How to remove this fastener?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by mercat68, Apr 4, 2021.
  1. mercat68
    mercat68 Active Member
    304
    216
    Mount Airy, MD
    Came across this fastener on an underbody panel at the rear of my 2017 Prime (removing panels to mount a hitch). Tried turning it, but no luck. Any tips on how to remove it? Thanks.
  2. Mendel Leisk
    38,763
    Try pushing down and/or prying up on that central bit?
  3. mercat68
    304
    216
    Mount Airy, MD
    Thanks, I’ll try, but might be a little awkward trying to do both at the same time in tight space. Why do manufacturers create a variety of odd fasteners when a simple pan head screw would do?
  4. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    To save weight. It looks like those "tabs" might be for inserting something wide and flat, then turning counter-clockwise. Just a guess...
  5. mercat68
    304
    216
    Mount Airy, MD
    Yeah, that was my first move, but just turning doesn't do it. Pushing the blue pin doesn't work either (it's not a pushable pin, it's the tip of the post on which the fastenter sits). I ended up turning and yanking down hard as I turned. It broke free. Nolt sure if that was the right process, but it worked.
