How to Remove the MFD from a. 2007 Prius
Discussion in 'Gen 2 Prius Audio and Electronics' started by Michael Crestohl, Aug 5, 2022.
  1. Michael Crestohl
    Michael Crestohl Junior Member
    63
    Marblehead Massachusetts
    Can anyone tell me how to remove the MFD from a 2007 Prius! Can I simply swap it for one with the navigation system or is tyere more to it than that?
    tia,
    Michael
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Easy to remove but often the AC vent covers get very brittle, so don't be surprised if one or more break, especially the two in the middle. Here's a pretty clear video of the process.
    You can't just put in any MFD. You'll need to do some research to see which one or ones will match with yours. Your car, for example may not have the connectors for the maps since there's a GPS involved. If you post the part number that's on the back on this thread, maybe someone can help with that. IIRC, they all start with 46 and are five digits.
    Or, you can send it to the guy in the video for repair as some others here have done.
