How to remove Hybrid battery quickly and easily
Discussion in 'Gen 2 Prius Technical Discussion' started by 3prongpaul, Aug 20, 2013.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    Here's a video of us removing a Gen2 traction battery in about 10 minutes.
    (We cheated a bit and used multiple lithium powered impact drivers)
    Hand ratchets would take significantly longer. Apologies in advance for the bad audio.
  2. koolingit
    koolingit Member
    158
    52
    Mocksville NC, USA
    I loved it! Now you've got to do one showing the installation. In the meantime, I'll be watching this one twenty or thirty times!
  3. 3prongpaul
    956
    735
    Just watch it backwards for install procedure!
  4. koolingit
    koolingit Member
    158
    52
    Mocksville NC, USA
    Seriously, I was wondering about the bolts. It looked like everything was 10mm but were they all the same size and thread pitch and length? I noticed you pointed out a few were black but were all the rest really the same size?
  5. 3prongpaul
    956
    735
    There's a bunch of different fasteners, two 8mm nuts hold the orange HV cables to the black relays, plenty of 10 & 12mm bolts/nuts. The seat-backs are 14mm, so you need sockets for 8,10,12,14mm. Pliers to remove plastic barbs are helpful. If you view the video on Youtube directly my comments explain a bit more.
    If doing it your first time you could store each type of fastener in a muffin tin or take photos as you go.
    I've done it so many times I know which fasteners go where from memory.
    ovenmage, Merkey and koolingit like this.
  6. bisco
    52,855
    well done, thank you!(y)
    Merkey likes this.
  7. Flying White Dutchman
    4,376
    314
    Great video
    nice so see it compleet in 1 video
    if anyone wants to see a relay replacement
    here is a old video
    or speeded up
  8. 3prongpaul
    956
    735
    I've never seen a main relay fail on a stock Prius. Do you think yours failed because of the PHEV system? The main relays are not designed to cycle with an active load.
  9. Flying White Dutchman
    4,376
    314
    yes that was the cause of it!
    human error and no patience.:)
    but no problem have some laying around ;-)
  10. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Where can I get the big pliers-like removal tool shown in the video? Thanks!
  11. 3prongpaul
    956
    735
    2009Prius likes this.
  12. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A high voltage (300v), high current diode across the contacts (reverse biased so normally no current) would protect the contacts from inductive kicks. Slight chance of diode leakage causing problems when the Prius is off.
    JeffD
  13. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    wow.mad respect. I bet you could remove and replace my aux battery while asleep and eating a sandwich! Thats on my mind as I need to do this next week! (the aux battery NOT what you did!)
  14. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    LOL I thought I was doing good at 30 mins as a first timer with no power tools.....of course I forgot to push the handle down on the safty plug after I installing it and went over everything else 3 times but 20 mins later it was back running..
  15. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I get the feeling you've done this before. Like, a few dozen times.
    Well done, Paul. Thanks for posting.
  16. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Missed this post before.
    I've seen and worked with Paul before.
    The man is a machine. Knows every bolt and size without even looking.
    We should have a competition sometime to see who can do it the fastest. :)
    Carmen TheWonderDog likes this.
  17. Gambitsource
    Gambitsource New Member
    22
    San Diego
    Hello everyone. This was a very helpful thread in getting the battery out of my 2007 Prius. I replaced 2 modules and charged 3 modules with power cycles. Next, after putting the HV battery back in and getting the car started I am back to square one with the power drain. I show 16.3-16.5 V per Cell on Torque Pro and when driving it I will come to a stop with my foot on the brake and I see the power draining slowing from the Hybrid battery. I wonder if I need to replace the whole battery... any thoughts?
  18. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    YES...............
    m.wynn likes this.
  19. bruthajess
    bruthajess Junior Member
    Las Cruces
    Paul, just wanted to give you props for a great video! It was super resource as I replaced my hybrid battery this morning!
  20. Gambitsource
    22
    San Diego
    Not even the right battery man. Mine is 2007....
