How to replace passenger side standard low beam bulb
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by web1b, Mar 9, 2013.
  1. gliderman
    gliderman Active Member
    751
    225
    Yep. It sure is. I have plenty of experience replacing them. And they are easy.
  2. 50324prius
    50324prius Junior Member
    39
    iowa
    If this is the case then why is it that only the passenger side has gone out twice? Every 6-9 months I have had to replace it. I do not leave the headlights on in the day time and do not do a lot of night time driving.
    I used to use Silverstar brand, but went back to the less expensive ones.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The passenger side one also always burns out for me, not sure why.
    The low beam bulb isn't too difficult to replace, but the passenger side marker bulb is a REAL PITA.
    iPhone ?
  4. gliderman
    751
    225
    My amber passenger side marker bulb is permanently burnt out. It will not be replaced.
  5. Hoosier1
    Hoosier1 Member
    87
    33
    Southwest Indiana
    Use a 10mm socket or wrench and remove the two bolts holding the reservoir. You can leave the hose connected when swinging the reservoir out of place. This approach provides easy access to the passenger side low beam light bulb. I replaced the OEM bulbs with Silver Star Ultra's last October. The bulbs are still going strong and make a substantial difference when driving on dark roads. Of note are the increased side visibility and slightly whiter light. There is a YouTube video that shows the process that someone posted to install a "Prius HID Xenon low beam package." Goggle the words in quotation marks for a step by step process to access the bulbs.
    Changing both bulbs takes less than 10 minutes. Just be sure to not touch the bulbs with your bare hands.
  6. Hoosier1
    Hoosier1 Member
    87
    33
    Southwest Indiana
    Here's the link to the video that illustrates how to access the bulbs.
    Robert Holt likes this.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I bet u do :D
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    It could be due to oil / dirt on the bulb. Any containment on the bulb will create a hotspot & in time the bulb will burn hotter in that spot causing the bulb to have a shorter life span.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I love the fact that i don't have side marker lights......just a nice white LED bar & white reflector :p
  10. hlunde
    hlunde Member
    419
    75
    I've replaced one roadside without moving the coolant reservoir. It was tight, but possible. Carry a 10mm wrench to move the reservoir.
    My real issue is that some family members are accustomed to DRLs and keep Prius headlights on all the time. Then they fail and you don't know it until you're miles from home and you turn on your headlamps in the dark. Lamp failure indicator does not include headlamps. Duh?
  11. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    It's not the reservoir that has to get moved but the coolant hose. Nonetheless, I am sure for some it can be done without moving it over but for those with big(ger) hands it can be quite the task.
  12. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Thank you, Hooiser1, for that video, and thank you to the rest of the respondents in this thread for all the information that encouraged me to just replace the low beam headlights myself. I have big hands, so I chose to unbolt the 2 10mm bolts securing the coolant reservoir and shift it on top of the engine to get the space to work on the passengers ‘ side. I replaced the OEM halogens on our 2012 hatchback with Sealight S1 LEDs, hoping to gain some illumination when using low beams. The bulb replacement was under 15 minutes and was facilitated by the fact that the Sealight bulbs have a very small ballast with an extra 6” of cable on them. Securing the ballasts so that they would not flop around, however, took another 10-15 minutes. The 6000k bluish-white color of the low beams now matches the LED parking lights I installed a couple years back.
    Cheers!
