how to replace hid head light blubs
Discussion in 'Gen 2 Prius Main Forum' started by k4141222, May 13, 2007.
  1. k4141222
    k4141222 New Member
    can some one please give me some advise on changing the hid head light bulbs i want to do it myself cause the dealer wants 300 bucks for the bulb not counting labor. I found a pair on Overstock.com for 20 bucks . and i see some moulded plastic that looks like i should pry open with a screwdriver . and i dont want break something thank you kirk
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Don't know about HID but regular bulbs are covered in the owners manual.
  3. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    if u have HID's u have to get the d2R socket type bulbs, no ordinary halogens woudl fit there and surely doesnt cost 20
  4. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    What year is your car? I'm shocked the HID bulb would require replacement this soon. They should last many, many, many years. We're talking 10 years plus.
    As for the bulbs, hate to break it to you but they REALLY need to be replaced in pairs, even moreso than halogen bulbs (although headlights should always be replaced in pairs). The HID's color changes pretty distinctly as they age, a new one and an old one will look very different. In fact Phillips makes a bulb that is designed to replicate the color of a used bulb just for this reason.
    I would be EXTREMELY dubious about a $20 solution, ESPECIALLY for a pair. Thats impossible.
    http://www.overstock.com/search?SearchType...mp;keywords=HID
    This what you found? These are not HID bulbs, they're crappy blue painted halogen knock offs used in ricer cars. These will not work in your Prius with HID.
  5. galaxee
    galaxee mostly benevolent
    9,810
    466
    MD
    twenty bucks for HID lights.... no. the dealer is asking the same price as any other dealer will charge you- that's a pretty common price for HIDs.
    the install does not involve any prying apart of plastic. there is a quarter-turn quick-lock plastic cap over the back of the housing. after you take that off, you'll see the metal socket, which you also turn 1/4 turn. then there's a hinged spring clip that you swing off to remove the old bulb. do not touch the new bulb!!!!! then it's a matter of replacing everything.
  6. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(galaxee @ May 13 2007, 10:00 PM) [snapback]441466[/snapback]</div>
    I haven't had to do this yet, and imagine it will be a long time before I have to do so. However, in the event that the bulb is touched. Would cleaning it with alcohol remove contaminants sufficiently for the bulb to work safely/properly?
    Dave M.
  7. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    No way in hell could you get the real thing for $20 a pair. That's a joke.
  8. banggooooo
    banggooooo New Member
    He/she is probably referring to new halogen bulbs that are whiter.
