how to repair the engine compartment wire
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by zakky, Nov 11, 2015.
  1. Mendel Leisk
    42,386
    I've worked with engineers, that'll look at my attempt at design, then basically say: "Ok, that's good, but too complicated and expensive, overkill for the situation".
    Don't turn it into a pissing contest, lol.
    mertechperformance and HGS like this.
  2. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    I don't think it requires zip ties at all. Just posted which ones would last the cars lifetime under the hood.
    Also, they're quite affordable. Gardner Bender. But most would buy in larger packages to be more worthwhile. And yeah about $30 for a 500 to 1000 pack all depends on length.
    #22 mertechperformance, Nov 16, 2015
  3. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I hope that's not anything like Kapton which has been implicated in a number of aircraft fires and crashes...
  4. HGS
    HGS Member
    307
    123
    I used F4 tape back in the 70's when I worked on fighter aircraft in the USAF. It's good stuff. I won't worry about fires, etc.
  5. frodoz737
    frodoz737 Top Wrench
    4,812
    2,564
    33
    Kapton is/was wire insulation. Nothing to do with this topic.
