost position.
    (b) Disengage the 3 claws to remove the front outer seat track bracket cover. [​IMG]
    6. REMOVE FRONT INNER SEAT TRACK BRACKET COVER (for Cold Area Specification Vehicles)
    (a) Disengage the 2 claws and clip to remove the front inner seat track bracket cover. [​IMG]
    7. REMOVE REAR OUTER SEAT TRACK BRACKET COVER
    (a) Lift up the seat track adjusting handle and move the seat to the foremost position.
    (b) Disengage the 3 claws to remove the rear outer seat track bracket cover. [​IMG]
    8. REMOVE FRONT SEAT ASSEMBLY
    (a) Using a E10 "TORX" socket wrench, remove the 2 bolts on the rear side of the seat. [​IMG]
    (b) Lift up the seat track adjusting handle and move the seat to the rearmost position.
    (c) Using a E10 "TORX" socket wrench, remove the 2 bolts on the front side of the seat. [​IMG]
    (d) Disconnect each connector and clamp under the seat.
    (e) Lift up the seat track adjusting handle and move the seat to the center position. Then, operate the reclining adjuster release handle and move the seatback to the upright position.
    (f) Remove the front seat assembly.
    RobAustin and col127 like this.
  5. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
  6. col127
    col127 Member
    345
    Illinois
    Wow, thanks so much for that!! :) Where'd you get that from? Do you happen to have the rear seat removal instructions too ? I'd rather have the 'official' ones so I can follow it. Thank you!!!!!!!
  7. wmo168
    wmo168 Member
    239
    49
    South Florida
    1. REMOVE REAR SEAT HEADREST ASSEMBLY
    2. REMOVE REAR CENTER SEAT HEADREST ASSEMBLY
    3. REMOVE FRONT FLOOR COVER RH
    (a) Using a clip remover, remove the 2 clips <A>. [​IMG]
    (b) Disengage the 3 clips <B>.
    (c) Disengage the 3 guides and remove the front floor cover RH. [​IMG]
    4. REMOVE FRONT FLOOR COVER LH
    (c) Disengage the 3 guides and remove the front floor cover LH. [​IMG]
    5. REMOVE FRONT CENTER FLOOR COVER
    (a) Using a clip remover, remove the 3 clips. [​IMG]
    (b) Disengage the 2 guides and remove the front center floor cover.
    6. REMOVE REAR SEATBACK ASSEMBLY RH
    (a) Fold down the rear seatback assembly RH.
    (b) Remove the 2 bolts and rear seatback assembly RH.
    NOTICE:
    Be careful not to damage the vehicle body. [​IMG]
    7. REMOVE REAR SEATBACK ASSEMBLY LH
    (a) Fold down the rear seatback assembly LH.
    (b) Remove the 2 bolts and rear seatback assembly LH.
    NOTICE:
    8. REMOVE REAR SEAT CUSHION ASSEMBLY
    (a) Using a clip remover, disengage the 2 clips.
    Text in Illustration
    *a
    RH Side
    *b
    LH Side
    (b) Disengage the hook of the rear seat cushion assembly from the vehicle body as shown in the illustration.
    Standard Measurement
    a
    100 mm (3.94 in.) or less
    NOTICE:
    Follow the instructions below carefully as the cushion frame can be deformed easily.
    (1) Choose a hook to disengage first. Place your hands near the hook as shown in the illustration. Then lift the seat cushion to disengage the hook.
    (2) Repeat the step above for the other hook. [​IMG]
    (c) Remove the rear seat cushion assembly.
    NOTICE:
    9. REMOVE REAR SEAT CUSHION LOCK HOOK
    (a) Disengage the 2 claws and remove the rear seat cushion lock hook as shown in the illustration.
    HINT:
    Use the same procedure for the RH side and the LH side. [​IMG]
    RobAustin likes this.
  8. lameron
    lameron New Member
    ok, i have a question. it might sound stupid, but how can i "Disengage the 3 clips <B>."??
  9. wmo168
    wmo168 Member
    239
    49
    South Florida
    There maybe special tools that goes in, I am not sure as I haven't done it before.
  10. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    Don't worry about that. First remove the push clips then just pull outward in a slow forward motion.
  11. Jim at Growing-Faith.org
    Nomad
    Do you know if it is possible to separate the back rest from the seating portion of the passenger seat? I have a thread started here:
    Removing upper passenger seat back rest | PriusChat
    It seems like people in this thread might have the knowledge to help me. Thank you!
  12. Jim at Growing-Faith.org
    Nomad
    Do you think this is true for the Prius C:
    "The reason I suggest this is that properly removing and reinstalling the front passenger seat on US models can be a hassle, not to mention potentially unsafe in a collision.
    The front passenger seat is held by four bolts, and has two or three wire harness connectors.
    However, the seat is equipped with an Occupant Classification System (OCS) ECU that communicates with the Airbag system. The seat also has the seat cushion switch, seat belt buckle sensor, four weight sensors in the seat frame, the seat cushion airbag, and the side airbag.
    Turning the vehicle on while the seat is disconnected will set diagnostic trouble codes in the airbag ECU that may prevent normal operation of the airbag in the event of a collision, and will need to be cleared after reinstalling the seat.
    Zero-calibration of the OCS system is required each time the seat is removed and reinstalled."
    Which is from this thread:
    How hard to remove front passenger seat? | PriusChat
    Thanks in advance.
  13. Cannaman420
    Cannaman420 New Member
    Indianapolis, IN
    2017 Prius c
    Here's a writeup I did when I removed the back seats completely. The front seats are pretty simple, just 4 screws on the tracks that slide the seat forward/backward under some pop off plastic covers and 3 connectors per seat.
    Prius C backseat removal in 10 steps | PriusChat
    I assume you were adding deadening for a subwoofer? I'd love to see pics of your system! I have a 15" sub in my PC2 using about 1500 watts rms in a custom box. Subs in a hatch are the best!
    alistaircookie likes this.
  14. Hartish Khoobarry
    Hartish Khoobarry Junior Member
    49
    Mauritius
    2014 Prius c
    Do have a link where the pics are availble?..
    If you have a video.. it would be better
