How to repair/replace wire - Loud rattle/shaking + chewed wire - 2017 Prius C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Ben R J, Oct 14, 2020.
  1. Ben R J
    Ben R J New Member
    29 Palms, California
    2017 Prius c
    Hi there. I have a 2017 Prius C. When I start the car, about 30 seconds in, it starts to violently rattle and shake. It's even worse when in drive or reverse (I just drove it around my driveway for a minute to see what happens.) The engine light comes on when in drive, but not if I brake or park.
    I lifted the hood and think I found the culprit- a chewed up wire. There's also rat/rabbit fur all over the engine and they might have chewed other things, but I haven't found anything else yet.
    If someone could tell me what this wire is and how they would go about fixing it, it would help a lot. I live in the middle of nowhere and got a flat tire last month and the tow alone cost $500- with insurance. I'm not handy with cars so my only option right now is to try to hire someone to come out and fix it and at least if I get some answers on here, I can know whether or not this person is up for the task.
    Any thoughts are welcome. Thanks.
    Screen Shot 2020-10-14 at 1.38.18 PM.png Screen Shot 2020-10-14 at 1.37.28 PM.png Screen Shot 2020-10-14 at 1.37.56 PM.png Screen Shot 2020-10-14 at 1.37.39 PM.png
  2. PriusCamper
    PriusCamper Senior Member
    12,555
    5,085
    Pacific Northwest, USA
    There are very few repair jobs that are easier than this... Almost anyone who has basic wiring skills could do it in 5 minutes.
    Ben R J likes this.
  3. Elektroingenieur
    2,515
    3,282
    Three Touring
    The Electrical Wiring Diagram (more info) shows that’s connector C1, for Fuel Injector Assembly No. 1. The engine is rattling and shaking because the cylinder isn’t getting fuel.
    If it were my car, I’d buy this set of fuel injectors and their connectors for sale on eBay for $65:
    12-19 Toyota Prius C Fuel Injector Injectors Set 1.5L L4 OEM 13 14 15 16 17 18 | eBay
    (I have no connection with the seller.)
    That would get you a replacement connector—the black one with green and gray wires, second from the left in the seller’s first picture—with the correct terminals and seals already installed. The price isn’t much more than the cost of the two repair wires (pigtails) you’d have to buy instead from a Toyota dealer, but it would avoid the need to extract the old terminals and install the new pigtails into the old connector housing, which can be tricky if you’ve never done it before.
    Instead, you could cut off only the damaged sections of the green and gray wires going to the old connector, leaving as much of the existing wire as possible, and then splice them to the short green and gray wires from the new connector, as described in Toyota’s Wire Harness Repair Manual (PDF), pages B-30 (46) through B-35 (51), step 3, items 1 through 6, and in an old Toyota video (from 16:26 to 17:37).
    You’d need parallel splices (sleeves) (probably the blue size, but maybe the yellow size, depending on how large the wires are), a suitable crimping tool, and self-fusing silicone tape.
    If you decide to do the work yourself, see the precautions in the Owner’s Manual (PDF), pages 414–415, and if you’re not confident in the result, consider taking the car to a shop to have it checked and redone if necessary.
    PriusCamper and Ben R J like this.
  4. Ben R J
    Ben R J New Member
    2017 Prius c
    Thank you! That's a lot of good info. Appreciate it.
    Elektroingenieur likes this.
