How to remove white steering wheel cover
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Mario-V, Feb 18, 2017.
  1. Prodigyplace
    12,713
    11,848
    Central Virginia
    If this were available in matte black I would get one for $20
    Steering Wheel Garnish
  2. dml996
    dml996 Junior Member
    Spartanburg, South Carolina
    You can buy replacement pieces for the steering wheel on e-bay or Rakuten Japan
  3. mrlarrys
    mrlarrys Junior Member
    26
    68
    PA
    2023 Prius
    IMG_3521.JPG bought this on Ebay for my 2018 prius ECO - it is a cover and was installed with double sided tape - best $20 I ever spent, fit perfect IMG_3524.JPG IMG_3522.JPG
    #23 mrlarrys, Oct 18, 2018
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,603
    Taylors, SC
    The equivalents for the 2018 and up Corollas and Camrys are showing up with different color OEM steering wheel trims.
    Unfortunately the panel cannot be purchased from Toyota dealers without the switch assembly.
    If you wait, they will sure show up in wrecking yards. Since these parts rarely go bad even with the air bags deployed, they will likely be cheap.
  5. mrlarrys
    26
    68
    PA
    2023 Prius
    Ebay item # 142853749780
  6. Prodigyplace
    12,713
    11,848
    Central Virginia
    I want one in matte black to match my console.
  7. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    Do you happen to have pictures of the back of the airbag, and the naked steering wheel? I've found the 3 holes in the back of the steering wheel, but I'm poking around a bit blindly, and can't find the part I need to release to get the airbag to come off.
  8. Luke Warmchops
    Luke Warmchops New Member
    Maine
    I purchased a black plastic cover recently on eBay. The ad said it was only for the Prius Prime, but my local Toyota dealer told me that the original part (the white part being covered) were the same part number on the Prius and the Prius Prime. It fit perfectly. The cost was about $16. This is a much better solution than painting it.
