How to Replace Gen II Prius Engine Coolant
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Zedhomme, Oct 16, 2013.
  1. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    Here's a presentation for do-it-yourselfers on how to change the Gen II Prius Engine Coolant.
    Most important thing I learned was patience when draining and refilling and bleeding out any trapped air.
    tacopyro, FreydNot and yugoport like this.
  2. yugoport
    yugoport Junior Member
    Thanks for sharing, it's a great document.
    Enviado do meu GT-I9300 ?
  3. jamesacarroll3
    jamesacarroll3 Junior Member
    Dallas
    As someone who spent the last several days patiently trying to work through an air-lock after changing the coolant control valve and inverter coolant pump, I recommend adding a "Lisles funnel" (~$26 on Amazon) to this procedure for the DIY'er. This will greatly speed up the process, prevent a lot of spillage, and doesn't require shop-air.
    koolingit likes this.
