How to remove hard water from windshield?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by manoosie, Nov 19, 2012.
  1. manoosie
    manoosie Junior Member
    23
    I bought a 2004 Prius recently, and there are water outlines where the windshield wipers work. I looked up the tricks online, and tried white vinegar. No luck. I went to the next step and purchase very fine steel wool (#0000), but that doesn't do anything to it either.
    Any tips? It is driving me crazy. Thanks.
  2. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    ...keep trying with vinegar maybe soak rag and lay it on there to give it time to react. But possibly there is permanent damage to window.
  3. fuzzy1
    10,170
    A housemate long long ago had success removing hard water spots with jewelers rouge. But he didn't mention wiper scratches. I've never used it, so don't know the caveats.
  4. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    I don't know if this would do what you want, but I have successfully cleaned lime and chlorine stains off of glass using "Lime Away". I am not saying it will remove the lines you are talking about, but it won't hurt to try it. I would not recommend spilling the product on your paint, as it might damage the paint.
    Ron
  5. born_again
    born_again Member
    103
    47
    Rancho Palos Verdes, CA
    when all else fails, focus on hypermiling.
    PriusGuy32 likes this.
  6. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    This product is also known as "CLR", and it removes calcium, not chlorine... do be careful around your paint, and your skin for that matter.
